Welcome to the North American Subaru Impreza Owners Club Saturday July 21, 2018
Old 11-21-2017, 07:36 AM   #11526
wrxstefan
Member#: 478018
2003 Impreza WRX
Originally Posted by iNfEk View Post
That's good numbers already. What are your goals.
I was wondering if 440-450 is achievable on a safe tune? Don't really wanna go much higher than that.. also dont wanna lose too much reliability.
wrxstefan is offline   Reply With Quote
Old 11-21-2017, 09:01 AM   #11527
08wrx440
Member#: 261040
04 STi
Sold a few things from my twinscroll setup... but I have EJ207 pistons and a VF37 lying around, 30k miles on it before I sent it out to get cleaned / billett wheel.. if anyone is interested. :-)
Happy Thxgiving Nasioc!
08wrx440 is offline   Reply With Quote
Old 11-28-2017, 06:22 PM   #11528
Cobrakai
Member#: 176408
2005 STy
Anyone with a V7 have significant piston slap on cold starts?
I'm hearing a faint knocking noise that's rather disconcerting (IE early stages of rod knock) when the motor is cold and I'm backing up or taking off in first, the noise goes away once the motor is completely warm and doesn't appear in any other gear or RPM range, just post clutch engagement + load.
My higher mileage EJ205 made a similar sound that Irvine Subaru informed me was piston slap, sound went away when the motor was warmed up as well.
Unfortunately I'm the only person in my immediate circle of friends that notices **** like this, two of whom have EJ207 motors.
And to top it off I've exceeded my 30 day "start up" warranty.
"The power of OCD compels you!"
Cobrakai is online now   Reply With Quote
Old 12-08-2017, 05:56 PM   #11529
Master467
Member#: 459849
2002 Legacy GT
89N (titanium pearl)
You're pushing the little 2 liter at 450. People have done 500 but i'm sure they didn't drive with that tune much, or if they did, it didn't last long.
v7 pistons are good, but you can still ringland them. At the amount of boost you need to do that you will probably be close to lifting the head on stock head bolts.
I've always said, if you're content with 400whp, the 2 liters are much nicer daily driving cars than the 2.5's. Buddy has a stock 206 (commonly known as the EJ20TT, incorrectly, but commonly none the less) at 325whp 310ftlbs on E85 with a vf39 and billet comp wheel. Fun, daily drive able, spins tires when it's under 40 degrees F. If you need 400+ to have fun, put a built IAG/Outfront 257 in the thing and call it a day. Have your heads chamber matched and you don't need special hybrid pistons or anything. Head studs, then you have a motor that will hold 700 and you're limited by injector and turbo only.
That's only ~5 grand though, so send it.
Master467 is offline   Reply With Quote
Old 12-08-2017, 06:19 PM   #11530
johnfelstead
Member#: 856
2005 JDM STi
If you are talking flywheel power then that's achievable on the stock engine with the correct turbo and tune.
johnfelstead is offline   Reply With Quote
Old 12-11-2017, 07:52 AM   #11531
Samurai Jack
Member#: 21145
2002 Enemy of Aku
https://www.youtube.com/watch?v=L4VvO1MZYzA
Can't hear a thing on that video. That engine is the quietest I have ever heard.
Did you have the sound on when you recorded
Samurai Jack is offline   Reply With Quote
Old 12-11-2017, 08:46 AM   #11532
Bansheeboy11
Member#: 182415
1999 RS
If your going rotated i have a GT3076 im looking to part ways with, ill trade for the VF37 plus cash if your interested
Bansheeboy11 is offline   Reply With Quote
Old 12-11-2017, 04:18 PM   #11533
Cobrakai
Member#: 176408
2005 STy
Haha yes, it's difficult to capture it with the iphone.
Going to keep enjoying it for the time being and if something develops down the line oh well, I've always wanted to tear one of these apart.
Old 12-11-2017, 08:12 PM   #11534
jdm05
Member#: 180155
05 Jdm Sti 2.0
Hahaha true good luck and have you had an oil analysis yet to see how he motor is doing? Black stone?
jdm05 is offline   Reply With Quote
Old 12-16-2017, 04:26 PM   #11535
GarrettPlusBugeye
Member#: 455087
2002 Impreza WRX
Fellow Ej207 owners! I require some quick assistance! My gray plug on my engine was damaged when the engine was pulled, I don't know the layout to repin the plug. Here's a picture of it.
I'm also located in Oregon and interested in buying a 3" JDM downpipe from someone/trade for my Cobb 3" USDM downpipe. Thanks all!
GarrettPlusBugeye is offline   Reply With Quote
Old 12-16-2017, 08:36 PM   #11536
ether947
Member#: 297799
2003 WRX
EJ207 version 8
[IMG]https://i.imgur.com/A4VzmTq.jpg[IMG]
Hard to tell from the angle but it looks like this one.
https://www.iwireservices.com/produc...ock-receptacle
ether947 is offline   Reply With Quote
Old 01-04-2018, 01:16 PM   #11537
86Dreams
Member#: 385256
V7 S204
Whats the soonest you twin scroll guys can spool max boost? I was able to get 25psi at 3300 RPM. Im still refining this but i was surprised to see so much so soon.
https://i.imgur.com/v3sDcVF.png
86Dreams is offline   Reply With Quote
Old 01-04-2018, 01:33 PM   #11538
ether947
Member#: 297799
2003 WRX
EJ207 version 8
I hit full boost (18 psi) by 3800 RPM in 3rd gear (5MT). I noticed your pull was in 4th gear, do you have a 5MT or 6MT?
