Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 09-05-2006, 10:40 AM   #1
ScoobySnacker
Member#: 105303
2003 WRX
Thumbs down Mobil 1 gear oil sucks...now what?
So i changed my trans fluid this weekend and put some mobil 1 synthetic oil in(75w 90). 1st gear is very hard to get into without grinding. Also the shift from 1st to 2nd takes some muscle.
So, i want to chage it out and im not sure where to go now. I have heard great things about redline's trans fluid, but im not sure which one to get. I have heard that the gl-5 oil that does not contain the friction modifiers is the way to go. This type of fluid:
http://www.redlineoil.com/products_g...57&subcatID=18
I was also reading unabomber's FAQ on something and noticed at the bottom that he has a listing of everything in his car. He uses lightweight shockproof trans fluid, and swears it is the best. This type of fluid:
http://www.redlineoil.com/products_g...61&subcatID=20
So bottom line, i need to change this mobil 1 crap out and get some good stuff in there before i burn out the syncros. What would you suggest? Thanks
ScoobySnacker is offline   Reply With Quote
Old 09-05-2006, 11:50 AM   #2
-OneWay-
Member#: 70128
Motul Gear300
It's good stuff!
-OneWay- is offline   Reply With Quote
Old 09-05-2006, 11:56 AM   #3
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Two most popular:
Uncle Scotty's Cocktail
100% lightweight shockproof
Uncle Scotty's is much cheaper though, so go with it.
Old 09-05-2006, 12:55 PM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
The other consideration is the milage on your car. If you're still in the powertrain warranty, you need that all important trail of receipts showing you bought 75w90 GL5. Right now, to eliminate arguments with the dealer, I'm running Redline 75w90NS in the tranny and Redline 75w90 in the rear diff. It is an interesting change from stock. The gear lever is MUCH easier to move, especially on cold mornings. The OE fill was actually kind of hard to deal with in the winter. The downside is that you can really feel what the inside of your box is machined like, and let me tell you, it's not pretty. Notchy doesn't even begin to describe it. Also, if you're a drag racer used to slamming the stick from one gear to the next, you will be unhappy. There's definitly less friction for the synchros to work with. However, if you use proper shifting technique, the box shifts fast and easy. I'm not sure how this works, but it definitly feels better when you're pressing on and really working the box than when you're just puttering down the high street.
Am I happy with it? Yeah, I guess so. It works adaquately and shifts easier when cold. Will I continue to run it when my warranty is up? No, I'll switch to the Cocktail I think.
Conclusion: The Redline synths listed above work well enough and meet warranty requirements. If you're under warranty, I recommend them. If you're not under warranty, try them, and try the cocktail too.
Old 09-05-2006, 02:04 PM   #5
ScoobySnacker
Member#: 105303
2003 WRX
Well, im out of the warranty period so that is not an issue. I just want some trans fluid that works I am going to look into the cocktail mix and see what that is all about. Thanks guys!
Old 09-05-2006, 05:28 PM   #6
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
I use lightweight shockproof. To tell you the truth I expected great things based off of others' testimonies but I didn't notice any difference..
WRXRallyBlue is offline   Reply With Quote
Old 09-06-2006, 08:19 AM   #7
ScoobySnacker
Member#: 105303
2003 WRX
Well, looks like im going to go with the cocktail mix..It is alot cheaper than putting all redline in.
mobil 1 gear oil in WRX 5mt? alacrity024 Off-Topic 40 04-01-2006 04:55 PM
Mobil 1 gear oil for tranny? nix-hex Transmission (AT/MT) & Driveline 11 03-12-2006 09:13 AM
Mobil 75W90 gear oil on 05 Matrix automatic transmission? txl146 Off-Topic 6 11-14-2004 02:06 AM
Cheap Mobil 1 gear oil AlboWRX Transmission (AT/MT) & Driveline 16 12-21-2003 02:23 PM
Mobil 1 gear oil wrxlvr Rocky Mountains Impreza Club Forum -- RMIC 2 12-15-2003 08:05 PM
