Welcome to the North American Subaru Impreza Owners Club Thursday December 8, 2022
Old 04-29-2014, 03:02 AM   #1
SteamSpeed.com
Member#: 339860
Default Steam Turbocharger Performance Results!
We thought that we would start a new thread for our Steam Turbochargers. There has been quite a bit of positive feedback from our customers and we want to provide a place where people can come to get an idea of the performance people are getting from the Steam STX 67, STX 71, or the STX 20G-R.
Post everything you have here: dyno plots, build specifics, etc. Don't be shy. There is lots to share and lots to learn. Perhaps your posting will help someone else or lead to tips from others! You don't need to be producing over 500whp to post here. Some will be interested more in spool characteristics than they will top end power. Others will want to see that peak power. Bring it all. Specifically, be sure to post the following:
Turbo model, dyno plot, supporting mods, etc. With the variety that is out there, this is sure to be interesting.
SteamSpeed.com is offline   Reply With Quote
Old 04-29-2014, 03:14 AM   #2
SteamSpeed.com
Member#: 339860
Default Stx 71
Initial dyno results of the TD06SL2+3071:
Originally Posted by xluben View Post
Here's the plot of my new setup (2.5L, 6MT, TD06SL2-5371 @25psi peak, tapering to 22psi on E85):
Top end feels strong and the plot agrees with this. Load is steady up top even though boost drops off. Car pulls hard all the way to 7k. Could try revving it further but haven't done that yet. Spool is not super early, but that is expected with cams and non-AVCS. Power comes on by around 4k so it is still a solid 3k of usable powerband.
Below is a comparison to the 2.0L with TD04 and VF39. Overall shape of the curve is similar with the larger turbo and larger motor, but the power is much higher. Little to nothing is lost on the low end of the powerband so it still feels fairly good around town but now it really takes off once you get the rev's into the 3k-4k range and above.
Full Build Info:
http://forums.nasioc.com/forums/show....php?t=2528768
Engine:
  • OEM 2012 STI 2.5L Case
  • OEM 2012 STI Heads
  • OEM STI Nitrided Crank
  • OEM STI 11mm Oil Pump
  • OEM STI Gasket Set
  • CP 99.75mm 8.2:1 Pistons
  • Manley Turbo Tuff I Beam Rods
  • ACL Rod and Main Bearings
  • ARP Head Studs
  • GSC S1 Camshafts
  • GSC Beehive Springs w/Retainers
  • GSC Valve Seals
  • Torque Solution Motor Mounts
Intake/Exhaust/Fuel:
  • GrimmSpeed CrossPipe
  • GrimmSpeed Uppipe
  • GrimmSpeed Downpipe
  • Perrin CatBack Exhaust
  • TD06SL2-5371 Turbo
  • GrimmSpeed Gaskets
  • GrimmSpeed TMIC w/Gold Tape
  • GrimmSpeed TMIC Splitter
  • GrimmSpeed Y-Pipe Kit
  • GrimmSpeed MBC
  • 04 STI Fuel Pump Hanger
  • Walbro 255 Fuel Pump
  • ID2000cc Injectors
  • TurboSmart FPR
Drivetrain/Transmission
  • OEM 2012 STI 6MT
  • OEM 2004 STI Driveshaft
  • OEM STI R180 Rear Diff Flange
  • Anarchy Motive Shift Knob
  • Kartboy Short Shifter
  • Kartboy Front Shifter Bushings
  • Karboy Rear Shifter Bushings
  • Torque Solution Tranny Mount
  • Torque Solution Pitch Stop Mount
  • ACT HD Pressure Plate
  • ACT 4 Puck Unsprung Disk
Suspension/Wheels:
  • OEM 2002 WRX Wheels
  • 04 STI Struts
  • 04 STI Springs
Interior/Electronics:
  • MapDCCD
  • VSSPro
  • ProSport EVO Boost Gauge
  • ProSport EVO Oil Pressure Gauge
  • AEM Wideband O2 Gauge
  • Odyssey Slim Battery
Old 04-29-2014, 03:30 AM   #3
SteamSpeed.com
Member#: 339860
Default vf35 vs STX67 - injector duty cycle maxed and maf maxed
Originally Posted by magnet89 View Post
Something to share. VD graph comparison of my old vf35 vs the STX67 on EJ207 UK type. Note that this is just the turbo that has changed. My maf was maxed out and injectors has reached more than 100% duty cycle. I'll post the graph again once i get it tuned with bigger injectors and maf.
