Welcome to the North American Subaru Impreza Owners Club Thursday April 2, 2020
Mid Atlantic Impreza Club
Old 03-21-2015, 10:04 PM   #3101
Smurftastic
Member#: 243697
17.4 PSI ECUtuned 02
BLOD Cofounder|TopScoob31
Two years ago I did a tuck and shave job in the engine bay with all new sheet metal. After two years paint started flaking off the sheet metal... had to strip allllll the paint down, add new filler to smooth out imperfections... and now get to repaint... with the engine still in >
Smurftastic is offline   Reply With Quote
Old 03-22-2015, 06:21 PM   #3102
vadersaysno
Member#: 414300
2011 Impreza 2.5i
Gray
Yesterday I actually placed the order for my Hella Sharptones.
Took the car through the touch less car wash (Shell across from Edison HS). It usually does a nice job, but this time the rear still looks dirty. I'm quite disappointed.
vadersaysno is offline   Reply With Quote
Old 03-22-2015, 09:23 PM   #3103
EvileyeZ88
Member#: 233501
07AD 337/335SAXWAGON
99 outback sport
T6 oil change with oem subaru filter, balanced summer wheels and put those on.
http://www.imgur.com/Br3hG9O.jpeg
EvileyeZ88 is offline   Reply With Quote
Old 03-22-2015, 10:30 PM   #3104
justanotherjeep
Member#: 347956
2012 STI
PBP
After two years of ownership I finally flashed to stage one and installed a Q300 exhaust. I also mounted some Michelin Pilot Super Sports.
justanotherjeep is offline   Reply With Quote
Old 03-23-2015, 02:53 PM   #3105
cagustin
Member#: 298152
2009 Impreza WRX
Satin White Pearl
I finally got back into another Subaru last week, 2009 satin white pearl WRX wagon. I picked up an Accessport v3 this morning!
cagustin is offline   Reply With Quote
Old 03-23-2015, 08:23 PM   #3106
Oaf02Z
Member#: 263219
Jim, let's see them mounted up.
Oaf02Z is offline   Reply With Quote
Old 03-23-2015, 10:46 PM   #3107
EvileyeZ88
Member#: 233501
99 outback sport
Here's a crappy night time picture.
http://www.imgur.com/H5JufYY.jpeg
Had to run a 5mm spacer to clear the brembos up front
http://www.imgur.com/bPGDbIu.jpeg
This would be acceptable if I had sedan front end..
Old 03-23-2015, 11:42 PM   #3108
Oaf02Z
Member#: 263219
Pokeage, what are the wheel and tires specs?
Old 03-24-2015, 12:10 AM   #3109
Red-Rex
Member#: 343261
2012 WRX Hatch
Lightning Red
Did several things today.
Changed Spark plugs
Transmission and Diff service
Hella's
Cobb SF intake and box
Accesport V3 & Stage 1 Tune
CNT Racing Catback
LED Plate bulbs
Grimspeed license plate relocator
Wrx plate delete
Still have a few more parts to put on just ran out of time today
Red-Rex is offline   Reply With Quote
Old 03-24-2015, 06:13 AM   #3110
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Yesterday I journeyed down to AndrewTech for an alignment. Also had the trans and rear diff fluid changed.
RavensFan7 is offline   Reply With Quote
Old 03-24-2015, 10:17 AM   #3111
Mingwhying
Member#: 333675
2009 Impreza WRX
Satin Pearl White
This week i changed the spark plugs and finally got an accessport v3 and sf intake with box! WOOOHOOOOO!!!
Mingwhying is offline   Reply With Quote
Old 03-24-2015, 10:32 AM   #3112
EvileyeZ88
Member#: 233501
99 outback sport
Motegi sp10 18x8 +40 with a 5mm hub centric spacer. Tires are BFG KDW 215/40/18
Fenders are slightly rolled, so I'm not worried about cutting the tires.
http://www.imgur.com/Aw9qpCu.jpeg
http://www.imgur.com/aJwMgNo.jpeg
its not even that wide of a setup, I'm just really limited by the wagon fenders.
Old 03-24-2015, 10:46 AM   #3113
Oaf02Z
Member#: 263219
For 215 looks meaty. Maybe BC of the poke?
Flares coming your way?
Old 03-24-2015, 11:28 AM   #3114
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Looks like he could use just a smidge of extra camber in the front and be ok!
Abnormal is offline   Reply With Quote
Old 03-24-2015, 12:09 PM   #3115
EvileyeZ88
Member#: 233501
99 outback sport
No flares, I'll do STI front end before I do flares.
I'll settle the alignment this week, I ran out of time on sunday, had to unmount 4 tires and then re mount them on my wifes summer wheels, then put them on her car too.
Old 03-24-2015, 12:51 PM   #3116
15WRX_MD
Member#: 404807
2015 WRX
Crystal Black Silica
Default What did you really do to your car today? V3.1
Installed these. I'll post up some pics on the car later.
Should've bought TPMS's. Lights already getting on my nerves.
15WRX_MD is offline   Reply With Quote
Old 03-24-2015, 01:52 PM   #3117
EvileyeZ88
Member#: 233501
99 outback sport
^Put a piece of electrical tape over the light. Problem solved lol.
Old 03-24-2015, 02:18 PM   #3118
Squattro
Member#: 357064
2015 Subaru WRX
GBP
Ha, that's a perfect idea. When I had my winter set on, my seat position and wheel position was perfectly lined up to when I sat normally, I couldn't see the light
Squattro is offline   Reply With Quote
Old 03-24-2015, 05:32 PM   #3119
15WRX_MD
Member#: 404807
2015 WRX
My summer setup until stock rubber is shot. These will become my winter wheels and I'll go for some 18's for summer. 17x8 +45 Rota Titans Hyper Black. God it's good to be back on summer tires...
Old 03-24-2015, 05:39 PM   #3120
15WRX_MD
Member#: 404807
2015 WRX
I like it! The '15s not only give you a light but every time you start the car it gives the warning chime, the TPMS light flashes for a few minutes then stays lit and the yellow "I" indicator by the odometer stays lit. For some reason just a simple light did not suffice.
Old 03-25-2015, 09:51 AM   #3121
idrivea911
Member#: 380935
2006 Saab 9-2x Aero
Thanks, Obama!
idrivea911 is offline   Reply With Quote
Old 03-25-2015, 10:06 AM   #3122
ThatGy
Member#: 137791
2002 Impreza WRX
WR Blue
Here's a crazy idea, get more TPMS sensors for your other wheels.
ThatGy is offline   Reply With Quote
Old 03-25-2015, 11:12 AM   #3123
acumenhokie
Member#: 271479
2010 LGT
2009 FXT
acumenhokie is offline   Reply With Quote
Old 03-25-2015, 02:30 PM   #3124
rtpurdum
Member#: 392146
2011 WRX Hatch
Oh nooooo. Looks like the one that came out of my 04 wrx. Shambles! Sorry to see that
rtpurdum is offline   Reply With Quote
Old 03-25-2015, 02:49 PM   #3125
acumenhokie
Member#: 271479
2010 LGT
2009 FXT
Weak a55 split case PoS.
Too bad I have a total of 0 upgrade options without fabrication. ****!
