Welcome to the North American Subaru Impreza Owners Club Monday January 24, 2022
Old 01-14-2022, 11:22 PM   #1
97 Pimpreza
Member#: 123693
2011 WRX Hatch
Exclamation P045x EVAP system code? This may help. Fuel tank pressure sensor location.
I've read a number of OLD posts looking for the physical location of the fuel tank pressure sensor for various models (foresters, WRXs, etc.) while trying to troubleshoot a P045x code (P0453 in my case) and no one ever seems to have found it.
I FOUND IT! And I would imagine its in a similar spot on other models
It is located on the rear passenger side above the upper control arm. if you have skinnier arms you can just reach it.
If I solve my P0453 code I will post my solution. Fingers crossed.
Hope this information is of use to someone since it really would have helped me when I started to off-and-on look for this thing days ago since all diagrams in the manual are SO vague about its location.
Best I can do until I can get my img.nasioc.com account working is this imgur link (you're on your own to get it working though. on PC you can highlight the link and right click then "go to 'url' ")
https://imgur.com/gallery/5PT3lts
[pictures coming soon.... STILL having issues]
97 Pimpreza is offline   Reply With Quote
Old 01-15-2022, 07:37 PM   #2
97 Pimpreza
Member#: 123693
2011 WRX Hatch
Update: Following the service manual, I checked the EVAP_VP (vapor pressure) numbers which should read less than 7.95 kPA with the sensor plugged in (it was reading 8.035 kPa). Then unplugged the tank pressure sensor and checked the readings again and got 8.191 kPa. Per the Subaru service manual this means I have a short somewhere between the tank pressure sensor and ECM. This is going to be fun to fix....
Oh and still having issues adding pictures (img.nasioc.com is refusing to send a confirmation email.....)
Old 01-16-2022, 08:02 PM   #3
97 Pimpreza
Member#: 123693
2011 WRX Hatch
P0453 Update/possibly solved?:
Checked for a short between the fuel tank pressure sensor and ECU.... None found.
Sprayed out the connectors for the fuel tank pressure sensor with contact cleaner and reattached everything.
Took it for a test drive (about 10 miles) and the code hasn't come back yet. It was reappearing within 5 miles before so possible issue was a bad contact (assuming it doesn't come back again)?
Also checked the EVAP_VP numbers again and was reading 15+ kPA. This should be an issue according to the service manual, but no check engine light or codes are present so I'm really not sure what to believe at this point..... EVAP problems suck.
STILL trying to get pictures loaded up here in case anyone needs to find the tank pressure sensor.
Old 01-22-2022, 01:37 AM   #4
97 Pimpreza
Member#: 123693
2011 WRX Hatch
5 days later and still no CEL or code returning so if anyone gets a P0453 like I did, try cleaning the contacts on your fuel tank pressure sensor before diving super deep into the issue and replacing expensive EVAP bits. I think this is the last of my updates until I FINALLY get pictures working and/or the code returns. Hope this info can be of use to someone at some point. If not I'm just talking to myself on a forum.
Old Yesterday, 04:51 PM   #5
Max Capacity
Member#: 149347
05 LGT ,09 SpecB
Black/silver
Let's hope dirty connectors is the simple fix. Kind of chasing the same issue on my 05 Legacy GT wagon.
I've has P0442 and P0457
This may help someone...
https://legacygt.com/forums/showthre...ak-286916.html
Max Capacity is offline   Reply With Quote
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
Powered by Searchlight © 2022 Axivo Inc.