https://www.dropbox.com/s/tli5wrgsqd...vs%20stx67.jpg
Old 04-29-2014, 03:37 AM   #4
SteamSpeed.com
Member#: 339860
Default STX 67 Tuned
Another STX 67 result
Originally Posted by bl0wnb0xerbabiE View Post
So here is my dyno graph. The numbers pictured are from the dynojet, 418whp! My tuner Ed at Eq tuning and the installers were amazed at how much this thing made on pump piss Cali 91 octane.
He said that with similar set ups and turbos, he usually only sees 330whp at most on pump gas. The mustang dyno numbers are 354whp and 337lb-ft torque. I will post a more detailed write up on the appropriate thread.
Old 04-29-2014, 10:02 AM   #5
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx3
Very Nice, Ill post up graphs of the STX67 soon. Prob get back on the dyno in a week or so.
rexworx is offline   Reply With Quote
Old 04-29-2014, 11:09 AM   #6
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
How many of these turbo's are out there? Only 3 results so far?
I think getting it into a list format like this will be useful for comparisons:
Kinugawa Results List:
WHP / WTQ | 1/4 @ MPH | TURBO @ PSI | FUEL | VEHICLE | USERNAME | LINK
434 / 408 | XX.X @ XXX | TD06H 60-1 @ 24psi | 93 | 2006 STI | STi MAN86 | LINK
427 / 413 | XX.X @ XXX | TD06SL2-5371 @ 25psi | E85 | 2002 WRX | xluben | LINK
415 / 425 | XX.X @ XXX | TD06SL2 20G @ 21psi | 93 | 2009 WRX | 20wrx09 | LINK
398 / 388 | XX.X @ XXX | TD06H 20G @ 25psi | Meth | 2004 WRX | mod maniac | LINK
390 / 404 | XX.X @ XXX | TD05H 20G @ 20psi | E85 | 2007 STI | *Ulimited* | LINK
387 / 379 | XX.X @ XXX | TD05H 20G @ 24psi | Meth | 2003 STI | bhpsti | LINK
380 / 390 | XX.X @ XXX | TD05H 20G @ 20psi | 93 | 2007 STI | *Ulimited* | LINK
377 / 374 | 11.7 @ 116 | TD06SL2 20G @ 25psi | E85 | 99 Impreza | Fuji K | LINK
370 / 381 | XX.X @ XXX | TD06SL2 20G @ 19psi | 93 | 2011 WRX | ResidentR | LINK
370 / 370 | XX.X @ XXX | TD05H 18G @ ??psi | ?? | 2007 WRX | RallyImprezive | LINK
357 / 317 | XX.X @ XXX | TD06H 20G @ 27psi | 93 | 2003 STI | ElSpa | LINK
349 / 349 | XX.X @ XXX | TD06SL2 20G @ 19psi | 93 | 2006 STI | powerls | LINK
340 / 351 | XX.X @ XXX | TD05H 20G @ 19psi | 93 | 2013 WRX | Silviaspeck | LINK
324 / 332 | XX.X @ XXX | TD05H 18G @ 18psi | E50 | 2006 WRX | Ferraz | LINK
317 / 344 | XX.X @ XXX | TD06SL2 18G @ 19psi | 92 | 2006 WRX | drmichael | LINK
307 / 333 | XX.X @ XXX | TD05H 16G @ 22psi | 93 | 2008 WRX | chemtek| LINK
xluben is offline   Reply With Quote
Old 05-04-2014, 09:32 PM   #7
OBP WRX
Member#: 330185
subscribed
OBP WRX is offline   Reply With Quote
Old 05-08-2014, 03:40 PM   #8
Beard_Of_Moses
Member#: 316926
2004 wrx wagon
Default Steam STX67
Got the car tuned yesterday with the STX67. Stock EJ205. Other mods include TMIC, Turboback, Intake and Hybrid Boost control.
