#1451 |
Member#: 92634
RMIC
![]() Did not spot any killdozers. Cash obtained.
I was thinking anything involving a crane in Grand County would be $1k on its own just to get them there. So I’m honestly pleasantly surprised.
#1452 |
Member#: 92634
RMIC
![]() My deck contractor guy came around today with the framer. Clarified plans and timeline. 90% likelihood imo that this deck work happens by the 20th as it needs to. He now has a check for $15k in hand to cover initial materials and at least part of the labor.
Many more instances pointed to at how the 2021 rebuild of the deck was a ****ty job. Wrong kind of wood for the exterior ledger, not tied in to the beam away from house, flashing wrong, the damage to the EIFS, etc. This should get it fixed up properly, and reinforced with the two 18” concrete caissons supporting a 12’ long beam under the hot tub area proper. Damaged EIFS near deck surface will be covered up with something else, which will actually improve the aesthetics considerably. |
#1453 |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! mix and match silver |
#1454 | |
Member#: 92634
RMIC
![]() my electrician made an error on the wiring: I'd initially texted him that I needed one 30A and one 50A line, but he somehow parsed 50A x 2 and thus 6 ga. in reality I actually needed just a 20A + the 50A.
I thus asked the electrician as a make-up of sorts for this extra unneeded cost to drill a hole through the main floor wall for me (for Starlink wiring), as I know he has the tools. and it turns out the whole house is ICF construction! https://www.buildwithrise.com/storie...cf-sustainable in other words, it's all concrete in the middle of the walls. for his two 240V lines he thus had to drill through the concrete of the walk-out basement wall. and for the extra hole that I asked for he also had to bust out the hammer drill and drill through the concrete of the main floor wall! my battery powered tools and Chinesium 1" bits would have had no chance at all... anyway, it being all ICF is news to me. I knew the basement was all concrete due to it being walk out and the uphill side having rooms underneath the main floor and garage alike. but I didn't know about the other floors also being done the same. this is a nice surprise from the house perspective for a change. this also has bearing on the deck reinforcement work: the engineer correctly had figured out that the house was ICF and denoted the same on his drawings of where the new ledger should be tied in, albeit in slightly confusing fashion. these 0.5 x 6.5" Simpson Titen HD concrete screws will thus indeed be going into concrete. ![]() so current status of mountain house projects: Quote:
edit: Aug 12 now confirmed with my hot tub mover guy and the Tabernash-local crane guy. just need to make sure the deck reinforcement work is actually done (by this Thursday!)... I guess they could sneak the final part of work in August 4 - 8 potentially as well and still have Aug 12 be ok. Last edited by shikataganai; 06-17-2024 at 12:39 PM. |
#1455 |
Member#: 92634
RMIC
![]() So it looks like the deck reinforcement work will actually get done today. Which is good since renters check in at 4! I made a run up last night to check on its status and drop off/set some stuff up.
https://www.threads.net/@toshi.clark...FhPqW6_4KwjcrQ Thus we are a go for the August 12 date to relocate the hot tub from here in Denver to up on the reinforced deck. edit: the concrete piers got done in 10" inexplicably. he will redo them in future weeks with 16" as per spec. Last edited by shikataganai; 06-20-2024 at 06:19 PM. |
#1456 |
Member#: 92634
RMIC
![]() ![]() ![]() It has been moved. ![]() Starlink works, too. |
#1457 |
Member#: 203905
![]() Toshi, glad to see you back for a bit. Congrats on the vacation home work. I hope the rental season goes well for you.
