Welcome to the North American Subaru Impreza Owners Club Wednesday June 3, 2020
Old 07-30-2008, 06:22 PM   #1
blackrexxer03
Member#: 130532
2003 MBP WRX
UTEC Protuned Stg. 2
Default quick up-pipe question
looking at up-pipes i've noticed that some have like 5 studs when I thought that mine was only 3, are the newer wrx's different from the older ones?
blackrexxer03 is offline   Reply With Quote
Old 07-30-2008, 06:27 PM   #2
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
'Like' 5 studs? Or 5 studs?
Throw up a link to the uppipe you're referring to. There are only 3 bolts that matter, and those are the turbo bolts. The others are for the mounts if I'm not mistaken. It's been a while since I've been under there
Audiosavvy is offline   Reply With Quote
Old 07-30-2008, 06:33 PM   #3
blackrexxer03
Member#: 130532
2003 MBP WRX
http://www.perrinperformance.com/sha...0/97_large.jpg
has holes for 5 studs but there is only three bolts that bolt the u/p to turbo correct?
Old 07-30-2008, 06:42 PM   #4
FlatironsTuning.com
Member#: 171650
There should be 5 studs on the top flange of the Up-Pipe, three of them bolt to the turbo, and the other 2 hold the up-pipe in place. You should get all 5 with any up-pipe that you get, though I have seen a couple that make you transfer studs from your OEM Up-Pipe to the new one, and that is a real pain.
Oh, and all 2002 - 2005 WRX Up-Pipes are the same. Though all the STI Up-Pipes, and later WRX's Up-Pipes do not have a pre-turbo cat FWIW.
Fitment wise, they haven't made any changes since the old turbo Legacy.
J. Cooley
Flatirons Tuning Project Car
Flatirons Tuning F.A.Q. Blog
Flatirons Rally Team Blog
FlatironsTuning.com is offline   Reply With Quote
Old 07-30-2008, 06:44 PM   #5
blackrexxer03
Member#: 130532
2003 MBP WRX
gotcha, thanks for the info 8)
Down pipe/Up pipe questions 72BCR Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-10-2009 06:36 PM
Quick Y-pipe question! Vicious LSD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-29-2007 07:12 PM
Quick mid-pipe question loreley Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-29-2007 01:57 PM
quick intercooler piping question deluxsti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-17-2005 10:15 PM
Quick Down Pipe Question gpd323 North West Impreza Club Forum -- NWIC 3 11-02-2001 08:00 PM
