Welcome to the North American Subaru Impreza Owners Club Wednesday February 21, 2018
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 10-17-2017, 10:15 AM   #1
nmeone
Member#: 476201
Default NC 2015 w/fully built motor and high end parts
Phone: 704-228-3783
Price: 37K obo 35,000 obo!
VIN: JF1VA2L63F9824518
Reason for Selling: buying a Tesla
After driving this it makes me realize that this may be a little too much for a daily driver. I also have my Tesla being delivered to me in early next year as well. So it makes it a mute point to have too many cars.
On the exterior this car is 100% stock but it is a definite beast on the inside. It makes 380awhp and 410 torque on 93 pump gas.
Interior is in mint condition as it were new.
I have the title in hand as well. Clean and clear title and clean carfax as well.
The car has 19,920 miles on it right now but will go up as I do drive it from time to time.
A little history on the car. The motor went at 14k for ringland issues. Subaru took it as a warranty but I wanted it beefed up and be able to daily 400 awhp. So subaru provided a brand new block halves, Bolt Kit, Crankshaft and Engine gasket kit. (all records and invoices available up request, about 15 pages and 22K worth of parts. All of which were brought brand new at the time of assembly.)
All of this was then sent to 42 Autosports to build the motor to accommodate the 400 awhp daily driver request on pump gas. It is definitely capable of more but its enough for a DD and to keep it as reliable as possible.
The car currently has 21,120 miles on it and runs great! So the new setup has 5k on it now and has perform flawlessly. Oil was recently changed and looks great.
Car drives and idle like a stock car until you let it loose.
I welcome all serious potential buyers to test drive and do a compression test on the motor for that piece of mind.
Block
Brand New OEM Subaru block halves
Brand New OEM crankshaft
Brand New OEM Seals and gaskets
CP Pistons 99.5mm - coated
Carillo Pro-SA Rods 3/8 WMC hardware
ACL Race Bearings with Coating - Rod set
ACL Race Bearings with coating - main set
ARP head studs
Subaru Smooth timing belt idler
Killer B ultimate Oil pickup tube
Killer B Baffe Windage tray
Head
GSC 33mm (+1mm) o/s exhaust valves (8)
GSC 37mm (+1mm) o/s intake valves (8)
CNC valve seat porting
Perrin Air/Oil separator w/metal fitting upgrades
Clutch
ACT HD clutch kit - 515 TQ
Intake
Cosworth Tumbler Delete housings
Torque Solutions air pump delete plates
Perrin 2.4" turbo inlet hose
Exhaust
Cobb 3" downpipe
Perrin Equal Length @ [540248922:Header]
Perrin catback exhaust
Turbo
Grimmspeed Boost Solenoid
Blouch Dominator 1.5XT-R 83cm
Perrin Turbo Heat Blanket
DEI header Wrap - Titanium
Fuel system
Deutschwerks 65C fuel pump
Deutschwerks 1000cc EV14 fuel injectors
COBB STI Fuel pressure regulator
IAG Fuel Rail and Hoses
Misc
COBB AP V3 tune by 42 autosports in NC
nmeone is offline   Reply With Quote
Old 10-17-2017, 10:17 AM   #2
nmeone
Member#: 476201
https://www.dropbox.com/s/24tc4rcjrk...arfax.pdf?dl=0
here is the build sheet and carfax as well as dyno and invoices
best way to contact me would be to text me at the number listed above!
Old 10-19-2017, 03:16 AM   #3
socrates42
Member Sales Rating: (4)
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
Nicely done! On the fence, but leaning towards making you an offer.
socrates42 is offline   Reply With Quote
Old 10-19-2017, 11:07 AM   #4
nmeone
Member#: 476201
Thanks! Its a great car and i've been slowly putting some miles on it! Blast to drive.
has 20,130 miles right now.
Old 10-19-2017, 11:54 AM   #5
WRXXXED
Member Sales Rating: (1)
Member#: 432652
2010 Subaru WRX STI
61K (Gray)
Dyno and dyno numbers?