#1458 |
Member#: 92634
RMIC
![]() many thank
summer rental season has been good. petering out now as we approach the shoulder season: only a few weekends booked. with updating the listing with Starlink and the hot tub in a bit maybe some more business shall come in. |
#1459 |
Member#: 35824
NWIC
![]() I wanna soak there
#1460 |
Member#: 92634
RMIC
![]() And now the swim spa is in its place in Denver. Cranes are awesome
https://www.threads.net/@toshi.clark...bsSie9UVThU9RA No inline photos because img.nasioc doesn't like modern photo formats Last edited by shikataganai; 08-19-2024 at 06:39 PM. |
#1461 |
Member#: 92634
RMIC
![]() I’m thinking post-snow spring will be the time to have the mountain house repainted from its current salmon-box state. Green main body color, brown accents (doors, window surrounds, the faux beam horizontal element on the sides, masonry below deck), then a dark protective stain on the deck’s wood structure to sort of match.
It won’t be this exactly because it’ll need EIFS-compatible paint. But this is the idea. ![]() ![]() |
#1462 |
Member#: 34631
Vehicle:What day is it? it is... today |
![]() If those are copper awnings that's gonna look great. Is that copper or exposed/finished wood there?
#1463 |
Member#: 92634
RMIC
![]() Not sure where you’re asking about copper. Under deck is pressure treated wood except for the bits of concrete caissons and brick at the bottom few feet. House is EIFS all over the outside. Metal flashing up by roof, underside of eaves is wood.
#1464 |
Member#: 203905
![]() I think he is referring to the eaves which appear to be a dark brown. Copper would be an expensive and odd choice for that area.
Are those colors common in the area? No one wants a house that is drastically different than others around them. |
#1465 |
Member#: 34631
![]() ![]() if copper that alone would be worth more than my house. because I'm homeless!!!! :rimshot: |
#1466 | |
Member#: 52314
South East
![]() Quote:
#1467 |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
![]() ![]() too much brown. I would balance it out with some other color than brown. |
#1468 | ||||
Member#: 92634
RMIC
![]() Quote:
![]() ![]() ![]() Quote:
https://en.wikipedia.org/wiki/Exteri...nishing_system Quote:
![]() (and yes, the right of the two garage doors is smaller than the left. they made a lot of weird choices. ![]() Last edited by shikataganai; 12-06-2024 at 11:07 AM. |
#1469 |
Member#: 203905
![]() I like the green and think you should add some detail above the second floor on the front. Giant flat wall of house 35' tall.
#1470 |
Member#: 92634
RMIC
#1471 |
Member#: 21356
NESIC
#1472 |
Member#: 92634
RMIC
![]() you can, on both sides. left one isn't bad at all. right one is tight and then the wall of the garage is right up against the implied line from the right edge of garage. that spot is not very useful... but then again when we go up we're just up with one car.
#1473 | |
Member#: 92634
RMIC
![]() Quote:
![]() again, I don't see how "salmon faux stucco" was approved as "earthen tone and similar muted colors that blend into the natural surroundings and landscape". |
#1474 | |
Member#: 92634
RMIC
![]() Quote:
I get to figure out garage door repair tomorrow. Springs either broke or are just detensioned due to a renter pulling the emergency release on one of the garage doors, the left normal sized one. And said renters (or the cleaning crew) managed to switch the right garage door’s keypad into the locked mode. so between these things neither garage door could be opened from the outside until I flipped that switch. And thus the trash company driver who picks up trash from within the garage on Fridays could not get in earlier today. Thus a good portion of the garage is now filled with trash from the rental group over Thanksgiving, who managed to create a quite incredible amount of the same. (and due to the left door being the one that is broken I had to wedge the minivan in the small side of the garage at an angle, mirrors folded in and all. It’s very tight.) |
#1475 |
Member#: 92634
RMIC
![]() two updates for you all, surely waiting with bated breath
1) Overhead Door replaced the opener just fine. they haven't billed me for it yet. $1,500 and change from the receipt left at the house by the tech. mountain tax! 2) my snow plow guy/overall handy dude who did the deck reinforcement project finally got around to billing me for the remainder of the deck work--I'd been asking him every month or two but he's not quick on such matters. finally hired an accountant and got around to it. $1,800 more to button up the books, so $16,800 all in. not bad at all, imo. and so far the deck is still standing eh |
