07-24-2006, 09:06 PM | #1 |
Member#: 115477
TXIC
Vehicle:2002 Impreza 2.5RS Blue Ridge Pearl |
anybody know where to install the water temp sensor?
07-24-2006, 09:15 PM | #2 | |
Member#: 78739
TXIC
Vehicle:2015 WRX White |
07-24-2006, 09:20 PM | #3 |
Member#: 115477
TXIC
30mm WATER ADAPTER Temp. installs in upper radiator hose 16401630 $28.95
32mm WATER ADAPTER Temp. installs in upper radiator hose 16401632 $28.95 34mm WATER ADAPTER Temp. installs in upper radiator hose 16401634 $28.95 36mm WATER ADAPTER Temp. installs in upper radiator hose 16401636 $28.95 38mm WATER ADAPTER Temp. installs in upper radiator hose 16401638 $28.95 12xP1.25 OIL ADAPTER Temp. replaces oil pan drain plug 16400713 $10.50 14xP1.25 OIL ADAPTER Temp. replaces oil pan drain plug 16400714 $10.50 18xP1.25 OIL ADAPTER Temp. replaces oil pan drain plug 16400721 $10.50 OIL BLOCK ADAPT. UNIV. Temp/Press M20xP1.5-70 & 3/4x16UNF 66&70 12002801 $70.00 which one? |
07-24-2006, 09:51 PM | #4 |
Top Scoob 005
Member#: 58098
TXIC
Vehicle:10.4 @ 137.46mph Cosworth, TSR70, MZM Tune |
I have the one that installs in the upper radiator hose sitting at home, PM me if you're interested.
-D |
Where to hook my Water temp sensor up?? | happy69 | Newbies & FAQs | 4 | 04-03-2007 11:01 PM |
Anybody know where to find the carbon fiber STI rabbit Logo? | jay25RS | Interior & Exterior Modification | 7 | 02-05-2005 12:14 PM |
Where is the water temp. sensor located? | spshultz | Normally Aspirated Powertrain | 2 | 09-06-2001 12:20 PM |
Where to install the Fuel Pressure Sensor? | Sean McElderry | Technical Forum Archive | 2 | 07-12-2000 07:15 AM |
Where to install the Fuel Pressure Sensor? | Sean McElderry | North West Impreza Club Forum -- NWIC | 2 | 07-11-2000 03:52 PM |