Old 01-04-2018, 02:05 PM   #11539
86Dreams
Member#: 385256
V7 S204
its a 5 speed.
Thats a good point, it might just be the amount of time that the turbo is spooling.
Old 01-05-2018, 07:01 AM   #11540
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
Default EJ207 Owners?
my max is 20psi and i see it just before 3000rpm (maybe 2900?)
custom built 4EAT, stock VF36
Titter is offline   Reply With Quote
Old 01-05-2018, 01:43 PM   #11541
ether947
Member#: 297799
2003 WRX
EJ207 version 8
its a 5 speed.
There's a higher load from the engine in 4th gear (it's also slightly overdriven), so the turbo spools faster. Most people do pulls in 3rd. Do you have any 3rd gear pulls? I'm curious to see how it performs.
I wish I could parse this (other than extreme jealousy) as I've never driven an automatic turbo car. I'm assuming that's in third gear on the 4EAT?
Old 01-05-2018, 08:28 PM   #11542
Titter
Member#: 416107
2002 WRX Wagon
EJ207 Spec C 4EAT
not sure which gear actually. dont have a graph from a dyno pull. just from me mashing my foot down and then looking at my boost gauge then rpm. its either 2nd or 3rd. prolly 2nd. thats where i spend most of my time. (i rarely drive in D)
also since in relying on my eyes and reflexes, i might be off a wee bit.
Old 01-08-2018, 05:50 PM   #11543
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Anybody running a vf48 on a ver 7 and want to share dyno graph ?
D-Rodman is offline   Reply With Quote
Old 01-09-2018, 09:18 AM   #11544
08OBS
Member#: 274397
2005 WRX V9 207
1992 Legacy SS
My most recent oil analysis. Very happy with how these are turning out.
08OBS is offline   Reply With Quote
Old 01-09-2018, 01:41 PM   #11545
Micro
Member#: 103451
00 RSTI
Originally Posted by Gigs90 View Post
Easily , The stock STi clutch will handle almost anything except repeated hard launches.
I asked a few months ago if a dealer clutch could handle the 207... 250 miles into my break in period of the 6mt dealer clutch, tried revving it past 4k rpm to ‘test it’ and it slipped. (I instantly let go of the gas)
I’ve been babying the clutch since I got it changed. Local driving. Nice and easy.
Dealer clutch. Competition Clutch steel LW flywheel. Installed by a reputable tuner shop (which I contacted. They told me to bring it by)
Any thoughts?
Micro is offline   Reply With Quote
Old 01-09-2018, 08:25 PM   #11546
Gigs90
Member#: 306719
2003 Sti Wagon
@jn_garage
That looks way better
Originally Posted by Micro View Post
I asked a few months ago if a dealer clutch could handle the 207... 250 miles into my break in period of the 6mt dealer clutch, tried revving it past 4k rpm to Ďtest ití and it slipped. (I instantly let go of the gas)
Iíve been babying the clutch since I got it changed. Local driving. Nice and easy.
Any thoughts?
Could be the flywheel , Its weird cause I have had multiple friends track their cars with the stock STi clutch with no issues.
Gigs90 is offline   Reply With Quote
Old 01-10-2018, 09:04 AM   #11547
Micro
Member#: 103451
00 RSTI
It’s kimda frustrating after spending over $1000 to have this thing not grabbing. Ugh.
I’ll post an update after I bring it back to the shop next week.
Old 01-10-2018, 10:08 AM   #11548
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Any thoughts?
Just how much power and torque are you running w/your EJ207?
Old 01-10-2018, 11:01 AM   #11549
Micro
Member#: 103451
00 RSTI
basically stock V7. nothing to brag about.
Old 01-10-2018, 01:19 PM   #11550
Samurai Jack
Member#: 21145
2002 Enemy of Aku
If your 207 is basically stock, then the OEM STi clutch should easily handle the power level.
Could be a failing clutch - it happens, even when new
Could be some kind of contaminate got on the clutch / flywheel
Could be how you have been driving - no one was there to see how you drive
Could be a failing or wrong TOB.
Has this been slipping since the install or is it something that just popped up very recently?
I had something similar on a different car.
Car had an aftermarket clutch installed by a shop. 10 days after the warranty ( 90 days ), the clutch collapsed.
This time I took the car to the dealer and had them install an OEM HP clutch. From the moment I left the Dealer, the clutch was slipping like you describe.
Took it back the next morning and they spent all day trying to figure out what was wrong. They checked everything. Clutch, flywheel, TOB. They measured everything again. They checked with the machine shop who resurfaced the flywheel. They installed a whole new clutch.
I was standing there with the Tech the whole time so I know what was being done. Still the same.
So, I asked them what TOB they installed. Seemed like silly question, but ...
As it turned out, since the aftermarket clutch had a short TOB, so they just installed a short TOB.
Problem was, the OEM clutch required a long TOB.
Once they fixed that, problem solved.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 07:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 04:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 09:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 03:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 01:56 AM