Event: Dyno Tune
Ambient Temp: Unknown
Elevation:3,438 ft
Weather: Tuned indoors, but cloudy and warm
Tires: 225/45/r17
Car: 2004 WRX
Tuner: Sunny
Dyno Info: Dyno Dynamics
Transmission: 5 Speed, Factory gearset
Gear: Unknown, assuming 3rd
Peak HP at RPM: 293.3
Peak Torque at RPM: ~270
Baseline hp/tq for a stock on same dyno: 175.7/220 ON a stock 2.5L 2006 WRX
Target Boost: 20psi
Target AFR: unknown
Fuel: 94 unleaded
Engine/Power Modifications: Steam STX67, I.D. 1000cc injectors, Walbro 255 fuel pump, Perrin catted 3" downpipe, Supersprint 2.5" Catback, Grimmspeed Uppipe, Mishimoto TMIC, Hybrid boost control with Cobb EBCS and Grimmspeed MBC, Cobb SF Intake and Box, Cobb After Maf hose, Perrin 2.4" Turbo inlet
Driveline Modifications: Cusco motor and tranny mounts, Whiteline transmission bushings, Kartboy diff outrigger bushings (comfort).
Suspension Modifications: KYB Exel-g struts, stock height King springs, Eibach Rear sway bar and Kartboy endlinks.
Other Modifications: 17x7.5 Enkei RPF1
Beard_Of_Moses is offline   Reply With Quote
Old 05-08-2014, 04:59 PM   #9
Delphi
Member#: 239335
2011 WRX
Stock block?
Edit: Nvm I am blind and should be lashed lol.
Delphi is offline   Reply With Quote
Old 05-12-2014, 12:57 PM   #10
Scooby921
Merci Buckets
Member#: 88606
2018 Grand Cherokee
Velvet Red Pearl
It would be appreciated if you guys could follow the standard PPB format outlined in the link below. Results are more useful if all the background information is available.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 05-12-2014, 02:34 PM   #11
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Event: Dyno Tune
Elevation:3,438 ft
Tires: 225/45/r17
Car: 2004 WRX
Tuner: Sunny
Target Boost: 20psi
Target AFR: unknown
Fuel: 94 unleaded
Where does she spool on the street?
Subian is offline   Reply With Quote
Old 05-13-2014, 05:41 PM   #12
rmommandi
Member#: 335230
Got my PPB post up! Car is tuned and boosting.
http://forums.nasioc.com/forums/show...3#post41943913
rmommandi is offline   Reply With Quote
Old 05-13-2014, 06:15 PM   #13
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
It's all lies. They ain't making that power cause I ain't making that power!
I really hate that format. That's all I gotta say about that.
FuJi K is offline   Reply With Quote
Old 05-14-2014, 02:52 AM   #14
SteamSpeed.com
Member#: 339860
Default rmommandi's results with Steam STX 20G-R
Event: dyno pull
Ambient Temp: 50 degrees
Elevation: 5,000ft
Weather: sunny
Tires: 225/45r18 Nankangs
Car: 2006 WRX TR
Tuner: Harvey Epstein
Dyno Info: Dyno Dynamics Dynamometer
Transmission: 5spd stock
Gear: 3rd
Peak HP at RPM: 375.7 ~6000RPM
Peak Torque at RPM: ~345 5000RPM
Baseline hp/tq for a stock on same dyno: Stock wrx puts down about 200 (need confirmation on that)
Target Boost: 21psi
Target AFR:
Fuel: pump gas, 91octane
Driveline Modifications: ACT heavy duty street clutch and lightened flywheel.
Suspension Modifications: Greddy Type-R coilovers, other small suspension mods.
Other Modifications: 18x9.5 RPF1s, Lightweight crank pulley, ID1000, Walbro 255lph fuel pump, Gimmick Motorsport FMIC (turboxs replica) Grimmspeed EBCS, Grimmspeed Uppipe, Tial 44mm EWG, K&N Typhoon intake, Helix Catted DP, Invidia g200 Catback, COBB AP….. pulling a blank on other stuff, if I recall ill update.
Harvey has seen it all and was impressed by this turbo! said it could make nasty power on a built motor and e85, I'm working on that.
