Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 03-16-2006, 01:27 PM   #1
wrxtuner13
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
Cool realtime map
How would i remove the realtime map without unhooking the battery? i loaded the economy realtime map and i have the stg2 93 in base map. and i heard it's not good to have the same base and realtime map in.
thanx
-jeremey
wrxtuner13 is offline   Reply With Quote
Old 03-16-2006, 02:39 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Just load the stage 2 RT map on like you did the econo map... nothing wrong with doing that. That's is how it's supposed to be used.
wrxdrvr is offline   Reply With Quote
Old 03-16-2006, 04:46 PM   #3
wrxtuner13
Member#: 88521
2010 WRX Sedan
390whp/398wtq E85
k thanx
Old 03-18-2006, 11:25 AM   #4
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
I believe wha some peopel are reffering to is when you FIRST flash the base map or reconnect teh battery. Some people have said not to flash the same RT map on top of the base map. But once you change it it shoudl be fine.
scoobdude is offline   Reply With Quote
Old 03-25-2006, 09:23 AM   #5
Hypnotk
Member#: 93307
05 WRX
If my base map is stage 1 93 what is the benefit of running a real time stage 1 93...or is there one?
Hypnotk is offline   Reply With Quote
Old 03-25-2006, 09:59 AM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
real time maps only change your boost/timing/rev limit/ WG duty cycle.
The only time you will need to put that real time map on is when you have changed over to another real time map (valet mode/ antitheft mode etc). But if you never do that there is no reason to load it. Even if you disconnect the battery.
Old 03-25-2006, 12:27 PM   #7
Payback
Member#: 41328
2003 WRX Sedan
SOLD - 2/07
Cobb really needs to be more clear in the instructions. I was confused about this when I first got my AccessPort and I got one of the early ones. It is a very, very common question. You would think by now that the instructions would be revised.
Payback is offline   Reply With Quote
Old 03-25-2006, 09:12 PM   #8
Old 03-25-2006, 12:29 PM   #9
Hypnotk
Member#: 93307
05 WRX
Thx you guys..now I understand
16g base map and realtime map. subietech420 AccessPort 1 09-15-2006 10:19 PM
realtime map vs base map dodiox Engine Management & Tuning 25 11-19-2005 05:58 PM
Should i be using the stage 1 realtime map or just use the base map ? wrxhunter Engine Management & Tuning 2 06-10-2005 01:38 PM
Base map and Realtime map aakrusen Engine Management & Tuning 13 05-29-2005 12:43 PM
Base map, Realtime map CaptainMorgan Engine Management & Tuning 2 05-15-2005 01:45 PM
