Welcome to the North American Subaru Impreza Owners Club Sunday October 20, 2019
Old 04-10-2017, 10:05 AM   #426
ALOKIN
Member#: 348177
2002 Bugeye
Haltech GTX3584RS
Get viton orings
ALOKIN is offline   Reply With Quote
Old 04-10-2017, 10:45 AM   #427
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
Originally Posted by ALOKIN View Post
Get viton orings
Where would I put the o rings?
ZTruitt7 is offline   Reply With Quote
Old 04-10-2017, 11:46 AM   #428
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
Yours looks to be a different design than mine. My 2011 the fuel pump snaps into a housing that has a filter inside of it. The pressure seal from the factory comes with one oring and a spacer. Yours seems to attach with a hose. There shouldn't be any leaking problems as long at that hose doesn't come off and is nice and tight. I'm guessing the other end of the hose connects up to the port going out of the tank. Looks like yours does not have any orings. I could be wrong. Maybe others may know better.
sub2010ss is offline   Reply With Quote
Old 04-10-2017, 11:53 AM   #429
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
Did you install the original pump? If so did you change how it's connected to the fuel lines? When I look up a 2009 STI it shows the same set up as mine which sure doesn't look like the picture you got. You can see the spacer and oring in the diagram.
Old 04-10-2017, 12:45 PM   #430
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
Wow yeah when I bought the car it already had a walbro 255 in it. So whoever installed it definitely changed something. Well that's awesome, no idea how I'm going to go about this now. The pump in the picture I posted is the aeromotive 340. Which I'm replacing with a walbro 450, since the 340 isn't working right.
Old 04-10-2017, 12:58 PM   #431
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
I wonder why they would've installed the hose like they did? It's more a pain than anything. When I install the pump into the car, the housing compresses and the hose is between it. When I first installed the 340 I did a pull and was losing fuel pressure. That hose was smashed between the housing, I have it now so it isn't as bad. Maybe I should just take the hose off and run it like it should be in the diagram?
Old 04-10-2017, 01:26 PM   #432
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
I'm not sure why they would have changed it. But to revert it back to factory would take a bit, especially considering you don't know what all they did to it. My advice, pick a used housing up off of eBay. Or try your new pump with however they have it installed.
Old 04-10-2017, 01:31 PM   #433
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
Alright I'll try the new pump and see what happens, if not I'll just get a used housing. Did you hardwire yours?
Old 04-10-2017, 02:10 PM   #434
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
I sure did. My turns on when the key is on and doesn't stop till the key is off. That's why I originally questioned your suspected problem. Once hardwire does, the pump will run at max mean maximum fuel pressure regulated by the fuel pressure regulator. Even if it's bleeding down when the pump is off, it shouldn't be an issue once the pump is on. If it is, I don't think it would run at all.
Old 04-10-2017, 02:55 PM   #435
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
That's exactly how I have mine hardwired! So I'm still trying to think if it's just fuel related. It didn't start acting like this until after I installed the 340. I don't think it's the fact it's hardwired. I mean I can hear the pump running when I turn the key up, it's obviously working. For me to have to crank it a couple times to start, sounds like it's just losing pressure.
Old 04-10-2017, 04:21 PM   #436
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
It's definitely hard to say not knowing your fuel pressure. One of the best things I like about the Cobb ap and flex fuel is I can monitor fuel pressure differential. Difference between actual fuel pressure and boost pressure. There's also a compensation feature. It'll tell me if the ap is adjust because fuel pressure isn't holding. Pretty slick ****.
Old 04-10-2017, 04:41 PM   #437
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
Well fuel pressure at idle was where it should be. I hooked an inline fp gauge and went and did some pulls. When I would go into boost the pressure would drop to like 15. So I know it's the 340. When I called aeromotive to say I wanted to return it, I was told that's not surprising. They said those pumps suck lol so hopefully when I install the 450 everything goes right.
Old 04-10-2017, 04:42 PM   #438
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
Yeah where I live there is no e85 near me. The Cobb flex fuel would be nice, I'll eventually buy an ap. Once my car is running like it should.
Old 04-10-2017, 04:44 PM   #439
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
Yeah dropping is definitely bad. It should rise proportionate to boost.
Old 04-10-2017, 04:47 PM   #440
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
Exactly so I'm returning the 340, just need to install the 450. It made 398awhp and the pump wasn't flowing right. So the new pump hopefully will work right.