Shoutout to the guys at Steamspeed for answering all my questions when they popped up and for making a nasty friggin turbo!
[/quote]
Old 05-17-2014, 10:46 PM   #15
SteamSpeed.com
Member#: 339860
Hi NASIOC,
We finished building our JB STX 76 prototype. It is designed to satisfy those trying to hit the 450-500 whp with a stock location turbo. It is based off of a GTX3076R compressor wheel with a TD06SL2 9-blade turbine. We designed a new compressor 3" anti-surge housing that is compact enough to really be stock location.
Here is the GTX3076R compressor map. FYI: with the JB center vs the BB center as Garrett testing their turbo, there will be some differences. The surgeline at higher boost may shift more to the right, and the JB turbo will be less efficient at higher back pressure rations.
PM us if you have a built motor and are interested in testing our STX 76 prototype.
Thanks,
Sam
Old 05-18-2014, 12:05 AM   #16
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
Sam:
That being said, what is the expected power of the STX-71 then?
What loses do you see using the JB over the BB
The specs for the STX-76 still stand?
CmpInd/CmpExd: 58/76.6
TrbInd/TrbExd: 61/54.10
west_minist is offline   Reply With Quote
Old 05-19-2014, 01:04 AM   #17
SteamSpeed.com
Member#: 339860
Originally Posted by west_minist View Post
Sam:
Yes, those specs are correct.
It should be able to make the same peak power. The compressor wheel can flow what it can flow irrespective of the JB vs BB center. If you have a well designed intake, exhaust, etc., I think there won't be much lost JB vs BB. If you have say a lot of back pressure, the BB turbo version will be more efficient. That is all.
Thanks,
Sam
Old 05-20-2014, 01:43 AM   #18
SteamSpeed.com
Member#: 339860
A couple months ago, some of you may recall that we announced we were working on a new prototype turbocharger. Below you will see that turbocharger; the Steam STX 76 a journal bearing 76mm turbocharger mated to a lightweight 9-blade turbine wheel with a 3" inlet. We will keep you posted when we have dyno results.
Steam STX 76 is on the left A stock TD04H on the right.
The rest of the images can be seen HERE
Old 05-21-2014, 07:41 AM   #19
SteamSpeed.com
Member#: 339860
Did you tuner have any feedback? I wonder if the exhaust was being restrictive...
Old 05-21-2014, 07:54 AM   #20
alexandern05
Member#: 266954
04 wrx v7 sti swap
agile tuned 389hp 342ftlb
If your still looking for someone to test out the new Turbo pm me
alexandern05 is offline   Reply With Quote
Old 05-21-2014, 08:05 AM   #21
SteamSpeed.com
Member#: 339860
We a few interested parties. Please PM us with the details of your car and the time frame in which you can get some results up. We are expecting some big numbers with this turbo and would feel bad if it broke someone's stock block.
Old 05-21-2014, 08:11 AM   #22
SteamSpeed.com
Member#: 339860
Default 06 2.5l WRX + Steamspeed Hybrid STX td05h-GTX2867 (Garrett) - 416whp/399lb-ft
See the full thread at http://forums.nasioc.com/forums/show...4#post41852964
Check out Ed's @ Equilibrium Tuning feedback in posts: 2, 18, 20
Event: Custom Dyno tune
Ambient Temp: 74 degrees Fahrenheit
Elevation: 100 ft above sea level
Weather: Blue and Clear
Tires: Dunlop Sport Maxx 225/45/17
Car: 2006 Subaru WRX
Tuner: Ed at Equilibrium Tuning
Dyno Info: Graphs for both Dynojet and Mustang below
Transmission: Stock 5 speed
Gear: 3rd
Peak HP at RPM: 416.6 whp at 6600rpm SAE corrected
Peak Torque at RPM: 399.6 lb-ft at 4050rpm SAE corrected
Baseline hp/tq for a stock on same dyno: Stock STI runs 210-220whp on the mustang dyno
Target Boost: 19 psi
Target AFR: 10.7
