Welcome to the North American Subaru Impreza Owners Club Tuesday June 17, 2025
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 06-14-2000, 12:29 AM   #1
Formula1
Member#: 1576
2000 2.5RS
BRP
Unhappy Weapon R intake vs. water
Guys, one quick queston!
I have an intake on by weapon -r and the rainy summer season has just started in Florida! Is there a chance this filter or in that case any exposed filter will take in water? I opened the hood the other day after driving home in the rain to see that the inner fender and all areas surrounding it were wet! is this normal, to have an exposed filter this close to water?
Does anyone else share this concern?
John
Formula1 is offline
Old 06-14-2000, 12:39 AM   #2
Strepto
Member#: 252
Post
if the vent directly above the filter is open you will very likely suck up some water. I don't think you need to worry if that vent is closed.
Strepto is offline
Old 06-13-2000, 01:00 PM   #3
Basil
Member#: 743
MY02 WRX Wagon
TXS Stg 2 - 242 whp
Post
I'm getting one of Rallispec's MY00 intakes and was curious about the same question - particularly since they open the hood vent.. Apparently they are taking the plate that closes the vent, and using stand-offs, mounting it a little lower to promote airflow. My big thing was "am I gonna suck in water" - their answer - nope.. Shouldn't have a problem.. I am going to put a bag over it when I wash the car, but not worry about it otherwise..
Anywho - if you're not opening the vent, don't worry about it..
Basil
Basil is offline
Old 06-13-2000, 01:39 PM   #4
Matt
Guest
Member#:
Post
Strepto, where is that intake you mentioned from Rallispec ? Their web page shows "comming soon". What do you know about how they are going to set it up ?
I ask because i really want an intake and Have seen a few different designs available.
Old 06-13-2000, 01:42 PM   #5
Basil
Member#: 743
MY02 WRX Wagon
TXS Stg 2 - 242 whp
Post
Actually, that was me.. hehehe.. There's a thread in the general forum - it has photos.. I've also been talking to them about it since march - I was going to have one installed with my N1 catback, but had an unexpected expense. It looks like a great set-up, around $350 bucks..
Basil
Basil is offline
Old 06-13-2000, 07:08 PM   #6
jhoffmann
Member#: 1407
2000 2.5 RS-T
BRP
Lightbulb
Formula1,
I have an ISR intake on MY00 Impreza RS. I have opened the hood scoop but not the small vent above the filter. I live in Minnesota and have driven many miles in down pooring rain and behind vehicles throwing all of the water mist at me and have had no problems. I was also concerned about the same thing when I first did my intake but decided to give it a try. We'll see if I am proven wrong. Good luck and go for it.
Jim H.
jhoffmann is offline
Old 06-13-2000, 11:38 PM   #7
Fitz
Member#: 1426
'07 335xi,14 Tundra
848 Evo Race Bike
Post
I'm still a little bit iffy about most of these intakes. I know on the MY00's that if the motor senses it's taking in hot air, it actually retards the timing. Freeing up flow is great and everything, but unless you're tapping into a cold air source (Fender or hood scoop) I see them being more of a detriment than anything else.
I don't see the hood vents being much of a cold air source but rather just what it says; a hood vent. I'm pretty sure a low pressure is created outside of those hood vents while driving. The higher the speed, the more efficient the low pressure. Back in highschool my auto teacher used to illustrate this principle by filling a bucket full of water. He then blew a stream of compressed air over the top of the bucket and it literally "sucked" (if there was such a thing) the water right out. The same thing can be done with a straw and a small container. The low pressure that's created will actually push the water out of the container, up the straw, and into the air....
Just a thought...
Fitz
Fitz is offline
please compare: gpmoto (rallitek) intake vs. weapon r intake legacy2003 Normally Aspirated Powertrain 0 07-11-2004 02:50 PM
COBB Intake vs. Weapon-R Intake DoodieHead Normally Aspirated Powertrain 39 11-03-2001 03:57 AM
intake vs. WATER SuBaRu-ImPrEzA_RS Technical Forum Archive 2 09-09-2000 12:34 AM
Weapon R Intakes vs. the competition Matthew Nelson Technical Forum Archive 28 09-07-2000 01:32 PM
Weapon R Intakes vs. the competition Matthew Nelson General Forum Archive 3 08-31-2000 12:19 AM
