Welcome to the North American Subaru Impreza Owners Club Friday November 27, 2020
Old 11-25-2020, 10:49 AM   #376
samagon
Member#: 26859
of TXIC
I also like (oYo)!!!!
Originally Posted by BeepBoop View Post
You're googling the 90s one. I specifically said 80s. The 80s one ranges from 2800-3200.
not sure where wikipedia got their info (cause I see the 2800 lbs claim as well), but according to a few other sites I've visited, every version of the turbo (manual/auto) weighed more than 3000 lbs.
Old 11-25-2020, 11:12 AM   #377
blurred
Member#: 47143
Originally Posted by quentinberg007 View Post
Is own3d still a thing?
Very nice comparison. Iíll have to dust off my spreadsheet where I calculated the wheel torque at given vehicle speeds and see how the new BRZ compares to the old.
Edit: dusted. Looks like the BRZ gen 2 (if 4.44) will make ~25% more torque to the wheels than the gen 1.1 (4.11) across the vehicle speed range. At 20mph, it will make a whopping 40% more torque because 20mph in first gear was the pit of despair on the gen 1.1 (4000RPM). The Fiesta will hold to the gen 2 until 20-25mph where the BRZís narrow gear ratios and wide RPM band take over.
The correct term would be Axle Torque, not Wheel torque, wheel torque takes rollout into consideration on the power side. Did you use the dyno graphs for each car and correct rollout for speeds??
Here is my old Fiesta ST with mp215 kit Axle torque graph, using my dyno graph in 250rpm increments
blurred is online now   Reply With Quote
Old 11-25-2020, 12:57 PM   #378
JustyWRC
Member#: 153088
2005 Baja Turbo
06 Forester 18 Imp Sport
Originally Posted by bugatti0628 View Post
very possible the roof lights has LED upgrade
No doubt; but, when EVERY other light on the car is LED.................why should I have to pay more for them?
Old 11-25-2020, 04:44 PM   #379
subyski
Member#: 202642
08 Impreza,80Vette
68 Impala, 15 SantaFe
Originally Posted by heavyD View Post
Maybe it's me but I don't crash into cars or other things so headlight replacement costs isn't something I ever consider when looking at a vehicle.
It's not so much that. If an LED diode dies, it you're SOL if it's out of warranty. Sure, LED's should last a "lifetime" but I've seen plenty of OEM LED taillights with failed diodes. One or two diodes is maybe fine, looks bad but it still sucks as there's only one fix, full replacement. LED headlights are not cheap and it give insurance companies more reason to charge higher premiums too. Honda has issues with their DRL LEDs burning out.
I'm for improved headlight and light output but it can come at a cost.
subyski is offline   Reply With Quote
Old 11-25-2020, 04:59 PM   #380
BeepBoop
Member#: 496462
Can you really not see how something that has mechanical actuation would have a shorter life than something permanently fixed in place?
Do YOU want to pay to replace the motors on those stupid things when they act up 10 years into a car's life (or earlier), or are you one of those people that thinks of cars as disposable things you're going to replace ever 3-5 years
I typically own cars late into their life and have to deal with all the shortcomings of things hitting their failure points. I'd prefer cheap, easy replacements with a focus on minimal extra **** that can go wrong. Keeping it stupid simple is an art form lost on modern automotives.
BeepBoop is offline   Reply With Quote
Old 11-25-2020, 05:13 PM   #381
dwf137
Member#: 161333
18 Highlander
Yami XSR
I totally agree. These are the reasons I never saw myself owning my Golf R longer than the 6 year warranty I had - only ended up having it 2 years because of other life circumstances.
I'm strongly considering one of these in a few years. The wife gave me the thumbs up. This would likely be a long-term car as it'd be a third car, garage kept. I'd much prefer to avoid too many gizmos and gadgets especially on a Subaru. VW has been doing gismos and gadgets for so long that they've worked out the kinks, Subaru, not so much. Although I guess if the tech is coming from Toyota/Lexus, I might be a bit more up for it.
