03-06-2004, 07:29 PM | #1 |
Member#: 49057
Vehicle:2004 STI Black |
want e-mannage what will i need to work on a STI
how has put it on a STI and what harness will i need
if you have it how did u git it from? thanks
03-06-2004, 07:48 PM | #2 |
Member#: 53163
i got it on my car you are going to need an Ignition Harness and Fule injector control harness. I highly recommend using solder when connecting your wires not wire taps as they are not always a good connection. you MUST get the greddy support tool software and the cable can be found for cheap if you look around the internet, you are looking for a USB to serial cable. you need to have the software because the emanage needs to calibrate throttle position in percentage from 0-100%. keep in mind to follow the directions and hook up the wiring so that you have the correct ignition control wires hooked up in the right firing order or you will blow your ignition coils. other than that i am still learning to use the thing even though it is highly simple.
03-06-2004, 08:45 PM | #3 |
Member#: 22760
Vehicle:#54 STR S2000 crazymonkeyracing |
you only need to order the igntion harness. you can use the extra wires in this harness for the injectors. this will save you a few bucks.
make sure you solder the wires. a lot of people have problems becaseu of not soldering then wonder why their car doesnt run. |
03-07-2004, 10:38 AM | #4 |
Member#: 49057
thnks
do is throw a CIL ? |
03-07-2004, 11:54 AM | #5 |
Member#: 22760
no CEL, make sure you update the firmware to 1.36 though.
will 06 legacy block work on 05 sti? | alexkondor | Newbies & FAQs | 2 | 08-12-2009 01:20 PM |
What will I need to swap wrx to 6 speed | subadupa | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 12-03-2008 10:12 AM |
WHat will i need to get 350 to 400hp out of a 2.2t | TURBO KID | Built Motor Discussion | 3 | 03-02-2008 04:10 PM |
help will this off set work on 06 sti | subaru222 | Tire & Wheel | 3 | 07-07-2006 10:33 PM |
what will i need to clear STi brembos behind P1's? | lawn boy | Brakes, Steering & Suspension | 1 | 12-25-2005 01:53 PM |
