Welcome to the North American Subaru Impreza Owners Club Sunday May 27, 2018
Old 05-13-2005, 10:56 AM   #1
CaptainMorgan
Member#: 24660
2005 FXT
Default Base map, Realtime map
Can someone explain the differences between a base map and realtime map on the AP to a map on the UTEC? From my understanding, a base map on the AP would be akin to having a chip reflash. A Realtime map on the AP and a UTEC map would be very similar to each other, doing about the same job. Is this correct in thinking? Would it be possible to tune a UTEC to control the car similar to a reflash? Thanks
CaptainMorgan is offline   Reply With Quote
Old 05-15-2005, 12:18 PM   #2
stentorian
Member#: 12959
2017 Focus RS
Check their websites . This is from the Cobb site:
Base Map - Refers to any map that is flashed into the ECU.
Real Time - Refers to a Real Time switching map that can be used without flashing the ECU
-Joe
stentorian is offline   Reply With Quote
Old 05-15-2005, 12:45 PM   #3
hondaeater69
Member#: 60324
1998 RS
you're not making a correct relation between access ecu maps and utec maps. they cannot be compared. RT maps were created so that data can be manipulated in real time, while the car is running, without flashing the ECU with the information to see how the car responds to the new info. THere is no 'flash' with UTEC.
base or realtime map? CryderSpeed AccessPort 7 06-24-2006 09:17 PM
Base Vs. Realtime maps - CAP NattiRex Newbies & FAQs 19 06-02-2006 03:24 PM
realtime map vs base map dodiox Engine Management & Tuning 25 11-19-2005 04:58 PM
Should i be using the stage 1 realtime map or just use the base map ? wrxhunter Engine Management & Tuning 2 06-10-2005 12:38 PM
Base map and Realtime map aakrusen Engine Management & Tuning 13 05-29-2005 11:43 AM
