10-13-2009, 12:23 AM | #1 |
Member#: 210923
South East
Vehicle:2002 Bug-Attack 15 slow STI |
can i get a list on how to convert my sidefeed to topfeed
hi
i want to do this to install bigger injectors if there is diy please post the link i didnt find if not i just want a list of parts i'll need for this project thanks
10-13-2009, 02:04 AM | #2 |
Member#: 180038
NWIC
Vehicle:IB You dont even own a subaru! |
searched a little bit and couldnt find the answer, is it just swapping TGV's or does it require fuel rails as well?
10-13-2009, 02:51 AM | #3 |
Member#: 102808
Vehicle:1995 Built EJ207 6sp 30r ***break in*** |
http://forums.nasioc.com/forums/showthread.php?t=533787
Is there anything to be careful about when buying TGV Deletes or using a TGV Delete service? WRX and STI TGVs are not interchangable, so you must state your year/model car with the Vendor to ensure you get the right kind as the JDM TGV varieties are complicated. For the US varieties: 2007+ STI are topfeed 2004-2006 STI are sidefeed 2002+ WRX are topfeed Yes you can convert your car from top to sidefeed or vice versa, but unless you want the additional time/trouble/expense, it's best to get the right TGVs in the first place. Top or side feed refers to the injector type/seating surface as they are different as are the associated fuel rails. So you must use all the components of either type if swapping TGV styles. |
10-13-2009, 03:12 AM | #4 |
Member#: 180038
NWIC
but is that the list? is the list:
07+ fuel rail, or aftermarket topfeed fuel rail and topfeed TGV's and topfeed injectors? just those three? |
10-13-2009, 03:51 AM | #5 |
Member#: 102808
10-13-2009, 08:37 AM | #6 |
Member#: 78165
South East
Vehicle:05 STI 35r + e85 |
You also need a topfeed FPR. Perfect time to switch to an aftermarket unit.
10-13-2009, 09:50 AM | #7 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
Top Feed Fuel Rail (with Fuel Pressure Regulator)
Top Feed TGVs Top Feed Injectors Top Feed Injector Clips. Tune! |
10-13-2009, 09:59 AM | #8 |
Member#: 78165
South East
I used Grimmspeed pnp top-feed TGV deletes, DW1100 injectors, Perrin top-feed fuel rails, and I got the side-feed fuel distribution block from Perrin so I could use an aftermarket FPR (Aeromotive A1000-6).
10-13-2009, 11:18 AM | #9 |
Member#: 210923
South East
jay im a fan of your car ^^^
youyube king |
11-01-2009, 10:54 AM | #10 |
Member#: 147346
TXIC
Vehicle:04 Need help! Installing injectors! $$$ |
Where did you get the correct connectors? Or did the side feed connectors fit your top feed injectors without modification?
11-01-2009, 12:18 PM | #11 | |
Member#: 108089
If you have a junkyard near by, look for some subaru topfeed ones (even from the older imprezas and legacys and such) Just remove the clips from the pins, and put them on yours, done. |
11-01-2009, 01:47 PM | #12 |
Member#: 144670
RMIC
Vehicle:05 WRB STi 11 SWP limited STi |
I have an 05 STi this is the list i did to convert mine to top feed
02-03 grimmspeed TGV deletes DW 1150cc injectors (top feeds) Agency power top feed fuel rails with the side feed fuel distribution block so i can use my stock FP and dont have to buy an aftermarket one and fittings And 03 wrx injector connectors Last edited by osirissirhc; 11-01-2009 at 01:54 PM. |
How to convince my girl to get the Scion Tc | tommy2hotty | Off-Topic | 47 | 08-17-2004 04:39 PM |
can someone list all the parts I need to convert my auto tranny to manual | starBug | Transmission (AT/MT) & Driveline | 3 | 07-14-2004 08:27 PM |
Where can I get complete listing of WRX part numbers? | igalwrx | Service & Maintenance | 5 | 05-08-2004 10:56 PM |
How can I get lap time on a track "LimeRock". | WRX2ME | New England Impreza Club Forum -- NESIC | 2 | 09-05-2001 10:55 PM |
