07-22-2008, 08:49 PM | #1 |
Member#: 159738
SCIC
Vehicle:2004 WRB STi 620awhp OFCD V3, FR TS, BW8374EFR |
Interesting ring gap machine
I don't do engine builds myself to warrant buying one, but since they're local maybe they'll gap my rings for my build. I just like to know the measurements are spot on.
http://www.abs-products.com/specialt...grinder.shtml# http://www.youtube.com/watch?v=RHSoSZvHoCo |
07-22-2008, 10:20 PM | #2 |
Member#: 29201
NESIC
Vehicle:BMW M3 Honda S2000x2 |
That is very trick. I like it, but I'm in the same boat. I don't do enough rebuilds to justify the nearly $900 price tag.
07-23-2008, 03:21 PM | #3 |
Member#: 54918
MAIC
Vehicle:673 WHP Element Tuning Pro Comp Engine |
When sizing your rings you should always use the proper tool to make sure the ring is cut smoothly and at the correct angle. You don't need a $900 ring grinder to do this properly however I could just see it know, go ahead and stick the ring in there, spin that baby up to 5,000 rpm, and oops I just took off 10 thousandths
I've seen some hack job hand filed rings and you really want to avoid that. You can get a decent ring grinder for a few hundred. When you start adding up what it costs to get all the proper tools sometimes it makes more sense to pay someone to do it but if you're brave and crafty go for it Thanks, Phil www.elementtuning.com |
Similar Threads | ||||
JE 2618 Pistons Ring gap & valve notches... | xbcaraudio | Built Motor Discussion | 4 | 04-17-2008 10:23 PM |
ej20 arias .020 over pistons ring gap | Scooby Rex | Built Motor Discussion | 5 | 07-30-2006 11:24 PM |
ej20 arias .020 over pistons ring gap | Scooby Rex | Built Motor Discussion | 1 | 07-26-2006 09:33 AM |
2.2t ring gap | TyranosaurusWRX | Pre-2002 Factory Turbo Powertrain | 8 | 04-19-2005 02:18 PM |
Ring Gap Question | Andursun0013 | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 02-25-2005 02:02 AM |
