Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2024
Old 03-08-2002, 04:36 AM   #1
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
Default who make adj shock for the wrx?
I have a set of whiteline springs and would like to replace my shocks with adjustible ones. I would really like the AGX's but they dont make them yet. What other brands are out there for the car. I had tokico on my integra and wasnt to happy with them. I hope someone has some answers. I really want to put these springs on.
thanks
-nick
Redline8k is offline   Reply With Quote
Old 03-08-2002, 07:05 AM   #2
RawCode
Member#: 3115
2002 Impreza 2.5RS
None out there!
Simple as that..
RawCode
RawCode is offline   Reply With Quote
Old 03-08-2002, 08:59 AM   #3
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
there's the 4 way adj sti ones...but at $1200+ for just struts why not get coilovers?
b_tapper is offline   Reply With Quote
Old 03-08-2002, 09:43 AM   #4
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Um, because they're pink? Perhaps they'll come standard on the "Hello Kitty" edition WRX.
Kevin
gtguy is offline   Reply With Quote
Old 03-08-2002, 10:02 AM   #5
gasman
Member#: 3530
2011 WRX
Default Check out the Leda A's
Redline8k,
Leda offers an adjustable (24 settings) strut for stock sized springs. I belive you can get them from RallyPerformance
There was someone selling a set a while back: Leda A For Sale Thread
Another thread from Ken at RallyPerformance: Leda A available thread
I have not used this setup myself although I am considering the full Leda B coilover option. Hope this helps.
Rob
gasman is offline   Reply With Quote
Old 03-08-2002, 11:35 AM   #6
b_tapper
Member#: 5291
'08 Scion xB
$1000 for 4 struts
i think i'll just put the last gen impreza kyb's on my car, i can live with zipties and the rear camber issue can be fixed
brian
Old 03-08-2002, 10:10 PM   #7
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
how much rear camber is there. Can it be fixed with just a camber bolt.
thanks
-nick
Old 03-09-2002, 06:05 PM   #8
BIGSKYWRX
Member#: 7958
09 GH B+
Camber w/ GC agx's and Eibach springs came in w/ about -3.0 degrees, stock is -1.3. This is from supermarkus. Most camber bolts offer 1-1.5 degrees of adjustment.
Koni evidently has their rear inserts fixed (shortened if I remember correctly) and will be available in April (someone else's post), their front inserts fit fine now.
Big Sky
Old 03-09-2002, 06:09 PM   #9
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Yup, the Koni inserts are great. For $600 all around you can't beat them. They will be correct for the rear in april. Im actually wondering if I should bother or just stay with my current setup (old rear Konis)?
trhoppe is offline   Reply With Quote
Old 03-09-2002, 11:57 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
trthoppe,
Can you access the dampening adj on the Konis easily? Are they on the top of the strut? What settings are you running autox and street?
thanks
Big Sky
Old 03-10-2002, 02:04 AM   #11
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
The front on the Konis is a piece of cake. With the rears, I have the back seatback only bolted in by the center 2 bolts, not the outer 2 bolts. That waY I can unhook it and bend it back to access the rear adjustments.
1 turn on the fronts and full stiff on the back for me.
Old 03-10-2002, 02:15 PM   #12
paultg
Member#: 437
So the adjustment is on the top of the strut for both front and rear? Access to the front top hat through the engine compartment, and for the rear:
Sedan-remove back seat
Wagon-pop off strut top cover???
Just wanted to make sure I understood you.
Paul G.
paultg is offline   Reply With Quote
Old 03-11-2002, 12:00 AM   #13
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
Exactly, except for the sedan you can use the little trick with the back seat.
Who makes turbo kits for the newer body style 2.5 RS? Sugar T General Community 2 11-01-2002 03:55 PM
Who makes a CAI for the WRX? BlazeWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-24-2002 01:52 PM
('93-'01) Who Makes a Supercharger for the 2.5rs? Steven Saunders Impreza Forum 18 05-26-2001 01:29 AM
Who makes coil-overs for the RS/WRX? Stallion WRX Forum Archive 5 02-14-2001 07:25 PM
Who makes aftermarket parts for the new wrx? 8Complex General Forum Archive 9 11-30-2000 09:44 AM
