Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2020
Old 09-13-2019, 10:03 AM   #301
delongedoug
Member#: 124113
Pura vida!
Yellow V standing by
Originally Posted by thechickencow View Post
The biggest benefit of the newest one is it will get updates to iOS a bit longer than the model before it and that means its useful life from purchase is longer.
Is that actually true? I mean, they're identical devices on the inside. Technically, there is no reason one should get updated longer than the other unless Apple does "X years guaranteed" updates, in which case the newer one will get one more year. But based on identical hardware, I'd expect them to be on the same upgrade cycle.
Because older generations are still for sale, I'm finding myself between 4 iPads that find themselves at similar price points (all wifi only):
2018 6th gen 9.7" iPad (128GB, A10 Fusion): $379
2019 7th gen 10.2" iPad (128GB, A10 Fusion): $429
2019 3rd gen Air 10.5" (64GB, A12): $469
Refurb 2017 2nd gen 10.5" Pro (64GB, A10X): $469
I honestly see no reason to buy the 7th gen iPad over the 6th. Maybe you get another year of updates? But the internals are the same, so maybe not. Either way, it's $50 for a slightly bigger screen. The problem is, at $429, why not just get the much better Air for $469? I could see getting the base iPad if you only want 32GB of storage, but the more usable 128GB model is a little too close in price to the Air. Probably on purpose, knowing Apple and their upselling ways.
That's why I'm pretty much between the 6th gen and Air. I'm not so sure about the refurbished Pro because it's from 2017 and while it still has a better processor than the current base iPad, it's the same price as the latest Air from 2019. So that's already 2 years of longevity gone at day 1 for little gain.
At the end of the day, I guess the Air is probably the best bet for future-proofing and all-around device per dollar.
/thinkingoutloud
delongedoug is offline   Reply With Quote
Old 09-13-2019, 11:52 AM   #302
psg
Member#: 81549
For all intents and purposes, the 7th gen iPad is the 6th gen with a nicer display. They're both 64-bit SoCs with the same amount of RAM. Unless Apple were to do something arbitrary about iOS support on those devices, the two should be supported with the same cutoff point.
https://i.imgur.com/wxYSqGG.png
psg is offline   Reply With Quote
Old 09-13-2019, 12:24 PM   #303
thechickencow
Member#: 16840
17 4Runner
Im talking out of my ass but in generality the device will stop being supported by updates at some point. Id have to look at apples history if theyve ever cut off a same hardware base device at a different update.
thechickencow is offline   Reply With Quote
Old 09-13-2019, 03:56 PM   #304
psg
Member#: 81549
Right, but usually when they do it, they're doing it for a reason. Like when all the 32-bit iOS devices got dropped and they went full 64-bit support only.
But Apple has locked certain features behind arbitrary "walls" at times, so who's to say that they might decide that a iPad 6th gen doesn't get iOS 15.2 but an iPad 7th gen does, and they run on the same SoC.
Old 01-10-2020, 12:42 PM   #305
lag
Member#: 34631
Not much to add:
I got an Ipad 4 or 5 years ago from my company as a Christmas Gift. I got a new one this year I still need to open/set up. I don't use the iPad for much more than a great magazine with Texture having pretty much everything I normally would have a subscription to. I don't have stacks of mags to deal with at home or having to pick some to travel with.
Nov' of last year the battery was being drained in a day even being generally unused. I didn't find an obvious reason that this seemed to suddenly start happening with pretty much years of use where I would charge it every other week at most with my limited rarely being under 30% charge, it was more a routine than necessity. I didn't want to jump on the artificial the problem bandwagon thinking Apple is trying to make me buy a new iPad having had mine too long. But, again I couldn't find a reason for the drain. Then it went back to normal battery use maybe having to charge it three times since Dec with no changes to the iPad or how its used.
Does this point to an obvious/known Ipad condition/problem/things that just happen you're aware of?
lag is online now   Reply With Quote
Old 01-10-2020, 12:52 PM   #306
shikataganai
Member#: 92634
The BMS probably was confused.
shikataganai is offline   Reply With Quote
Old 01-10-2020, 12:58 PM   #307
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
Or you're a dummy that installed a Facebook app and let it stew.
Old 01-10-2020, 01:26 PM   #308
psg
Member#: 81549
Originally Posted by lag View Post
Not much to add:
Yeah, batteries degrade over time and you've got a 5 year old iPad.
Old 01-10-2020, 02:02 PM   #309
lag
Member#: 34631
I don't know what else I expect out of an Apple thread.
Thank you.
Old 01-10-2020, 02:13 PM   #310
psg
Member#: 81549
What do you want us to say? Apple is ****ing with you?
Old 01-10-2020, 03:52 PM   #311
lag
Member#: 34631
"I love you. There was a bug in X-update fixed in Y-update that lead to draining the battery at unusually high rates around that time frame. Yore hair looks nice like that. If you didn't see update x replaced by y it may have been conscripted into a bot army explaining battery draining while you thought it wasn't in use. Check log x on the ipad and your router logs for oddities if not already running something that would alert you of oddities happening in real time."
Old 01-10-2020, 04:11 PM   #312
psg
Member#: 81549
Nice try, I don’t compliment anyone’s hair.
About the only thing you can do to help diagnose it is go to settings—>battery, and see if there are any outliers or trends. Apple didn’t put the battery health tool that’s on iPhones on the iPad, so you can’t directly see the reported battery % left. Anything below 80% is continued EOL on phones.
Old 01-10-2020, 04:11 PM   #313
psg
Member#: 81549
Somehow...a double post.
Old 03-27-2020, 10:28 AM   #314
markman
Member#: 93623
Has anybody tried the new mouse/touchpad support for iPad in a remote desktop client? Can you report how well it works clicking around in the Windows environment?
markman is offline   Reply With Quote
Old 03-27-2020, 12:24 PM   #315
psg
Member#: 81549
I have an OG Magic Trackpad and OG Magic Mouse, and for some (seemingly) arbitrary reason Apple decided not to allow their older Bluetooth mice and trackpads work with gestures/scrolling. Magic Mouse 2 and Magic Trackpad 2 are the only ones fully supported, then your mileage may vary with third party stuff.
With the original Magic Trackpad, I can click around on the screen. But since I have to touch the screen to scroll, switch apps, do anything...it's useless to me.
https://support.apple.com/en-us/HT211009
FS : The New iPad (aka iPad 3) rcl1221 MWSOC Private Classifieds 1 03-17-2012 02:15 AM
FS : (IL) The New iPad (aka iPad 3) rcl1221 Non-Subaru Stuff 0 03-16-2012 06:42 PM
FS : ipad 2 16gb wifi BNIB or ipad 1 32gb wifi gotti Non-Subaru Stuff 2 03-03-2012 05:24 PM
The "I Want an iPad in my Subie" Thread jr4284 Car Audio, Video & Security 746 11-19-2011 12:52 PM
Apple iPad BlackBeastie Off-Topic 4226 03-02-2011 01:19 PM
