Tire & Wheel Forum sponsored by The Tire Rack |
11-25-2010, 11:37 AM | #1 |
Member#: 152707
TPMS question
I was about to order some wheels and tires from tire rack for our 2011 Legacy, but decided I better find out about the TPMS first.
It also looks like the dealer will need to reprogram the TPMS module every time I swap wheels? Does that involve unmounting the tires, or is it simply reprogramming the module in the car? Any issues with aftermarket TPMS sensors, like the ones that tire rack sells?
11-25-2010, 06:52 PM | #2 | |
Member#: 3708
Vehicle:2016 RS |
Some kind of reprogramming will be required any time the car isn't seeing the sensors it is expecting. The dealer does it with the wheels on the car via an activation tool and the computer programmer service tool (whatever that thing is called). |
11-25-2010, 08:31 PM | #3 |
Member#: 247574
Vehicle:2013 PBP GV STI 2008 Impreza 2.5i |
The search function is your friend, try it.
For the different sensors, the TPMS module has to be reflashed. You can do it yourself, but you'll need at cheapest (ugitwhutupayfer) $125 Ateq Quickset, and then you will need the CORRECT ID's from the sensors in order for it to work. The best tool for the job is the Bartec Tech400Plus (~$1200) which does it all. Aftermarket sensors do work. I'm using the AirAware sensors on my '10 WRX and they work fine. |
11-25-2010, 08:51 PM | #4 | |
Member#: 152707
Though for the $128 that tire rack is charging for TPMS sensors, I may just forego them all together. Guess I'll have to ask the dealer if they could disable the tire pressure warning light for the winter. |
11-25-2010, 09:00 PM | #5 |
Member#: 247574
The AirAware sensors I bought were less than $50 each, came from Carquest. I don't think "warranty" will cover TPMS reflashes, being that there is nothing broken. You might get a good will a time or two from a dealership. My local dealership charges $45 for each TPMS reflash.
11-26-2010, 12:50 AM | #6 | |
Member#: 152707
As far as the cost, tire rack will be mounting the tires to the wheels, so I have to buy the sensors at the same time unless I want to waste money having someone unmount and remount everything. Also, tire rack is offering all 4 sensors for $128, and even then, the TPMS is bordering on not being worthwhile to me. Thanks for the suggestions though. |
11-26-2010, 01:26 AM | #7 |
Member#: 240161
Vehicle:2002 wrx wagon R.I.P 87 bmw e30, 2013 BRZ |
11-26-2010, 08:52 AM | #8 | |
Member#: 247574
http://forums.nasioc.com/forums/sear...rchid=17350979 |
Similar Threads | ||||
For 08 STI would this fit and TPMS question? | design1stcode2nd | Tire & Wheel | 11 | 12-06-2014 09:27 AM |
TPMS question | eholland | Tire & Wheel | 2 | 02-25-2010 08:54 PM |
TPMS question | captainEJ | Tire & Wheel | 13 | 02-14-2010 05:42 PM |
TPMS Question | engee | Newbies & FAQs | 17 | 11-30-2009 05:45 PM |
TPMS Questions | chanomatik | Alaskan Impreza Club Forum -- AKIC | 18 | 10-29-2009 05:08 PM |
