05-17-2019, 02:46 PM | #1 |
Member#: 318670
SCIC
Vehicle:2000 Legacy Outback White |
Spontaneous Alarm
Hi All,
98 Legacy Outback alarm goes off spontaneously (thank god just the lights) its draining the battery so now I am stuck unplugging the security system when I get out of the car so that the car, which means the FOB doesnt work and I have to reach down to plug it back in every time I get in the car in order to start it. Looking for a way to disable the alarm without disabling the fob...etc TIA for the help! (unrelated?? side note: recently replaced the starter, and wasn't having this issue before I did that.... )
05-18-2019, 03:54 PM | #2 |
Member#: 472037
Vehicle:2018 WRX Limited CWP |
Bad ground?
05-20-2019, 12:33 AM | #3 |
Member#: 318670
SCIC
05-20-2019, 04:35 AM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
I assume you disconnected the battery when you replaced the starter?
If this is the OEM alarm, it will come up in panic mode when power has been disconnected. There should be a button under the dash, if you press it with the key on it will cancel the panic mode and stop the alarm. |
05-20-2019, 10:37 AM | #5 | |
Member#: 318670
SCIC
05-21-2019, 11:31 PM | #6 |
Member#: 318670
SCIC
Confirmed today, using the button under the dash does not prevent the alarm from spontaneously triggering... any other ideas?
05-25-2019, 11:50 AM | #7 |
Member#: 318670
SCIC
annnnnndddd bump? Still having to unplug the security console every time I leave the car... any ideas?