Fuel: Piss poor Cali 91 octane
- Steamspeed's hybrid STX td05h-Garrett GTX 2867 journal bearing turbo - 8cm housing w/ 2.4 inch inlet - ported turbine and wastegate - IWG - Billet 11 blade compressor wheel and lightweight 9-blade turbine wheel
- KS tech 73mm CAI
- Walbro 255h fuel pump
- Greddy Evo catback exhaust
- Invidia 3 inch catless downpipe w/ DEI titanium wrap with high temp silicone coating
- Unknown brand uppipe w/ DEI titanium wrap with high temp silicone coating
- Tomei UEL
- PTP Turbo blanket
- Cusco heatshield
- Motive Autowerks TGV deletes
- Hallman Pro MBC
- Ebay BIG TMIC
- Block off plates
- Air pump delete
- Grimmspeed turbo inlet
- DW 850cc injectors
- ACT heavy duty clutch
- Streelight flywheel
- Perrin lightened crank pulley
- Kartboy short shifter
- Kartboy shifter bushings
Suspension and other modifications:
- Whiteline front fixed swaybar
- Whiteline rear adjustable swaybar
- Helix endlinks
- Hawk HPS brake pads
- Eibach Camber bolts
- STI rear strut tower bar
- STI powder coated black BBS rims 17 x 7.5
- Tein H tech springs
- aftermarket shocks
- Group N front tophats
- Greddy turbo timer
- Greddy shift knob
- STRI boost and oil pressure gauges
Soon to be...
- Grimmspeed TMIC splitter and shroud
- DEI Reflect-A-Gold wrap on heatshields, TMIC, and intake
- Hot coat UEL headers
- then maybe exterior mods yada yada..
Big thanks to Ed @ Eqtuning for a great tune. Him and his team were amazed and completely surprised at the power output of this turbo. We were originally going to go with the AEM CAI but the turbo was maxing out the MAF readings so we had to go with the KStech big maf intake. We also had to go with a slightly softer wastegate spring. Money well spent and the car pulls like a champ, especially up top.
I would have liked to have seen slightly faster spoolup but the amount of power mid to high more than makes up for it. The current wastegate seems to hit 18 psi and slowwwllllyyy get up to 19 psi. Ed believes that with an EWG, this turbo would "shiiinnnee." Our power expectations were surpassed and then some. I highly recommend this turbo (Garrett GTX compressor) to anyone looking for 20g typer power levels.
Below is the Dynojet graph:
And the more realistic Mustang dyno numbers:
Old 05-21-2014, 12:32 PM   #23
alexandern05
Member#: 266954
04 wrx v7 sti swap
Pm sent about testing your new Turbo.
Old 05-30-2014, 04:24 PM   #24
SteamSpeed.com
Member#: 339860
Here's the Steam STX 20G-R on 91 octane at 5000ft - 375whp @ 20psi.
TheBoostCreep Steam STX 20G-R tune
Old 06-09-2014, 12:34 AM   #25
wrxlove07
Member#: 236953
2002 Wrx aka Victori
Default 408/408
Event: 3rd gear pull
Ambient Temp: 88*F
Elevation: ~200
Weather:Cloudy/humid
Track and Conditions: asphalt highway, flat
Tires: 225s
Car: 2007 STi
Tuner: Myself (Roy)
Dyno Info: Airboy's Spreadsheet
Transmission:6 speed
Gear: 3rd
Peak HP at RPM: 408
Peak Torque at RPM: 408 - Smoothing 6
Baseline hp/tq for a stock on same dyno: ?
Target Boost: 24- EWG spring pressure
Target AFR: 11.2
Fuel: 93 Oct
SteamSpeed STX71
EJ257 w/Cosworth Pistons
Supertech valvetrain
Stock cams
Composite TGVs
DW 850cc
Aeromotive 340 pump
AP Fuel rails
Killer B Holy Header
Tial 38mm EWG
3" TBE
Grimmspeed TMIC
KSTech 83mm CAI
Driveline Modifications: Exedy twin disc clutch, Kartboy pitchstop, Group N Motor/Tranny mounts,
Suspension Modifications: ProDrive springs, stock everything else
Other Modifications: Lots of love
Pretty happy with the initial tune, pulls hard all the way to redline.
Running 11* timing at peak torque, 20* at redline. 24lbs boost
wrxlove07 is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
