Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 01-22-2010, 11:37 PM   #1
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Default Planning on going to the dyno to tune....What should I do before I get there?
I have an 02 Wagon w/ 2.0L running on UTEC/e85. I have tuned it myself using the road and LC-1/UTI.
My plugs are new (10k miles on iridiums), just did 90k maintence + timing belt. Things seem to be in good nick, eats just a bit of oil over 5k miles.
What do you guys do to prepare to go to dyno tune? I think this place runs on hourly rates, so I want to make sure I'm ready to go with no hic-hups.
SurfWagon is offline   Reply With Quote
Old 01-23-2010, 12:07 AM   #2
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
Did you do a compression test when you changed your plugs?
Subian is offline   Reply With Quote
Old 01-23-2010, 12:33 AM   #3
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
check your oil and fill your gas tank, check coolant levels and bring your wallet. oh yeah and be prepared to sign your car away....release form stating they are not reliable if your car explodes on the dyno.
krambte79 is offline   Reply With Quote
Old 01-23-2010, 01:14 AM   #4
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
No, I haven't done a compression test. I do have the tools for it, just only used it for my Jeep because I had some weird issues with it.
Is this just a good thing to do....or absolutely neccessary?
I am a little worried about letting someone "drive" the car. I've only let one other person drive it and he was gentle to it (on autox test&tune).
Old 01-23-2010, 09:35 AM   #5
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Found this good article by GRM.
http://grassrootsmotorsports.com/articles/dyno-dos/
My goal for the session is to work on spool and max torque. Right now my boost is set at 19psi, and I don't think I want to go any higher than that, but I can play with timing. I really don't know how to tune timing on the street well. I watch EGRs, but have only really been able to say "too much, i got some knock". Nothing more.
Old 01-23-2010, 10:10 AM   #6
sidewayz
Member#: 5810
2001 S366 2.5RS
sidewayz is offline   Reply With Quote
Old 01-23-2010, 12:43 PM   #7
SurfWagon
Member#: 156861
2005 LGT Wagon 5MT
swp, 16g
Thanks! Pasted in here for future viewers
Dyno Tuning Checklist v1.00
Sourced from Cobb Tuning's Technical Articles.
1st = Mechanical Issues
You need to make sure you are tuning a healthy engine.
We suggest you complete a compression test prior to your tuning appointment. Typical compression test results should be as follows:
•8:1-8.5:1 compression: 150-170 psi per cylinder
•8.5:1~9.5:1 compression: 170-210 psi per cylinder
•9.5:1~11:1 compression: 210-275 psi per cylinder
•11:1+ compression: 250+ per cylinder (highly depends on cams being used)
These pressure values will be less at higher elevations. Compression Tests should be performed on a warm engine and the throttle should be held fully open while testing. YOU SHOULD NOT have more than 20psi variance between cylinders. If you have one cylinder that is showing a greater variance than 20psi then you will need to repair that problem prior to your dyno tuning appointment. The additional cylinder pressure realized after a custom tune will only exploit the existing mechanical problem causing further and usually more severe engine failure.
A Cylinder Leakdown Tests can also be performed on a warm engine. YOU SHOULD NOT have a cylinder leakage of more than 7% in any cylinder. If you do, then you will need to further test to see where the air is leaking from and to; intake valve seat, exhaust valve seat, head gasket, piston rings, etc. Please know that even if these test results look good, you can still have an engine that has some mechanical damage and the tuner/calibrator should be able to recognize the systems and consult with you about the consequences of further tuning your engine.
2nd = MAF, Turbo, Vacuum Lines, & Intercooler Systems
Make sure that your intake, vacuum lines, and intercooler piping are sealed when under vacuum and sealed when pressurized like when running full boost. This is super critical especially if the vehicle is using a MASS AIR FLOW sensor to meter air. A vacuum leak after the MAF sensor, but prior to the turbo will make the engine run leaner. A boost leak after the turbo, but before the engine will make the engine run richer. Major leaks can usually be found while dyno tuning because the data will look incorrect, but minor leaks are very difficult to find so please pressure test these parts of your intercooler system.
•Make sure you have secured all of your vacuum lines and your intercooler piping so they do not blow off at the tuning appointment.
•Make sure all of the bolts are tightened, in particular, the exhaust system bolts. An exhaust leak prior to the turbo will lose power and make part throttle tuning almost impossible.
