Welcome to the North American Subaru Impreza Owners Club Monday January 22, 2018
Old 11-08-2002, 01:07 AM   #1
bigbuyer2477
Member#: 6604
2006 Impreza WRX STi
Black/Pearl Black
Default Having trouble running the UTEC
Just installed my stage 2 tonight, but it doesn't seem like it's running correctly.
The boost is lagging, and it takes considerable longer to reach even 14 psi. I had the map selector on "0" like they said it was suppose to be, but I could be wrong. No check engine light and the car runs, so I assume the UTEC was connected properly.
Does anyone know what the selector # should be when running stage 2? Also, the grounding wire, where is it suppose to be pluged in? Am I suppose to connect the wire INTO the grounding plug, or am i suppose to just have one end of it be attached to any part of the UTEC and the other end connected to the chasis?
Please help.
Thanks
bigbuyer2477 is offline   Reply With Quote
Old 11-08-2002, 02:17 AM   #2
smskier
Member#: 20061
02 Subaru WRX
stage 0 is stock. log into the utec and see if they have some other maps in there. if you told them to load a stage 2 map on there i think they prolly threw it in under map 1 which means you need to select (1) on the red selector.
also when you change to other maps, and you put your key in the ON position your CEL light will blink the map number before it goes solid.
for the grounding wire, you plug the ushaped into the back of the utec where theres a little hole to screw it down. then run it under your carpet and threw the center console and unscrew your front left bolt on your passenger seat track, and screw it in there.
smskier is offline   Reply With Quote
Old 11-08-2002, 02:46 AM   #3
bigbuyer2477
Member#: 6604
Black/Pearl Black
I'll try to change it this weekend, but what does running in "0" do? Does it just run on the stock ECU's maps instead? I hope that explains why the car doesn't run so well. The Unichip had more umph than the UTEC and turboback exhaust. Also, I had the u shaped tip screwed onto a part of the UTEC and had the other end of the wire grounded to a chasis ground under the carpet. You think that might have something to do with it?
Old 11-08-2002, 03:01 AM   #4
ScoobieSnaX
Member#: 10844
2004 Acura TL Navi
Pearl
You're on the wrong selector. Don't use "0". Switch it to #1. Step 18 of the manual states that "0" is used for the remote switch and shift light. Its also "stock mode" as stated in step 2 of the Operation (first start up) section.
Dude, take the time to read that manual FRONT to BACK....its worth it. You don't want to mess up your car!!
ScoobieSnaX is offline   Reply With Quote
Old 11-08-2002, 11:34 AM   #5
bigbuyer2477
Member#: 6604
Black/Pearl Black
I did, but the fact that it said "stock" implied that's what the UTEC's default setting should be. And since it has like 5 selectors I didn't know which number they loaded the map into, and I didn't want to assume it was going to be #1.
Well, at least #0 is running the stock ECU map, and since I only have the turboback exhaust on the car it will be OK until I change it this weekend.
Thanks for the help.
Old 11-08-2002, 01:02 PM   #6
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Do you have a laptop or any computer for that matter? If you plug into the serial port on the utec you can see where the stage 2 map is located. On my car it was in the 2nd position. As
Old 11-08-2002, 07:04 PM   #7
jjunior887
Member#: 16738
2015 WRX Limited
CWP
You guys should take it easy on this guy he's learning just like the rest of us. I know enough to get by but it's still confusing at times so lighten up a bit. Any way the 0 selection is syock as in it uses all the ECU's parameters for everything your stage 2 map should be on "1". Like everyone else said log in with your laptop to make sure. BTW you might want to check out www.wrxhackers.com if you havn't already people are a little bit more understanding for what seem like simple or stupid questions to someone else. Good Luck and happy tuning-James
jjunior887 is offline   Reply With Quote
Old 11-08-2002, 08:28 PM   #8
z&cobb
Member#: 12344
2002 2JC
blue
Well, it was a tad confusing. I just left it on with position 1 which was how I received the UTEC, along with the written note "stg 2".
