Welcome to the North American Subaru Impreza Owners Club Sunday October 17, 2021
Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Old 08-19-2021, 09:56 PM   #26
murrdogg24
Member Sales Rating: (49)
Member#: 50586
2020 STI
Crystal White Pearl
I have no idea if it's cracked or not because its on the car. I guess I can use a borescope when I change the oil next time.
Originally Posted by KillerBMotorsport View Post
The Smedia pan was installed December 2020. The other recent one is a few months old, and that was an obvious error on our part (setup baffle was used). We've sold +1,500 pans since Dec 2020. Not many failures
Do you have a cracked baffle? If so, reach out to us.
murrdogg24 is online now   Reply With Quote
Old 08-20-2021, 06:21 PM   #27
SwollRX
Member#: 382191
2006 WRX
I haven't seen it yet (or I keep missing it); What is the height difference between this and the OEM EJ Pans? Does it hang below any of the bottom bits when installed (in my case, an 06)?
SwollRX is offline   Reply With Quote
Old 08-24-2021, 10:25 AM   #28
KillerBMotorsport
Vendor Sales Rating: (43)
Member#: 198281
2005 WRX/STi
WRB of course
Our performance pan is ~7/16" taller. I say about, because the depth tolerance on Subaru pans is generally +/-.125, plus the GD and RV/VA pans are slightly different.
For your GD (and I'm relying on my not so great memory) I believe one of the OEM belly pan reinforcement ribs needs to be trimmed. It's a quick cut with a utility knife. I have seen some run without doing this, it will rub under some conditions, but I've never seen it cause any damage. I recommend trimming to provide 1/4-1/2" of clearance.
__________________
vs.
FA20 WRX Ultimate Oil Pickup, Now Available! Improving Pressure Consistency and AVCS Synchronization
KillerBMotorsport is offline   Reply With Quote
Old 08-24-2021, 05:00 PM   #29
SwollRX
Member#: 382191
2006 WRX
Thank you, so I can still utilize my plastic undertray/ belly pan then. That is good to know. I was initially concerned it may be hanging too low and potentially scrape; Im lowered by around 0.5"-1.0", if that much.
Old 09-24-2021, 06:39 AM   #30
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Correct!
Also, to give you some additional feels, our pan is extremely tough. It's put through two heat treat processes, and dare I say it's the strongest pan out there. In fact, it's VERY popular in off-road rally because of this. One car (El Diablo Rally Team; check them out on FB for the post) had an off into a boulder field a couple years ago, and the skid plat hit so hard it tore the engine from the motor mounts. It left a terrific imprint. They still use that pan today
__________________
vs.