WRXXXED is offline   Reply With Quote
Old 10-19-2017, 03:29 PM   #6
nmeone
Member#: 476201
I attached all invoices, dyno graph on the dropbox link on the second post.
Old 10-24-2017, 10:21 AM   #7
nmeone
Member#: 476201
Just got back from Overseas bump!
Old 11-01-2017, 05:01 PM   #8
nmeone
Member#: 476201
All Pm's replied! Make offers!
Old 11-08-2017, 05:57 PM   #9
nmeone
Member#: 476201
bump!
Old 11-10-2017, 06:27 PM   #10
nmeone
Member#: 476201
bump! I might consider a part out if anyone is interested. Pretty much motor and all!
Old 11-10-2017, 06:36 PM   #11
socrates42
Member#: 7747
2004 WRX 5door 5spd
08 E90 M3
You have pm
Old 11-10-2017, 07:06 PM   #12
SubeeWRX
Member#: 351733
Sonic Yellow
Beautiful car! Just picked up a white 18 sti myself. Curious question if you have the time to answer - you have any idea what caused the ringlands to go out so early? Or was it just bad luck with the motor?
SubeeWRX is offline   Reply With Quote
Old 11-12-2017, 05:24 PM   #13
nmeone
Member#: 476201
Car was stock when ringlands went out. I believe its a design defect with these cars/bad luck. Its a known issue.
A built motor is the best precaution you can take. Reliable and gives you a little more power safely!
Weekend bump and all PM replied.
Old 11-14-2017, 11:14 AM   #14
SubeeWRX
Member#: 351733
Sonic Yellow
Appreciate the reply man! Guess I will just have to hope for the best and build motor when warranty is up. GLWS!
Old 11-19-2017, 09:05 PM   #15
tytek
Member#: 53128
05 LGT, 360whp
Atlantic blue
Very nice STI!
Were the modifications done by the original owner since the receipts show a date prior to Feb, 2017 and Carfax shows a 2nd owner after that?
What boost is the car running currently? What fuel was it tuned for? Are the tires original and if not, how many miles on them and what brand are they?
tytek is offline   Reply With Quote
Old 11-19-2017, 10:29 PM   #16
nmeone
Member#: 476201
Yes it was done by original owner who was a local. She is car fanatic.
Its peaking at 23.5 psi. Tuned on 93. On the second set of tires which are OEM Dunlop tires with less then 3k on it.
My tesla is coming in soon! so need it gone!
Old 11-20-2017, 09:23 PM   #17
tytek
Member#: 53128
05 LGT, 360whp
Atlantic blue
Thanks for the reply. It is a very nice build and a super clean car.
Does it have a clear bra? Any paint chips on the front or the rear quarters?
Old 11-21-2017, 09:59 AM   #18
nmeone
Member#: 476201
No paint chip on front, but then again the car is white so if there is one i can't tell.
no chips on rear quarter either.
No clear bra but the car does have a ceramic coating which helps.
Old 11-26-2017, 08:44 PM   #19
nmeone
Member#: 476201
Bump for price drop!!! 36k!!!
Old 11-28-2017, 10:46 AM   #20
nmeone
Member#: 476201
bump!
Old 11-29-2017, 03:40 PM   #21
nmeone
Member#: 476201
Looks like parting out might be my best option for now.
anyone want a fully built motor and mods for your stock motor and parts + cash?
Old 11-29-2017, 03:46 PM   #22
acnaibcalderon
Member#: 478396
beautiful!
acnaibcalderon is offline   Reply With Quote
Old 11-30-2017, 10:41 AM   #23
nmeone
Member#: 476201
thanks! someone will appreciate it as much as i do!
Old 12-04-2017, 01:42 AM   #24
nmeone
Member#: 476201
bump and pm replied.
Old 12-07-2017, 12:52 AM   #25
nmeone
Member#: 476201
