Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 01-16-2018, 08:38 PM   #1
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Default STi Wheel Bearing Clearance
I just upgraded from the press in style bearings to 05-07 STi hub assemblies. I ordered new assemblies and noticed radial play in the bearing.
Is there a tolerance on these bearings for radial clearance? Not the best setup - but I measured with a feeler gauge approx .008 inches of total deflection.
I took a video - note the bearing was at about 40 degrees F here and the measurement was done at room temp.
The only thing I can think of that would have damaged the bearing is wheel stud install. I was very cautious to gently tap out the old studs by putting the bearing in a jig of wooden blocks under the hub face so less force would be transitioned to the bearing itself. I didn't notice if there was play before I did that but when the old studs were out and before the new ones went in I became nervous studying the play. Anyone have a new bearing they can refer to, or have a similar experience? Bearing spins smooth as silk and sounds fine.
corona672 is offline   Reply With Quote
Old 01-16-2018, 09:39 PM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
If you were hammering on the hub without the axle bolted in you could have caused the inboard inner bearing race to move a bit. That would explain the freeplay. Install the axle, torque the axle nut and you should be fine.
Old 01-16-2018, 09:46 PM   #3
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
If it's designed anything like the original, there will be some play until you torque the nut, because of the two separate inner races and bearings.
Old 01-16-2018, 10:36 PM   #4
corona672
Member#: 262902
'04 WRX Hybrid
It's a wrap!
Hammering sounds so cruel, I prefer 'encouraged' . The idea was by fixing the hub while encouraging the stud to come out, it would reduce any moment on the bearing itself.
Yes its the OEM bearing from an 07 STi. Is that a NTN bearing? I might be able to dig up some clearance charts from them.
I agree I'd like to try and torque them down and verify - I'm going to need some more parts first.
Old 01-16-2018, 11:23 PM   #5
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
I meant the original press in bearing. They have two center races and one large outer. When they aren't installed/torque'd between the axle and nut, they have some play because the two inner races can move a little. When you torque the nut, it presses the center races together and drops the clearance way down. This is why it's important to use a good torque wrench and the correct spec.
The style you are installing should also have two separate inner races. They shouldn't separate if there is an inner hub pressed between them though, unless you hit it pretty hard. Using something to support the rear of the hub is the correct way to do it.
Sometimes the inner races of the previous style bearings can pop a little loose or even come out if you jar them. It's easy to snap them back in by hand though.
