Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Old 11-13-2017, 06:43 AM   #7076
krzyss
Member#: 8365
2013 Ford Focus SE
Guys/gals
Put these in order of importance:
ice, snow, dry, wet, noise, maybe even add slush
Krzys
PS Listing your OE tire size helps as not everybody is fluent with all available options.
PS2 Is OE size for 2018 WRX STI 235/35R19? It seems that 17" will fit so by down sizing -2 one can save enough money for tire/wheel combo instead of OE tires only.
krzyss is offline   Reply With Quote
Old 11-13-2017, 12:53 PM   #7077
GodWhomIsMike
Member#: 102287
2016 Crosstrek Ltd.
Hyper Blue
In case anyone here is curious. I got a set of Blizzak WS-80 snowtires (16" mounted on steelies) back in November 2014. I am going to be installing them back on next Friday. When I took them off in early April, the mechanic inspected them and stated two seasons left on them, maybe 1 if it is a very warm winter this year. I'll have him inspect them again before installing them this year..
GodWhomIsMike is offline   Reply With Quote
Old 11-13-2017, 02:52 PM   #7078
Obviously Tyler
Member#: 395955
2016 WRX
2018 Crosstrek
Recently got myself a set of 17" Sparco Terra wheels for my 16 WRX and I'm deciding between the Conti. Wintercontact SI and the new General Altimax Arctic 12 tires.
I'm biased towards Continental because I've had a few sets of their DWS06 tires and I love them, but the Generals have always had good reviews and are about $100 less per set no matter where I source them.
Anyone have experience with either or both? Thanks.
Obviously Tyler is offline   Reply With Quote
Old 11-13-2017, 10:44 PM   #7079
RussianTiny
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
What tire pressure should I run on a performance winter Tire? I currently pumped them up to 33psi to match what’s inside the door card on my 18 WRX
RussianTiny is offline   Reply With Quote
Old 11-14-2017, 01:04 AM   #7080
Kaykay
Member#: 409353
2018 WRX STI
Originally Posted by krzyss View Post
Guys/gals
Krzys
My OEM tire size is 245/35/R19 on my 2018 STi. I'd be wanting tires fit for mountain pass driving in winter so I guess snow and ice are my top two concerns. Also very cold temperatures. I am not concerned about noise really.
Kaykay is offline   Reply With Quote
Old 11-14-2017, 07:13 AM   #7081
krzyss
Member#: 8365
2013 Ford Focus SE
Then you sound like studded tires would match your requirements the best.
I strongly suggest going with smaller wheel diameter (probably the smallest that fits over the brakes). The money saved on tires and mounting/dismounting will pay for second set instantly (or in few change over cycles).
The best available studded tires are Nokian Hakkapeliitta 9, IMHO.
Krzys
Old 11-14-2017, 09:14 AM   #7082
vision.dynamix
Member#: 139955
2015 Subaru STI
17Forester / 18Crosstrek
You're gonna want 17s. If you're car is not lowered, I'd go with 225/50R17. Studded, probably.
Old 11-14-2017, 10:10 AM   #7083
SubLGT
Member#: 207528
2005 Legacy GT
Try 36psi.
SubLGT is offline   Reply With Quote
Old 11-14-2017, 12:11 PM   #7084
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
I was getting 2 seasons out of all my ws's, that underlying all season compound gets exposed into the second half of the treadwear. They arent up for full winter service at that point, even though there is a fair amount of tread remaining. Lots of folks arent aware of the compound difference and gauge it by tread depth alone.
left footed whooten is offline   Reply With Quote
Old 11-14-2017, 12:12 PM   #7085
Drbeastcar
Member#: 477703
Is there any 17" options for my 2017 impreza sport 2.0?
Drbeastcar is offline   Reply With Quote
Old 11-14-2017, 12:45 PM   #7086
krzyss
Member#: 8365
2013 Ford Focus SE
Have you tried tirerack.com or discounttiredirect.com?
Krzys
Old 11-15-2017, 01:14 AM   #7087
Kaykay
Member#: 409353
2018 WRX STI
Thank you very much krzyss and vision.dynamix! I'm just having to make up my mind on which wheels I'm getting but the tire portion is sorted now thank you!
