Welcome to the North American Subaru Impreza Owners Club Monday March 8, 2021
Old 10-04-2020, 08:53 PM   #51
VarmintCong
Member#: 379605
2017 Civic Sport
2012 Outback 2.5
Originally Posted by samb View Post
COVID model?
Built when companies were doing things like putting admin people to work in the factory, lol. The entire supply chain is gonna have issues with quality, imo.
VarmintCong is offline   Reply With Quote
Old 10-04-2020, 10:45 PM   #52
White out
Member#: 46277
** LP640
575M DMC-12
Really tempted to GT350R before it's axed
White out is offline   Reply With Quote
Old 10-05-2020, 07:19 PM   #53
Skylab
n00b Moderator
Member#: 4263
Apparently the Voodoo is not available as a crate engine. Man, it would sound so refreshingly different hearing that exhaust over the gazillions of LS motors shoved into everything.
Skylab is offline   Reply With Quote
Old 10-05-2020, 08:23 PM   #54
thill
Member#: 377200
20 Camaro SS1LE
Shadow Grey
Well I’m pretty sure the order banks are closed so if you want a new one you better pounce soon. The last ones will roll off the line in December.
thill is offline   Reply With Quote
Old 10-06-2020, 08:19 AM   #55
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
There are three main reasons the LS finds it's way into everything under the sun: price, availability & packaging; it's cheap, plentiful and small (dimensionally); the Voodoo is none of those things. I do agree with you though, hearing more FPC engines on a daily basis would be welcomed.
Sid03SVT is offline   Reply With Quote
Old 10-06-2020, 11:09 AM   #56
Pre
Member#: 139693
FPC will live on in the upcoming Z06.
Pre is online now   Reply With Quote
Old 10-06-2020, 12:23 PM   #57
JP Chestnut
Member#: 504432
Not to mention reliability and weight. Chevy has done a good job more often than not at delivering reliable high performance engines.
JP Chestnut is offline   Reply With Quote
Old 10-06-2020, 02:29 PM   #58
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
DCT only, and 85k starting price, not quite as desirable or approachable as a GT350.
Yeah weight/power output ratio is good too; there is a long list of reasons why the LS just makes sense for a lot of applications. I'm deciding between an aluminum LS NA build and a 351w with a twin screw or roots blower - same power output goals, different ways to get there, the iron block Windsor w/aluminum heads and a blower is around 150lbs heavier & $1,500+/- more expensive than the LS, but it will make blower noises.. I don't give a wet-slap about purity, I care about fun, not sure if the windsor is worth the extra money just for blower noises though... I toyed with a twin screw/roots blower on the LS, but I'd overshoot my power target and more importantly, my budget. It's gotta be a twin screw or roots blower though, I'm going for theater, not dyno numbers; no turbos or centrifugals.
Old 10-06-2020, 02:32 PM   #59
JP Chestnut
Member#: 504432
I’ve been planning an all aluminum small main 351w based stroker but some of the various LS engines can put down similar numbers stock.
Old 10-06-2020, 02:43 PM   #60
SCRAPPYDO
Member#: 873
2020 JEEP / Ascent
Datsun 71 240Z & 68 2000
why not just skip all the newer LS stuff all together. Build an old school iron block SBC with a nice 6-71 Roots on it. If you want theater that would do the job and would be cheaper than any newer FI build. You could keep the camshaft on the milder side and still easily top 500HP and be perfectly streetable.
SCRAPPYDO is offline   Reply With Quote
Old 10-06-2020, 03:56 PM   #61
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
It's going in my 66 mustang; if I'm staying old school it's a Windsor with a blower, if I'm going bowtie it's an aluminum LS - honestly building an iron block SBC with a blower is about the same money and likely more than an aluminum NA LS build which will net the power I'm looking for in NA trim, a SBC will weigh as much as the Windsor with a blower; there just isn't a reason to go there over a Windsor for me. I don't want much power, ~400whp will be plenty, maybe even too much in this car, I just like blower noises which is why I'm contemplating it. An advantage of an LS blower build is that there is stuff out there in GM cars that are proven reliable from the factory; the second gen CTS-V put down about 500hp/500tq at the wheels and they go forever, I could start there, with a smaller pulley and be happy with the overhead in the engine for when the more power itch hits again in 5ish years; the R&D is done for me already. I also am staying with pump gas, no E85 or alcohol. Not a track or drag car build, it's a street car that will probably see the occasional track day. One thing is certain though, it's real easy to spend money.
