Welcome to the North American Subaru Impreza Owners Club Friday September 24, 2021
Old 07-25-2021, 10:06 PM   #1
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Default Why am I running through Bosch 4.2 LSU wideband sensors?
I posted this in the "electrical and lighting" category as well and don't know if this or that thread is the right one
So this is my second Bosch 4.2 LSU wideband sensor in about a 6 month period and im wondering if my exhaust has anything to do with it?
I'm running a rotated setup and my downpipe is touching the firewall some and im assuming causing vibrations in the exhaust and in turn the sensor as well. Could the exhaust vibrations contribute to sensor failing? From my understanding the sensors are ceramic based to deal with the harsh environments of the exhaust system and fragile so to say. Let me know your thoughts and opinions!
WRXXXED is offline   Reply With Quote
Old 07-26-2021, 06:13 AM   #2
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Where is the sensor positioned on the pipe? And is the bung on the top, bottom or side of the pipe?
snow_bound26 is online now   Reply With Quote
Old 07-26-2021, 07:55 AM   #3
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
^^^ my first questions were also going to be its placement on the exhaust. My first thought was water/condensation.
Old 07-26-2021, 08:39 AM   #4
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
The sensor is located about 12-14 inches down from the turbo. Its on the side of the downpipe. The bung is welded as the pipe goes down vertically so the bung is fitted horizontally
Old 07-26-2021, 09:13 AM   #5
snow_bound26
Member#: 395793
2005 92x Aero
Beige
It could potentially be catching enough moisture to cause it to fail. They are quite sensitive to condensation. Typically it is suggested to weld the bung in a horizontal section of pipe and angle the sensor to face as downward as possible so it can't collect as much condensation.
It's not so much when the car is running, but what happens in the pipe after it's shut off
Old 07-26-2021, 01:05 PM   #6
JSR84
Member#: 469585
2009 STi
What type of controller are you using. Please say Innovate.
JSR84 is offline   Reply With Quote
Old 07-26-2021, 01:42 PM   #7
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
It's a AEM uego wideband
Old 07-26-2021, 01:44 PM   #8
JSR84
Member#: 469585
2009 STi
Ok, there goes my theory. Ha
Old 07-26-2021, 01:46 PM   #9
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Thata good to know. I feel like I've actually heard that info somewhere before but I don't know why I didn't think of it. I'll have to weld in a new one somewhere else, there's a minimum distance from the exhaust housing they recommend right? I would love to just put it right behind the turbo so it's such easy acess but I'm not sure if the exhaust turbulence coming out of the turbo would cause it to read off. I don't see why it would but I guess you never know.
Old 07-26-2021, 02:34 PM   #10
JSR84
Member#: 469585
2009 STi
I've had mine about 3 inches from the V Band for about 2 years.
Old 07-26-2021, 03:09 PM   #11
undyjr
Member#: 459692
2019 WRX STI
silica black
The bung on my Grimmspeed down pipe is inches from the turbine outlet and angled down for drainage.
undyjr is offline   Reply With Quote
Old 07-26-2021, 03:37 PM   #12
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Lmao, yeah on my project car I was running a innovate controller (LC-1) and it bricked on me... just went with an AEM on that car as well lol, from everyone's responses about having their sensors just inches from the turbine I'm going to weld a new bung there and hope for the best.
Thanks everyone
Old 07-26-2021, 08:26 PM   #13
blurred
Member#: 47143
AEM mounted to the side about 5-6" from the turbine. Still running after 35-40k miles
blurred is offline   Reply With Quote
Old 07-31-2021, 07:54 AM   #14
TurboQueef
Member#: 86700
2005 STI
Silver/Black,[email protected]
I am chasing issues with frying the sensor in my FXT. I am running Innovate controllers, tried two different controllers and both the 4.2 and 4.9 sensors. I have changed the sensor location and still burn them out. I am running the old clunker side feed injectors and notice rich spikes every so often and suspect the rich condition is making angry the sensor until it fries.
I run an Innovate in my STi rotated set up with zero issues. It is using the first controller Innovate introduced to the market (LM1).
At any rate, what is your AFR upon start up, idle cruise?
TurboQueef is offline   Reply With Quote
Old 07-31-2021, 02:42 PM   #15
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
With the bad sensor I have now (did the brake clean test and didn't change reading) it's been .4-.6 afrs leaner compared to my AP "AFR sensor 1 ratio" for whatever load is put on the car throughoutthe entire powerband. I have a new sensor but haven't had the time to put that sensor in yet, ill update what those numbers are when the new sensor is put in.
Old 07-31-2021, 11:22 PM   #16
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Supposedly on some of the wideband controllers the wiring is important since you only want it on when car is running...not with car off but key on pretty sure it is something to do with the sensors heating element. I've never had an issue with my zeitronix zt2 but worth looking into
Old 08-01-2021, 04:06 AM   #17
can250
Member#: 452601
I'm just about to install one in my car and this is straight from the instructions sent with the sensor install at least 24" inches from turbo and at a position between 9.00 o'clock and 3.00 o'clock
can250 is offline   Reply With Quote
Old 08-01-2021, 06:36 AM   #18
WRXXXED
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
I have it wired so that the wideband controller is only on when the key is forward in the "accessory" and "on" position, so I should be good there
And interesting, a person here said that their part straight from the manufacturer was only a few inches from the turbine
Old 08-01-2021, 08:32 AM   #19
TurboQueef
Member#: 86700
2005 STI
Somewhat relating to this thread, it may be worth considering by cylinder AFR balancing. Especially if you are making power. I just created a thread to detail my test & result:
https://forums.nasioc.com/forums/sho...4#post46606854
Old 08-25-2021, 01:31 AM   #20
usdmf
Member#: 526173
NGK is a more tolerant, robust wideband. I wouldn't buy another Bosch.
usdmf is offline   Reply With Quote
Old 08-25-2021, 01:57 PM   #21
benflynn
Member#: 515308
They sure last well in a vw. Since 04 I have had to replace one of my 5 innovate Bosch wideband sensors
benflynn is offline   Reply With Quote
