Welcome to the North American Subaru Impreza Owners Club Monday July 16, 2018
Old 08-01-2006, 01:49 PM   #1
redgrocerygetter
Member#: 42044
1998 Legacy GT
Default swap question
what all is envolved in swaping a 2000 SOHC into a 98 legacy gt that had a DOHC? I need a engin bad and wanted to know if this was a good Idea or should I just stick to trying to find a 2.5 DOHC. Also wanted to know maybe some pros and cons of either the SOCH vs. DOHC. Thanks for any info. Also would just using the new block to the old heads work? That's where the problem with my old engine is is in the Block (belived it to be a bent rod). Thanks again for any help.
Aaron
redgrocerygetter is offline   Reply With Quote
Old 08-01-2006, 10:35 PM   #2
redgrocerygetter
Member#: 42044
1998 Legacy GT
bump...
Old 08-02-2006, 11:51 AM   #3
Jaxx
Member#: 177
The 93 W/EJ20K-sold
Subaru-less :(
sohc 2.0 was never sold in the US ..
wait for a 2.5
Old 08-02-2006, 12:52 PM   #4
redgrocerygetter
Member#: 42044
1998 Legacy GT
I know there are no 2.0 SOHCs. Just asking about the swap for DOHC to SOHC. Is there an advatage to this or should I just try and look for an engine that's more closer to a model year and is a DOHC?
Old 08-02-2006, 02:11 PM   #5
Kraziken
Member#: 38629
1999 Legacy GT (STI)
I can't recall the advantages, but if you're just looking to get a motor to get back up and running, I think finding similar year model engine is the way to go.
Kraziken is offline   Reply With Quote
Old 08-03-2006, 11:00 AM   #6
redgrocerygetter
Member#: 42044
1998 Legacy GT
ok thanks guys.
Old 08-03-2006, 04:55 PM   #7
Kraziken
Member#: 38629
The only advantage I can think is the whole head gasket issue. But if you install the newer style head gaskets while our installing the DOHC motor, you should be good to go.
My local mechanic says he hasn't seen any issues with the redesigned gaskets.
Old 08-03-2006, 05:33 PM   #8
FSRBIKER
Member#: 112753
2005 Outback XT
You will have a huge amount of wiring to due for the engine and ECU. I bought my 2.5 DOHC from these guys, $920 to my door. http://www.tigerjapanese.com/product...roducts_id=394
FSRBIKER is offline   Reply With Quote
Old 08-03-2006, 06:13 PM   #9
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Use the shortblock from the SOHC engine and mate it to your heads. That's the path of least resistance. And those SOHC heads are worth $250-300 if you sell them off. They are good heads, but are far to difficult to get to work in your car. Your DOHC heads are jsut as good...
Old 08-03-2006, 07:40 PM   #10
Kraziken
Member#: 38629
Yeah, that would be my concern.
For the wiring hassle, you might as well go with a turbo motor. IMHO.
Old 08-04-2006, 05:01 PM   #11
redgrocerygetter
Member#: 42044
1998 Legacy GT
sweet. That's the answers I was looking for. Thanks.
Old 02-08-2010, 09:31 PM   #12
crazskir
Member#: 237806
Ok to continue……….I have a 2001 legacy gt sw, with a non turbo 2.5…..I’m am looking to do an engine swap……does any one now what engines would fit in my car. I was looking at the 2.5spec b (290hp) or a 2.2 or 2.5 wrx engine……..then what transmissions should be paired up with the engine?????? And suggestions I already have a fully custom exhaust headers back.
crazskir is offline   Reply With Quote
2002 WRX swap into 2001 RS swap question dtl1218 Subaru Conversions 14 08-13-2008 01:58 PM
dash swap and motor swap questions aka_tur Subaru Conversions 6 02-27-2007 05:21 PM
EJ20G front clip swap swap questions... 970subaru Subaru Conversions 24 01-01-2005 01:09 AM
Legacy spring swapping question... Kevin H. Legacy Forum 0 11-05-1999 08:07 AM
