Welcome to the North American Subaru Impreza Owners Club Thursday October 21, 2021
Old 03-05-2009, 12:28 AM   #176
random112
Member#: 168594
1993 JDM GC8 WRX
silver with dirt
Default coil location
ok so this is gonna sound really retarded but where the heck is the 4 pronged coil pack thing that has to be deleted (not the coil on top of the plug, but the part that has to get pulled out for good, and bypassed)? I can't even find it... might be under the manifold or something? Wires run up towards the center top of the engine, then just disappear!
93 jdm ej20g
Thanks!
random112 is offline   Reply With Quote
Old 03-05-2009, 01:31 AM   #177
sniper512
Member#: 189923
1993 JDM WRX
On the passenger side strut tower. It is hidden under the BCS, MAP, and that other thingy with the vacuum lines going to it. Its easy 3 bolt and its out.
sniper512 is offline   Reply With Quote
Old 03-05-2009, 09:22 AM   #178
luka
Member#: 194742
1993 Impreza WRX JDM
93 jdm ej20g
Thanks!
This may sound silly but when you unplug your old coils make sure you label the wire harness which is what cylinder 'cause all the wires have the same color. I made that mistake and it took me a good hour to figure out why the motor didn't start ;/
luka is offline   Reply With Quote
Old 03-05-2009, 11:34 PM   #179
random112
Member#: 168594
1993 JDM GC8 WRX
silver with dirt
thanks sniper - will chek it tomorrow. What is the BCS and the MAP??
another dumbie - do these cars have knock control of some kind?
Old 03-06-2009, 12:36 PM   #180
bmxpunk
Member#: 89599
1995 almost 22B:)
red
[quote=random112;25841620]thanks sniper - will chek it tomorrow. What is the BCS and the MAP??
another dumbie - do these cars have knock control of some kind?[/QUOTE
BCS- boost control solenoid
MAP- Manifold absolute pressure sensor
Its the stuff that is mounted on the bracket on your front passenger side strut tower
bmxpunk is offline   Reply With Quote
Old 03-07-2009, 12:05 PM   #181
sniper512
Member#: 189923
1993 JDM WRX
Yuppers they have a knock sensor located under the intake manifold on the drivers side(non jdm so your passenger) of the TB.
Old 03-08-2009, 05:35 PM   #182
97sportwaggie
Member#: 171770
1994 Impreza Wagon
Dark Silver Mettalic
i converted them to fit my liberty version. kind of annoying but i made it work using like 40 dollars worth of dremel blades
97sportwaggie is offline   Reply With Quote
Old 03-25-2009, 10:36 PM   #183
evankanga
Member#: 189730
1983 westfalia
Default wrx ej20g--coil conversion--hell--back again
well, my right side coils are not firing.
when looking at the wires on the big plug coming off the ecu, there are like 8 wires, four of them are skinny, and the others are fatter. with the power on, none of the skinny wires have any power to them (200MV) is this right?
http://picasaweb.google.com/evankanga/WRXWestfalia#5317318549881295010[/IMG]
above is a picture. the wires on the left by my fiinger are the fat ones, and the ones on the right are all skinny except one 12V yellow wire.
http://picasaweb.google.com/evankanga/WRXWestfalia#5317318553114166306[/IMG]
this picture of the ecu shows the groups of wires. the four on the right are all fatter, and the four on the left are all skinny.
not really sure where to go from here.
any ideas
thanks evan
evankanga is offline   Reply With Quote
Old 03-25-2009, 10:49 PM   #184
keirnna
Member#: 50167
1996 Subaru STI RA
any ideas
thanks evan
Fixed your pictures.
keirnna is offline   Reply With Quote
Old 03-25-2009, 10:51 PM   #185
keirnna
Member#: 50167
1996 Subaru STI RA
any ideas
thanks evan
Old 03-25-2009, 11:31 PM   #186
evankanga
Member#: 189730
1983 westfalia
Default update--
thanks for fixing the pics.. and by the way i did the coil conversion last year.
all pigtails to all coil packs have one 12V wire, and one that has XX MV[trigger]
how do i check to see if the trigger is working?
i can unplug the pigtails on the right bank and no change whatsoever.
injectors just checked and cleaned.
i am amazed it runs on two cylinders so well.
bad ECU?
