Welcome to the North American Subaru Impreza Owners Club Friday June 20, 2025
Old 06-20-2005, 05:14 PM   #1
mr_yellow
Member#: 39983
2003 WRX Wagon
Default Yet Another "what's wrong with my car" thread
Hey guys,
Forgive me for putting this in the newb forum. I wasn't sure whether this was an engine or transmission issue. Hopefully someone knowledgable will read this and know what I'm talking about...
I picked up a used 03 WRX Wagon 2 months ago and have been loving it since. It's my first manual and first truely fun car to drive.
I've been on the forums to know of a few problems the WRX has had and now that I own one, I wonder whether I'm being affected by some of them now.
basically, in the morning from a cold start, the engine power comes in "pulses". most noticable in first and second gear. At first I thought this was due to weak clutch springs. But why would the problem go away after driving for a while? And if it is, I should get it warrenteed! But i wasn't sure and didn't want to risk getting screwed over by the dealership with a "can't reproduce" slip...
Then I thought maybe it's the hesitation from the poor grounding... But the hestitation is suppose to be a loss of power around 4k rpm... not like this pulsating feeling i get that occurs early in the rpm 1k to 3-4k(I haven't tried it higher, i get afraid and shift to the next gear).
Then I though maybe it was clutch shudder? I had thought that Clutch Shudder was resolved after the 02's and I got an 03.... But Clutch shudder "sounds" much more jarring and rattley. The pulsing I'm getting is like a pulse of power every .5 seconds... And the pulses are smooth and not jarring or rough. makes the engine sound like "whRRRrrRRRrrRRRrrRrr"
Any ideas?
Thanks,
mr_yellow is offline   Reply With Quote
Old 06-21-2005, 12:08 PM   #2
mr_yellow
Member#: 39983
2003 WRX Wagon
Wow.. is this really that unique? Someone must know what this is?
Old 06-21-2005, 12:37 PM   #3
f4phantomii
Member#: 58504
2004 STi
Aspen White / Silver
My STi does the same thing every morning when I pull out of my driveway up through 3rd gear.
I'm not really getting on the power, just accelerating to 25-30mph and holding that in 4th. In 4th I don't get the pulses, but I'm not accelerating either. When I get to the end of my neighborhood about 60 seconds later, it's gone.
But I get the same pulses. I suspect a little more slipping the clutch would smooth it out, but since it goes away so quickly, I don't worry about it.
-Michael
f4phantomii is offline   Reply With Quote
Old 06-21-2005, 01:05 PM   #4
Balr14
Member#: 84809
2005 Forester XT
Pulsing is not uncommon in boxer engines.
Balr14 is offline   Reply With Quote
Old 06-21-2005, 01:12 PM   #5
mr_yellow
Member#: 39983
2003 WRX Wagon
I agree that slipping the clutch a little more will smooth out the power delivery. I recognize that i may be engaging the clutch at too low of an rpm which causes the engine to not be able to keep up with the power.
If this is the case, then It's safe to assume mechanically, the car is fine. Is this what's called "engine bog"?
Old 06-21-2005, 01:19 PM   #6
UM-WRXer
Member#: 44623
To me it sounds like you have an engine management prob. My guess is something to do with openloop/closed loop and cold starts...maybe a faulty iat sensor, i dont know..if it was used when you bought it who knows what has happened in the past.
If this prob only happens when the engine is cold, i dont think it a mechanical prob...
UM-WRXer is offline   Reply With Quote
Old 06-21-2005, 03:12 PM   #7
f4phantomii
Member#: 58504
2004 STi
Yeah....I have read that the Cobb AccessPort help address these issues to some degree as well, especially the rocking and/or surging at very low RPM's.
-Michael
Old 06-22-2005, 10:28 AM   #8
drivin blind
Member#: 73043
2019 STI/370Z/Jeep
Black/Black Cherry/Green
Didn't think they had the open loop/closed loop thing until 04. Mine does the same thing when I first start out cold. Only for a few blocks. I attribute it to a stone cold engine, not my clutch. My .02
drivin blind is offline   Reply With Quote
Old 06-22-2005, 12:54 PM   #9
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
The open/closed loop problem is in the 04's and 05's. I don't think you have a problem. Maybe you're just not used to the power delivery of the car? I take it this is your first turbo? I wouldn't worry.
Acostafan is offline   Reply With Quote
Old 06-22-2005, 01:54 PM   #10
tsubaru02
Member#: 79628
2003 wrx ver 7 swap
mingnight pearl black
let your car warm up before driveing
tsubaru02 is offline   Reply With Quote
Old 06-22-2005, 04:57 PM   #11
mr_yellow
Member#: 39983
2003 WRX Wagon
lol.. yeah, it's my first turbo, plus first manual... so there's a lot of point against me in terms on experience.... I'm just glad i'm not the only one and that it doesn't seem like it's anything serious... Can't wait till i burn through the RE-92s and put on some real summer rubber...
Yet another speed bump with my builder *Rant* akeric Alaskan Impreza Club Forum -- AKIC 12 07-17-2009 10:49 PM
Yet Another "what's wrong with my car" Thread mr_yellow Brakes, Steering & Suspension 21 10-06-2006 03:31 PM
Yet another "should I turn my rotors" thread element533 Brakes, Steering & Suspension 2 01-11-2006 10:43 PM
Another "what's wrong with this picture"... GooseMan Off-Topic 15 11-14-2005 05:38 PM
The "Whats Wrong with My Car" thread Dan_E Normally Aspirated with bolt-on Forced Induction Powertrain 17 01-12-2003 03:45 PM
