Welcome to the North American Subaru Impreza Owners Club Friday June 5, 2020
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 01-10-2007, 11:51 AM   #1
MUGWUMP
Member#: 13170
2012 New Hotness
Default Quick tire question, could really use a quick reply...
MUGWUMP is offline   Reply With Quote
Old 01-10-2007, 12:01 PM   #2
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Don't do it!
Revision is offline   Reply With Quote
Old 01-10-2007, 12:05 PM   #3
MUGWUMP
Member#: 13170
2012 New Hotness
Damnit.
Now I gotta dig my summer wheels out from the back of my garage.
You've been around awhile, so I'll trust your judgement. I just didn't want to add 45 min to the whole ordeal.
Any mods can delete this thread and the one in the other forums if you are capable.
Thanks Rev.
Old 01-10-2007, 12:26 PM   #4
Yotsuya
Member#: 935
Will Woollard
Fan Club
Yeah, really a bad idea, there
Yotsuya is offline   Reply With Quote
Old 01-10-2007, 12:48 PM   #5
MUGWUMP
Member#: 13170
2012 New Hotness
Done!
That wasn't too bad...other than the sweating part in 35 degree weather
Remind me to buy a cordelss impact.
*wipes forehead*
Old 01-10-2007, 12:49 PM   #6
Revision
Member#: 242
MY05 PSM GGA !STOCK
I've got a cordless impact from Snapon. Takes 3/8" sockets.
Old 01-10-2007, 12:52 PM   #7
MUGWUMP
Member#: 13170
2012 New Hotness
Oh...and it looks like I bent something in the rear. The endlink I thin it is? The little C shaped thing. Whaever its attached to at the bottom is a little off. There might be something a bit bent with the front also, but nothing too bad. Guess I'm gonna have to take it to someone to take a look at it.
Old 01-10-2007, 12:53 PM   #8
MUGWUMP
Member#: 13170
2012 New Hotness
Yea my friend prob has the same one. As soon as IU can get $3-400 of disposable income, that will be my first purchase. If this happened a week earlier than it did I wouldn't have bought that xbox 360.
Old 01-10-2007, 01:00 PM   #9
Revision
Member#: 242
MY05 PSM GGA !STOCK
If you hit it that hard, you should have someone look at your suspension to make sure nothing else is bent.
Plus you need an alignment at minimum.
Old 01-10-2007, 01:15 PM   #10
nate.the.great
Member#: 72031
2017 SS 1LE
agreed. i bought this goodyear racing cordless impact from pepboys. it has taken a beating and still works great. strong enough to take off struts bolts too! until i have my own garage and get an air setup, it's great. i even ran it over with my sister's car once. hahaha. it think it was like $90.
nate.the.great is offline   Reply With Quote
Old 01-10-2007, 04:01 PM   #11
rougeben83
Member#: 115154
2005 Outback XT
White on grey
Is it the blue one? I think they were having a sale on those for $70. I was sooo tempted to get it, but wasn't sure how well a cordless impact would do.
By strut bolts you mean the two bottom ones right? I may be tempted to get one just to do my strut/spring install
rougeben83 is offline   Reply With Quote
Old 01-10-2007, 04:25 PM   #12
Revision
Member#: 242
MY05 PSM GGA !STOCK
Usually when someone says strut bolts and impact gun, I tend to think about the strut top bolt that holds the strut top and the strut together. You need either a special tool or an impact to get that off as the assembly usually rotates together if you try it with hand tools.
Please note that the bottom two strut bolts that hold the strut to the knuckle are usually torqued to 120 ft lbs plus rust/dirt holding power.
Old 01-10-2007, 04:56 PM   #13
nate.the.great
Member#: 72031
2017 SS 1LE
yup, the blue one! you should, it's worth it, and i am talking about the bottom two bolts. don't forget the PB blaster!
Old 01-10-2007, 05:01 PM   #14
nate.the.great
Member#: 72031
2017 SS 1LE
the top bolt is most easily loosened by dealing with it when the strut is still attached to the car. however, i got a pass-through socket set as a gift for christmas. def. my favorite tool set because the teeth on the socket wrench is so fine. i recommend picking one of those up too. i think my set is made by gear wrench? i got it at sears.
Old 01-10-2007, 06:58 PM   #15
Revision
Member#: 242
MY05 PSM GGA !STOCK
I've got a set of those in the tool chest of the Subaru trunk. Works great for misc stuff too... I still prefer using a long pipe over a long breaker for the lower 2 bolts. Beats snapping them in two with an impact.
Old 01-12-2007, 02:07 AM   #16
MUGWUMP
Member#: 13170
2012 New Hotness
I've got an update here for those who (don't) care.
Need new:
Lower control arm
Axle
struts
steering knuckle
endlinks
yadda
yadda
alignment
end result is $1580
*Shoots self in head*
Old 01-12-2007, 03:03 AM   #17
downshift1
Member#: 15607
I'm not the type
to make angry
I have most of those parts slightly used
downshift1 is offline   Reply With Quote
Old 01-12-2007, 08:00 AM   #18
Revision
Member#: 242
MY05 PSM GGA !STOCK
Ouch..
I could really use a BJ right now... DrDRum Off-Topic 616 01-15-2012 12:04 AM
Looking to upgrade could really use some input. ajshades Tire & Wheel 27 04-14-2008 09:32 PM
Could really use help from Ft Walton area stikboy9 South East Region Forum 3 02-28-2008 09:19 AM
Everybody listen, i could really use your help... under pressure Off-Topic 15 02-02-2006 05:38 PM
I could really use some help..... PimpRS420 Normally Aspirated Powertrain 1 10-21-2003 09:22 PM