•Make sure the blow off valve properly lubricated, seals tight, and is functioning properly.
•Be sure to use the proper oil feed and return lines and that they are installed properly.
•Turbo shaft play. You cannot expect a turbo to operate properly if has worn excessively, have the turbo rebuilt or buy a new one.
3rd = General Pre-Tuning Maintenance
•Make sure all fluid levels are up to par; this includes engine oil, anti-freeze, transmission fluid, differential/transfer case fluid, brake fluid, clutch hydraulic fluid, etc.
•Alignment and wheel balancing, the vehicle must be able to drive straight if it is to be tuned on a chassis dyno.
•Bleed the coolant system before you come for the appointment. If your engine has an overheating problem, DO NOT come for the appointment. Because we cannot tune a car that is overheating.
•The vehicle must be streetable and the driveline and drivetrain systems must be in tact and safe, if you have any clicking CV joints then repair them prior to the tuning appointment. Be sure to inspect your wheel bearings as well. The same stresses that your vehicles sees on the street are seen on the chassis dyno, although a failure on the chassis dyno puts your vehicle and the tuner/calibrator in a very unsafe environment until the vehicle and chassis dyno come to a complete stop.
•Inspect and replace your fuel filter (if need be), any blockage in fuel flow to the engine will cause pre-mature fuel pump wear and can lead to engine damage if the fuel filter clog causes a lean burn condition. Make sure that you have the proper fuel octane and enough fuel to complete the tune. If you want a tune for race gas, we suggest you schedule two different tunes because your engine will most likely be heat soaked after the pump gas tune and will need significant time to cool off. Fuel Pumps, you should not have installed the fuel pump if you see dirt, debris, or rust in the tank. If there is rust in the tank, replace the fuel tank. You will starve the engine of fuel if you leave junk in the fuel tank.
•If your engine oil and filter have been run for more than 3,000 miles, please replace the filter and your engine oil.
•If your spark plugs (& wires) have more than 5,000 miles on them (if they are copper plugs) or 15,000 miles on them (if they are iridium/platinum), please replace them with new ones. Be sure to gap them appropriately and to use a small amount of anti-seize when installing the new spark plugs. Bring extra spark plugs, during tuning it is possible to foul the plugs to a point where they will need to be replaced. New spark plugs are NOT included in the tuning rate.
•Make sure you have appropriately functioning brakes on the vehicle that are suited for your power level. We drive each vehicle we tune on the street after the dyno tune to verify proper operation. We should feel safe riding in your car after the tune.
•IF YOUR VEHICLE IS OVER 5 YEARS OLD, we highly suggest you remove your fuel injectors and have them cleaned and calibrated by an injector cleaning facility like DeatschWerks, RC Engineering, or WitchHunter, Since the tuner/calibrator is only metering the Lambda (Air/Fuel Ratio) from one location the assumption is that all fuel injectors are flowing the same rate. If you have one poorly flowing fuel injector, then it is possible to further damage your engine by completing a dyno tune.
•If your vehicle is over 5 years old or is driven in a humid oceanic environment, we suggest you clean your engine grounds and grounding attachment points. A vehicles electrical signals need to be as clean as possible so the ECM has good signals coming in and going out. The engine harness should have no exposed wires. Also, do no twist and tape wires together. Take the time to properly crimp or solder them together!
•Battery/Alternator - Make sure these items are strong and operating properly.
•Check Engine Lights or Codes - Do not come for a tuning appointment if you a check engine light is on. Please have this problem diagnosed and fixed prior to your appointment.
Old 01-23-2010, 01:31 PM   #8
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
There are a billion pre-dyno checklists out there...
http://www.google.com/search?q=pre+dyno+checklist
What mods should I do before I get a cobb accessport v2? pfinch117 Newbies & FAQs 13 10-17-2009 11:31 AM
Went to the Dyno to get a decent baseline bape-ape Normally Aspirated Powertrain 13 01-26-2009 10:06 PM
Bigger injectors and fuel pump...Can I drive it to the Dyno for tuning? xcdhridr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-26-2008 10:33 AM
Almost 35k, what should I do before the warranty is up? bren wrx New England Impreza Club Forum -- NESIC 10 07-01-2005 05:34 PM
this is for the e-town guys.....what should i do?? spt_impreza Canada Region Forum 15 02-07-2001 05:30 PM