Old 04-10-2017, 05:43 PM   #441
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
That's definitely good power for not being on ethanol. I'm would imagine the 340 should have had enough to keep you there especially hard wired. Hopefully the new pump fixes it up for you. Fuel problems can be very frustrating. One last thing I was thinking about. Do you have an aftermarket fuel pressure regulator? If so, where do you have it adjusted? I know once I went hardwired, the fuel pump can overcome the return lines and fuel pressure is about 10psi higher at idle than it is once the engine starts consuming enough to make up for the restrictions.
Old 04-10-2017, 06:32 PM   #442
ZTruitt7
Member#: 450157
2009 Sti hatch
IG- ztruitt7
Yeah I'm hoping for around 420awhp when it's done! It should be a blast to drive lol and yes I have an aeromotive fpr. After I hardwired it I adjusted it to where it should be, around 43 psi. Did you bypass your fpc as well?
Old 04-10-2017, 07:31 PM   #443
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
That could be your problem then. If you adjust pressure with 100% flow at an idle to a baseline of 43#, your fuel pressure is going to drop once the engine starts eating up that fuel. I'd try a baseline of 50-55# at an idle with the vacuum line off. Once you're wot you should be about 45# above boost pressure. And yes, my controller is completely out of the picture.
Old 04-11-2017, 02:26 AM   #444
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
With a properly sized fuel pressure regulator 43 psi base pressure at idle should be 43 psi at 100% duty cycle as long as the pump can keep up. Running 55 at idle expecting it to decay to 43 psi at redline is AFU. If that's what you need to do for your system you should try a fuel pressure regulator with a bigger flow co-efficient(Cv). I've never found that necessary with only one 340 L/h pump though.
Old 04-11-2017, 08:51 AM   #445
sub2010ss
Member#: 448862
2011 WRX
Dark Gray Metalic
Maybe the older ones are different, take a look at the diagram above. There's a jet pump assembly in our fuel canisters that sucks fuel from one side of the tank to the other. The restriction is not inside of the fuel pressure regulator, it's the return to the tank. I agree that running like I'm running isn't the most preferred method, but my car runs this way, runs good this way, and has been doing it for 3000 miles with good fuel mixtures. Also, it has to be considered when tuning the car. Lastly, I'm not the first or that last to run this way, there are plenty of people doing it. The only way around it is to use the fuel pump controller with pump duty cycle or change you fuel pump assembly to reduce the restriction of the jet pump by either modifying it or going with an aftermarket assembly. $$$$
Old 04-22-2017, 10:50 PM   #446
WhatTurboLag?
Member#: 243992
2006 WRX TR
So I just wired my 450.
I did my connections at the FPC mini harness (incase I ****ed up I could just buy a new harness.
Key in the run position the pump pulls, and keeps pulling. No "prime". Will try to figure this out later but for now it's okay.
I used the FP+ wire on the fuel pump controller for the signal.
- from the pump to chassis
and I disconnected the negative fuel pump wire on the FPC entirely. Now, My fuel gauge isn't working at all, but it may be because the engine is out of the car maybe? I'm not sure. I was a little paranoid about having two open connections inside the fuel tank (a positive and a negative pin inside the tank where the old fuel pump wires were)
I will revisit that issue once the engine is in the car. No clue if I have any codes yet since the engine isn't in I didn't check lol
WhatTurboLag? is offline   Reply With Quote
Old 05-09-2017, 08:32 AM   #447
CTSparky
Member#: 282204
2011 5 Door STi
Plasma Blue Pearl
For those of you that have bypassed or eliminated the control module... have you gone through any pumps? If so around how many Hours of use/ or miles?
I'm curious to hear about aftermarket pumps failing due to being run at full duty cycle for lengths of time.
CTSparky is offline   Reply With Quote
Old 05-16-2017, 02:08 PM   #448
Zumiez87
Member#: 206481
2013 WRX STI
So I hardwired my fuel pump on my 13 STI and it runs constantly, doesn't prime then shut off. I saw someone else had the same issue but didn't get a response. I'm using the green and yellow wire and the green and red wire. Any ideas? Help would be greatly appreciated!!
Zumiez87 is offline   Reply With Quote
Old 05-17-2017, 01:09 PM   #449
Zumiez87
Member#: 206481
2013 WRX STI
Hey did you figure this out at all?
Old 05-17-2017, 04:30 PM   #450
Zumiez87
Member#: 206481
2013 WRX STI
Got it! On my 13 STI, in the fuel pump harness. Cut green/yellow. Yellow wire from hardwire kit goes to connector side, and blue wire from hardwire kit goes to harness side. Then just run power and ground for the relay as usual. Now pump turns on, primes, shuts off. Like normal.