Old 11-15-2017, 06:35 AM   #7088
krzyss
Member#: 8365
2013 Ford Focus SE
The aesthetical part I cannot help ;-)
Krzys
Old 11-16-2017, 08:05 PM   #7089
nationuar
Member#: 470898
I went with Big-O Tires, 17"x7" and 215/50/17, they have worked well. However that is for a '18 WRX without the big brembos. If you have the brembos you might need to get bigger rims with a decent offset to clear the brakes.
nationuar is offline   Reply With Quote
Old 11-17-2017, 01:21 AM   #7090
Kaykay
Member#: 409353
2018 WRX STI
Yeah unfortunately I do have the Brembos to worry about... I've been told by one of the places in town that I can do 17s but it depends on the wheel. Apparently there aren't any steel wheels that will fit either (yes I know aesthetically that would be a crime but it's also far cheaper were it possible lol). So yeah, deciding on wheels has been hard ^^;
Old 11-17-2017, 06:03 AM   #7091
vision.dynamix
Member#: 139955
2015 Subaru STI
Rack showing a selection of confirmed to fit 17s https://www.tirerack.com/wheels/resu...8&autoModClar=
Old 11-20-2017, 08:55 AM   #7092
bigmaninjapan
Member#: 299064
2008 VF52 WRX Sedan
2016 Ford Transit Connect
This needs to be stated again as its very good advice!
I'm not sure its fair to call it an all season compound, but there is a pretty big difference in deep snow and ice performance. The tires still perform very well in wet and slush, far superior than an all season tire IMO.
bigmaninjapan is offline   Reply With Quote
Old 11-20-2017, 10:06 AM   #7093
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
I do believe reading from their own info (2 years ago+/-) that Bridgestone calls it an all season compound under there. Might be different now. Theyre not bad tires by any means, but they wont be liked if they dont match your climate and conditions. The last set I bought was before the lightest winter in years, like under 400" which is nothing for our area and snowpack needs. They were awful since I was driving the good winter snow/ice compound out of them in the dry. Took them off early that season and got a second season out of them that was also low snowfall.
You never know what winter will be like vs how much you prepare your vehicle for winter. You could buy that gnarly set of Hakkas studded then get little precip. Better to be over than under prepared, but its always a crapshoot.
Old 11-20-2017, 10:08 AM   #7094
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Do 05-07 BBS fit and clear? That could be a nice option over aftermarket in appearance and price.
Old 11-20-2017, 10:10 AM   #7095
left footed whooten
Member#: 44652
16 Colorado diesel
ATC Bobcat Pop-up
Id be all over those Koseis in 17 unless some older STI takeoffs would fit.
Old 12-01-2017, 11:15 PM   #7096
LONG
Member#: 478433
2018 WRX
I really dont have time to search through 284 pages so hopefully you guys can help me out. 2018 stock premium wheels 245/40/18.. Im looking to pick up some snow tires, so do I stick with OEM size or could I go with a 225/45/18? Alot of potholes and occasionally some decent size snow storms around here, I commute 50 miles a day. Thanks
LONG is offline   Reply With Quote
Old 12-02-2017, 12:18 AM   #7097
krzyss
Member#: 8365
2013 Ford Focus SE
Why not 17" wheels if you want ot be better prepared for potholes?
Krzys
Old 12-02-2017, 12:52 AM   #7098
LONG
Member#: 478433
2018 WRX
Krzys
I was just going to use the factory wheels. I can possibly get some base OEM 17s. If that's the case should I just use the OEM size tire?
Old 12-02-2017, 08:07 PM   #7099
krzyss
Member#: 8365
2013 Ford Focus SE
OEM is always safe bet.
You will find that there is big price difference between 18" and 17" winter tires.
Krzys
Old 12-03-2017, 11:23 AM   #7100
jschweg
Member#: 470267
I would downsize to a 17 and run the snows on those. The price difference between buying snows at the stock tire size and having to get them mounted and unmounted every year would probably be the same as buying them mounted on 17 inch steel wheels. Assuming you aren't going for looks in the winter, this works out great and you can run 215's and tuck your nice 18s away in the garage for the winter.
The General Arctic 12's are like $123 per tire + $70 for the wheel on tirerack.
jschweg is offline   Reply With Quote
This here is the Android OS thread. All phones, news, general info welcome. under pressure Off-Topic 10849 12-13-2011 10:10 PM
WTB: Winter wheels/ or All season tires on wheels, or just all season tires! Robstunner MWSOC Private Classifieds 0 10-29-2009 11:42 AM
Winter Tires vs. All Season Tires wrx425 Tire & Wheel 22 01-15-2009 11:34 PM
same tire thread all around for AWD? MystikalDawn Newbies & FAQs 6 10-15-2008 11:28 AM
Anybody get tired of all your mods and go back to stock or somewhere in between?? Farnsrocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 09-11-2007 10:06 PM