I noticed that as before, The "ABC is not necessary..." For me it is necessary.
So what do you set the ABC for when you switch back to map 0?
0.09 mPa, or do you leave it as is for your "hot" MAP. Since I don't have the uppipe but do have the efficient TXS TMIC should I stick with 0.115 mPA for stg 2 or set it lower or higher? It is currently set at 0.115 mPa for UTEC stg 2 + TMIC which is where I set if for the Unichip Stage 2 + TMIC.
z&cobb is offline   Reply With Quote
Old 11-08-2002, 08:54 PM   #9
jjunior887
Member#: 16738
2015 WRX Limited
CWP
If your really concerned you could close the ABC completely and it should run off the stock FBC or you could pull it off all together which might be easier. .115 mPa is right around 16.7 psi which shouldn't be a problem unless you were really pickythen you could turn down the ABC a little less than a 1/4 turn. -James
Old 11-08-2002, 09:40 PM   #10
bigbuyer2477
Member#: 6604
Black/Pearl Black
Thanks people.
I am going to hook up my lap top to the UTEC to find out for sure. It came with the map selector on "0" so I thought it was ready to go, but I guess I was wrong. The boost curve of the stock ECU is SO LOUSY!!!!!!
Old 11-09-2002, 12:13 AM   #11
z&cobb
Member#: 12344
2002 2JC
blue
Anyone done the grounding mode on the UTEC? The ground wire looks like some kind of joke. Just kidding.
Old 11-09-2002, 12:53 PM   #12
denverwrz
Member#: 22710
02 wrx
sadona red pearl
Default grounding
I called mark at turboxs on the very issue of grounding. He said there is something like 9 grounds running through the wires of the utec. He says to put the ground onto the screw that is below the only hole in the top case of the utec, but it is not super critical. I have mine grounded into a screw in the case and it works just great.
denverwrz is offline   Reply With Quote
Old 11-09-2002, 01:20 PM   #13
bigbuyer2477
Member#: 6604
Black/Pearl Black
The Stage 2 lives!!!!!!!!!!!!!!!!!!!1
It turned out that my map was stored in #1, and everything is running great now. For some reason they gave me the 93 octane map and I live in California I had to drive down to my nearest 100 octane supplier for a quick fill up, and next week I am taking her in for a custom tuning for 91 CA water petro.
I scared myself last night because it accelerated so much faster, and it was raining like mad. I loved it.
Old 11-09-2002, 02:21 PM   #14
jjunior887
Member#: 16738
2015 WRX Limited
CWP
i think TurboXS only has a Map for 93 at the moment but i believe i read somewhere that you need to take timing down 2-3 degrees accross the board and that should fix it. here's a link to the thread http://forums.nasioc.com/forums/show...hreadid=264889 -James
Old 11-10-2002, 05:11 PM   #15
crazyhorse
Member#: 19502
2010 Impreza with no
scoop. =(
For the 91 octane the reduction of timing should be enough... If you notice any detonation you may need to add a bit more fuel into the map as well. I'm keeping a close eye on my logs now that it's getting a lil cold here in NC. We'll see what happens.
-Tim
www.wrxhackers.com
crazyhorse is offline   Reply With Quote
Have a four port BCS, having trouble finding the right fittings and tubing GRRRR thumpetto007 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-06-2008 04:01 PM
Having trouble with the search engine... SnakesoWnZj00 Newbies & FAQs 3 10-07-2003 05:38 PM
Anybody have trouble running 18's on a GC8 RS? STi-Nane Tire & Wheel 20 05-11-2003 10:34 PM
I'm having trouble controlling the boost IMPBOY Normally Aspirated with bolt-on Forced Induction Powertrain 12 08-24-2001 08:33 PM
Anyone else having trouble searching the General Forum? 8Complex General Forum Archive 3 06-19-2000 08:47 PM