Old 03-25-2009, 11:52 PM   #187
evankanga
Member#: 189730
1983 westfalia
Default another update
ok... injectors:
with the ignition on
#1 12V 9V
#3 12V .2V
#2 12V 2V
#4 12V .4V
with the ignition off:
all read below a volt.
does this warrant concern? seems like it does.
getting someone over tomorrow to help me check spark
Old 03-26-2009, 07:39 PM   #188
evankanga
Member#: 189730
1983 westfalia
Default Update
ok....
i had the wires for the injectors and coils backwards for the right bank.
after changing them .....
i have squirt on 4, and spark on 3
much better... but i am still down one spark.\
on that one coil... how can i check whether i have a good coil pack via the ohms test or another.
ev
Old 03-26-2009, 08:00 PM   #189
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
I don't know the proper resistance for a late model coilpack offhand, but check it versus the other ones, they should all be almost identical....... also, try switching the coilpack to another cylinder and see if your problem moves.........
rockcrete is offline   Reply With Quote
Old 03-27-2009, 10:00 PM   #190
evankanga
Member#: 189730
1983 westfalia
Default FIxed
well..... it's sorted....
here's the scoop.
i crossed some wires..... ran some jumpers and found out that the pigtails off the new coils were all correctly inserted into the plugs except one.. which was reversed. re-inserted the wires in the plug and off she goes.
all 4 squirt now and all 4 sparky is the current deal.
thanks again NASIOC
Old 04-13-2009, 01:43 AM   #191
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Got mine wired in this weekend. I had the connectors from an 07 Sti sitting around so I hard wired them on to the 20G's engine harness
Last edited by bmxpunk; 04-13-2009 at 09:11 AM. Reason: said plugs, meant connectors, my bad
Old 04-13-2009, 02:00 AM   #192
keirnna
Member#: 50167
1996 Subaru STI RA
Originally Posted by bmxpunk View Post
Got mine wired in this weekend. I had the plugs from an 07 Sti sitting around so I hard wired them on to the 20G's engine harness
DO NOT USE STI EJ257 PLUGS ON YOUR EJ20!!!!!!!!!!!
You need to use the 07 coil packs with your regular EJ20 plugs. EJ257 plugs are longer and your piston might smash right into them.
Old 04-13-2009, 09:05 AM   #193
bmxpunk
Member#: 89599
1995 almost 22B:)
red
Originally Posted by kbahus View Post
Other than a faulty coil pack the swap went smooth. I was fortunate enough to track another down and got the car up and running. I have one bad connection I need to investigate but it runs super smooth and pulls awesome to redline. This was a great idea! Thanks Rob!
I am about to go install the STI coils.
I know better than to use the STi plugs because of how long they are are inside the head. I just used regular old NGK BKR7es. Kbahus used the same coils andit worked for Him I, don't see why it won't work for me. Forgot to mention this is a 2.2t/25d Heads wired as a 95 wrx
Edited above. Said plugs, meant connectors
Old 04-22-2009, 02:56 PM   #194
97sportwaggie
Member#: 171770
1994 Impreza Wagon
my car is running ****ty again after doing the coil conversion any suggestions.
Old 04-23-2009, 03:19 PM   #195
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
i just finished my Conversion. more than 100% happy. my car has no problems anymore! awesome thread.
instead of soddering though, i bought some .110'' connectors and sodderd the wires to them and then just plug'ed each one of the 3 into the coilpack. then put the high temp epoxy in. looks awesome and alot easier than trying to sodder inside the coilpack.
gc8awdsti is offline   Reply With Quote
Old 04-23-2009, 11:31 PM   #196
sniper512
Member#: 189923
1993 JDM WRX
Thats what I did. Worked great as well.
Old 04-30-2009, 07:04 PM   #197
sniper512
Member#: 189923
1993 JDM WRX
Does anyone know the testing procedure for the newer 02+ WRX coils? I am starting to think that i may have a wiring issue from the coils to the ECU.
Old 05-31-2009, 02:44 AM   #198
XanRules
Member#: 157348
JACK ING OFF
AND COMMITTING FRAUD
bumping because I just got an EJ20g manifold. Everything bolts up, but...where do I put this effing coilpack from my old motor?
XanRules is offline   Reply With Quote
Old 06-04-2009, 04:30 AM   #199
jdmwrx94
Member#: 211619
94 jdm wrx
red
Just did the convertion and now the car runs crappy. starts well, shakes more than it should, when i push on the gas, engine goes down a bit then rises in rpm. my boost guage indicate the proper boost(11ish psi) but feels like a pony, any clue?
***edit*** didnt expected to have a faulty coil, replaced it and fixed my problem
jdmwrx94 is offline   Reply With Quote
Old 06-28-2009, 02:40 PM   #200
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I got a set of 3.0 b9 tribeca coilpacks for super cheap, will they work the same as the wrx versions? They look the same as the wrx coils but the boots are red. I have a 97 ej20k and will be converting it to coil on plug.
2slofouru is offline   Reply With Quote
WTB: WRX coil packs for the EJ20G coil pack conversion ASAP! Joshb120 Private 'Wanted' Classifieds 2 05-18-2008 12:42 AM
2000 Intake manifold, EJ20G Intercoolers, EJ20G coil Woki Toki Engine/Power/Exhaust 3 04-18-2008 11:54 PM
EJ20G coil resistance? snowman4us Pre-2002 Factory Turbo Powertrain 4 11-15-2006 01:52 PM
EJ20g Coil on Plugs newgensti Subaru Conversions 7 09-15-2006 11:07 AM
EJ20G coil packs scoobyimprza Subaru Conversions 2 08-29-2005 01:36 PM