Old 11-25-2020, 06:07 PM   #382
JustyWRC
Member#: 153088
2005 Baja Turbo
Turn SRH off.......fixed......
Old 11-25-2020, 10:42 PM   #383
samagon
Member#: 26859
of TXIC
as long as it doesn't get stuck in a permanently cross-eyed position I couldn't care less if the turning motors break, so long as the bulbs produce light and point ahead???
Old 11-25-2020, 11:53 PM   #384
BeepBoop
Member#: 496462
That works! I wasn't aware you could do it.
I'd say the chances of it breaking and staying aligned or being aligned straight ahead instead of breaking mid-turn and sticking that way are small. Justy's suggestion works perfectly, though. If it's a permanent setting I can disable, it then becomes a non-issue.
Old Yesterday, 12:51 AM   #385
samagon
Member#: 26859
of TXIC
I bet there's a manual override kind of thing where you can align them, if they break in a cross eyed position.
bottom line, lots of options and the safety feature is hardly the end of the world if it breaks.
Old Yesterday, 01:27 AM   #386
Brahmzy
Member#: 3293
'20 Ascent
'15 XTerra P4X
LOL
Are we seriously discussing unfounded theoretical breakages of Subaru SRHs?
First, those motors are meant for ungodly amounts of runtime and activations.
Second, there has been no known said breakages. Correct me if I am wrong.
Third, my Ascent headlights are so badass I do not think I want another Subaru without them. I would gladly cough up for a headlight if I still own the vehicle outside of warranty.
Brahmzy is online now   Reply With Quote
Old Yesterday, 01:35 AM   #387
lil'redwagon
Member#: 10854
'02 WRX; '08 OBXT;
'08 G37 (S/C'd); '09 XF
My dad has a Mercedes that has headlights with motors in it. One side broke and it was permanently pointed down, like with the cutoff on the ground 6 feet in front of the car. No replaceable parts, just a new headlight assembly at those prices (~$1,000 for one). His warranty either just ran out, or it didn't cover it. I think he ended up claiming it on his insurance. Pretty ridiculous. I would opt out if given the choice.
lil'redwagon is offline   Reply With Quote
Old Yesterday, 01:53 AM   #388
Brahmzy
Member#: 3293
'20 Ascent
'15 XTerra P4X
Key word - Mercedes. Remember, German cars are STILL known for all kinds of little $hit breaking.
Old Yesterday, 07:19 AM   #389
nashcarr
Member#: 131897
2010 STi 05 FXT
SSM
Default 2022 Subaru BRZ News and Rumors
I like it, but not enough to get rid of the 2020tS I just purchased.
Like any other Subaru, the design grows on you after about 4-5 years.
nashcarr is offline   Reply With Quote
Old Yesterday, 09:54 AM   #390
Brahmzy
Member#: 3293
'20 Ascent
'15 XTerra P4X
Somebody needs to steal one and dyno it.
Old Yesterday, 01:07 PM   #391
bugatti0628
Member#: 447323
What if they release a ts version of the new brz. proper brembo brakes, unique dampers, better engine with almost no torque dip
bugatti0628 is offline   Reply With Quote
Old Yesterday, 02:49 PM   #392
illmatic
Member#: 3536
2017 SWP BRZ PP, FXT
2002/2003 AW/PSM WRX
I'm 100% sure Subaru will release special editions with Brembo brakes (found on VA WRX PP) etc.
illmatic is offline   Reply With Quote
Old Yesterday, 03:46 PM   #393
bugatti0628
Member#: 447323
but will subaru reward enthusiasts with a STI performance exhaust and very unique and lighter cold air intake. they have a chance to prove to us that we can get the power and handling without needing the turbo. they already took care of the torque dip
Old Yesterday, 05:53 PM   #394
subyski
Member#: 202642
08 Impreza,80Vette
Now that you mentioned it, I'm really surprised Subaru didn't release a STI exhaust or intake. TRD did for the FRS/86. They could have just rebranded the TRD units.