The advantage of an Aluminum LS NA is less weight on the front end for my power goal, the advantage of a Windsor with a blower is theater, just have to decide what is more important to me; not exactly a lot of examples of those particular cars out there to test drive to see which I prefer, you know what I mean?
Old 10-09-2020, 03:02 PM   #62
KC
Member#: 442
17 Imp Spurt
00 S2k
Local dealer has a new GT500. $25k ADM. $103k for a, excuse me while I choke back a laugh... a 77 thousand dollar ... Mustang.
--kC
KC is offline   Reply With Quote
Old 10-09-2020, 04:23 PM   #63
Skunkers
Member#: 115480
2014 Mazda3 sGT
Soul Red
--kC
Yeah we've crossed into the stupid zone now.
Skunkers is offline   Reply With Quote
Old 10-09-2020, 04:37 PM   #64
JP Chestnut
Member#: 504432
I was looking at the GT500s on car.com and they had multiple in the $125k range.
Old 10-09-2020, 04:41 PM   #65
dwf137
Member#: 161333
18 Highlander
Yami XSR
--kC
Ain't got nothing on this local beauty:
https://www.pierreford.com/new-Seatt...6P8CF4L5126802
$152K asking... Sticker says $50k. I'm confused...
Old 10-09-2020, 05:02 PM   #66
brandon
Member#: 1183
18 Altrak, 76 Mini
64 Lotus Elan, 70 Elan +2
To be fair... they do have a $500 Military Appreciation Bonus. Bunch of softies that they are...
brandon is offline   Reply With Quote
Old 10-09-2020, 06:22 PM   #67
grovlet
Member#: 372889
2005 Legacy GT
It's a Shelby Upgrade - But which package? Probably trying to push "Super Snake" Package...
Shelby.com
There's a "Super Snake" Convertible at a dealer near me in MA - but you can see the car and it was ordered / built / delivered to the dealer $133K....
https://www.saratford.net/new/Ford/2...earchDepth=3:3
So yeah = expensive mustangs - but "Shelby" special editions and 700+WHP
All that said = Not for me - would rather custom mod to my own specs for less $$ than "Shelby" (if I wanted to build a Mustang)
grovlet is offline   Reply With Quote
Old 10-09-2020, 06:40 PM   #68
dwf137
Member#: 161333
18 Highlander
Yami XSR
Shelby.com
Thats what I was wondering... had me confused. So a 50k car plus a Shelby package... got it. Still crazy stupid for a mustang to cost 150k...
Old 01-19-2021, 09:03 AM   #69
AVANTI R5
Member#: 73805
I got scared watching it..ahhh when he graps 5th near end that's where boys and men are separated and sixth well that's when lawyers have Probate popping their head.
Old 01-19-2021, 01:58 PM   #70
Pre
Member#: 139693
You can teach a chimp how to drive fast in a straight line. Not really impressive.
Old 01-19-2021, 02:03 PM   #71
hi5.0
Member#: 340456
2013 Impreza
I dunno, in America it seems even driving in a straight line at any speed can be difficult these days IMO based on some stupid ***** I see on the road.
hi5.0 is offline   Reply With Quote
Old 01-20-2021, 11:17 AM   #72
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
The gauge was a little fuzzy on my playback, was that 180 MPH?
mhoward1 is offline   Reply With Quote
Old 01-20-2021, 11:20 AM   #73
Sid03SVT
Member#: 183032
RWD Camry
Pull me over red
275kph/170.9mph
Old 01-20-2021, 11:28 AM   #74
JP Chestnut
Member#: 504432
Unfortunately, a nontrivial number of Subaru drivers can't seem to do so even with EyeSight.
Old 01-20-2021, 11:37 AM   #75
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
275kph/170.9mph
I thought it would be higher.
I've seen high top ends on the long stretches on large tracks, but on much more aerodynamic cars.
That front grill kills the top end, but that car isn't about top speed.
