Welcome to the North American Subaru Impreza Owners Club Tuesday July 17, 2018
Old 02-12-2010, 01:28 AM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default broken bolt doing swap
i have a 94 with a EJ20g... and i already got everything going,
but in the process of putting in the tranny i guess i was really frustrated and i striped the bolt.. and i just tried forcing it in... anyways... about half way through i snapped the nut on the INSIDE of the chassis. and have no way of tightening the dam thing. so i tried filling in the space with E-clips that just go right around the bolt and try to get it as snug as possible...
every time i start going in 1st, the tranny mount bounces fast and makes a lot of noise and shakes the car a lot.
anyways i want to try to make the mount secure... i heard something about helicoil... but i dont think that will work. since its in a hallow spot. i will post pics later...
any ideas?
azn0boi04 is offline   Reply With Quote
Old 02-12-2010, 02:09 AM   #2
bl_easy
Member#: 91407
Ver. 2 WRX STi wagon
BRetty green
Cut it open, weld a nut on the inside. Install bolt.
bl_easy is offline   Reply With Quote
Old 02-12-2010, 02:19 AM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
the metal is really thick... i thought about doing this... but i dont know what will cut through it... any idea? we have an air compressor and a welder and alot of tools...i dont know if a cutting wheel will cut through it... unless i use like 5 blades... idk.. it is an idea tho...
Old 02-12-2010, 04:16 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Cut it open from the inside silly rabbit...... The metal is not that thick, or it would've been tapped for threads instead of barely tackwelding a stupid nut inside.
Cut the bolt off first. Knock the piece inside up and out of your way. Drill a small hole up through the center of the hole and barely into the body. Now go inside and pull back the carpet to find the hole. Once you find it, cut a 3 sided "flap" big enough to work with and peel it open. Remove the cut off bolt and crossthreaded captive nut. Replace with a suitably sized nut and bolt, then close the flap. Tape it to seal it, or weld the nut in place and weld the flap shut.
Done.
Jay Storm
been there....done that.....
Old 02-13-2010, 11:38 AM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
ok.. sweet thanks... sounds like ill spend a day doing this soon... its annoying as hell when it shakes... makes my car sound like CRApp...
Broken Bolt.... What do I do???? Wrx-WannaB Brakes, Steering & Suspension 7 06-11-2007 12:21 PM
broken bolt - now what? voam Brakes, Steering & Suspension 6 10-10-2004 10:29 PM
removing broken bolt Schlogen Service & Maintenance 11 06-21-2004 10:28 PM
broken bolt... Schlogen Normally Aspirated Powertrain 6 06-16-2004 11:00 PM
broken bolt on the wheel hub tdxflex Brakes, Steering & Suspension 4 10-21-2002 02:12 PM
