Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2020
Old 03-24-2020, 11:56 AM   #1
86Dreams
Member#: 385256
V7 S204
'19 Giulia Q4
Default Steering wheel off center
Hi all. Wondering if anyone has an opinion on this one.
For as long as I've owned my 02 wrx, the steering wheel while driving straight has been a couple of degrees clockwise from center. I am going to replace the steering rack soon and would like to fix this if possible. My question is if there is a way to tell if the off centered wheel is a result of a misaligned clock spring or misaligned steering column linkage?
Any thiughts?
86Dreams is offline   Reply With Quote
Old 03-24-2020, 05:46 PM   #2
Bansheeboy11
Member#: 182415
1999 RS
Its probably your tie rods not being evenly adjusted from alignments over the years, easy fix. If its bad, you can remove/realign the splines on the coupler and/or the steering wheel itself
Bansheeboy11 is offline   Reply With Quote
Old 03-24-2020, 05:56 PM   #3
Muffin15
Member#: 326958
2006 Impreza WRX
San Remo Red
You can also check how many turns both ways lock-to-lock it takes to reach maximum steering angle from being straight (wheels straight, not steering wheel). But as mentioned already, a tie-rod adjustment should be able to take care of small amounts of difference. Straightening the wheel is one of the first steps of doing an alignment
Muffin15 is offline   Reply With Quote
Old 03-24-2020, 09:24 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
if you get the car aligned, they will straighten the steering wheel, as well (adjusting the outer tie-rod ends to center it)
