Welcome to the North American Subaru Impreza Owners Club Sunday October 21, 2018
Old 04-01-2006, 11:15 AM   #1
alacrity024
Review Crew
Member#: 49476
Default mobil 1 gear oil in WRX 5mt?
bought my car with 30k on it.. coming up on 60k.. figure it's time to change the transmission and rear diff fluid.. so i went and bought five quarts of Mobil 1 gear oil, a long funnel and an oil pump. did some searching on here to make sure i had the procedure right and found that a couple people were recommending AGAINST Mobil 1 in the gearbox........
i'm not gonna ****ing break anything am i??
and i posted this here because i am deathly afraid of other forums.
alacrity024 is offline   Reply With Quote
Old 04-01-2006, 11:18 AM   #2
incorporeal
FTW RIP
Member#: 1820
I put it in my RS, the transmission blew up 500 miles later, $1800
FTW
incorporeal is offline   Reply With Quote
Old 04-01-2006, 11:18 AM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
<---- running mobil1 since day 1. 130k on it never broke anything
sidewayz is offline   Reply With Quote
Old 04-01-2006, 11:19 AM   #4
alacrity024
Review Crew
Member#: 49476
FTW
how many miles on the car when you put it in?
Old 04-01-2006, 11:19 AM   #5
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
I used mobil 1 and had serious grinding issues. Switched to Redline Lightweight shockproof gear oil. Some people do a mixture but I am completely redline lightsweight shockproof.
http://www.racerpartswholesale.com/redline2a.htm
My shifting is much smoother and much less grinding than ever before.
2k2 is offline   Reply With Quote
Old 04-01-2006, 11:19 AM   #6
incorporeal
FTW RIP
Member#: 1820
Ftw
Old 04-01-2006, 11:21 AM   #7
alacrity024
Review Crew
Member#: 49476
damnit.. i really wanted to get this done today.. not in the mood to go return five quarts of oil...
Old 04-01-2006, 11:24 AM   #8
incorporeal
FTW RIP
Member#: 1820
Will you link me to the directions? and which pump did you buy and how much was it? I need to change my tranny's fluid too
FTW
Old 04-01-2006, 11:26 AM   #9
awilson529
RIP
Member#: 38867
11 Mazda
Adam, I would'nt put the mobil 1 in your gear box. I did, and it was GREAT for maybe 1,000 miles, then the grinding got horrible (when I had a WRX). Even cruising down the street and shifting normally, any gear would grind. I have found the stock (valvoline) is the best.
awilson529 is offline   Reply With Quote
Old 04-01-2006, 11:26 AM   #10
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
FTW
Pump?
Theres no pump needed to change the rear diff and 5mt fluid on a WRX. Just a long funnel to get the fluid into the spout for the MT.
Old 04-01-2006, 11:26 AM   #11
alacrity024
Review Crew
Member#: 49476
the pump was like three bucks at autozone.. it kinda looks like an oversized handsoap pump.. dunno how it works yet, but i remember changing fluid in the rear diff of my SVX it was a very awkward pour angle to put new fluid in it..
http://www.scoobymods.com/forums/sho...smission+fluid
Old 04-01-2006, 11:26 AM   #12
Clarque
Member#: 94195
I put in the mobil 1 75w90 in my sti tranny and rear diff. at 30,000 miles recently...soon after I noticed that my synchros were ****** up! so I brought the car to the dealer and am having them replaced...for free hopefully. I will not be using Mobil 1 again though. I am not happy with it at all. The fact that I had more problems with the tranny tells me that the stock stuff was working better than the Mobil 1. The damage was alays there, but the mobil one made it way more noticeable. Stick with the subaru stuff.
I normally swear by Mobil 1...but thats only for motor oil. which I also no longer use. I have been using Torco SR1 5w30...works great! I will never go back
-Ryan
Clarque is offline   Reply With Quote
Old 04-01-2006, 11:27 AM   #13
alacrity024
Review Crew
Member#: 49476
grrrr.... okay well i'm going back to autozone after work
Old 04-01-2006, 11:29 AM   #14
rex n effect
Member#: 15289
02 wrx pollen silv
& 07 Hyundai misfire'R'us
I used a mixture that contained some mobil1 for my first change. I'm not sure what part of the mixture caused it, but I got grinding when it was COLD out. 30 k later, I switched to redline lightweight shockproof (the blue sticky stuff?) and no grinding this entire winter. Instead of grinding, it was just slower to get into gear when it was cold.
Transmission forum? Don't be afraid...
rex n effect is offline   Reply With Quote
Old 04-01-2006, 11:32 AM   #15
2k2
Member#: 12368
2008 Infiniti G35X
2011 BMW X5 Diesel
Is this for a WRX or a RS?
WRX instructions:
1. Remove bolt from 5mt, it takes a 1/2 inch ratchet IIRC. Clean off bolt and magnet.
2. Replace bolt.
3. Get a long non stiff funnel and fill up 5mt.
Rear Diff
1. Remove lower bolt and drain, more will drain if you have you car with the front higher than the back
2. Replace Bolt
3. Again you need a long funnel and fill.
Thats it!
I still reccomend Redline Shockproof, you wont be able to get it at your local autoparts store though. It fixed all of my grinding problems.
Old 04-01-2006, 12:28 PM   #16
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
My syncros took a crap on me about 10K after switching to synthetic. They were replaced under warranty, but I will never run synthetic in my Subaru transmission again.
Stanley is offline   Reply With Quote
Old 04-01-2006, 12:33 PM   #17
incorporeal
FTW RIP
Member#: 1820
I done gots me a 4EAT impreza wagon
FTW
Old 04-01-2006, 12:34 PM   #18
alacrity024
Review Crew
Member#: 49476
oh.. so you can't change the fluid yourself.. you need to take it to a reputable shop with a transmission pump..
Old 04-01-2006, 12:34 PM   #19
alacrity024
Review Crew
Member#: 49476
should i just get the pennzoil "syncromesh" stuff or what??
Old 04-01-2006, 12:38 PM   #20
incorporeal
FTW RIP
Member#: 1820
yea but thats like $120 and I would rather do it myself
FTW
Old 04-01-2006, 12:40 PM   #21
alacrity024
Review Crew
Member#: 49476
yeah but you CAN'T do it yourself. the best you can do is drain about 1/4 of the fluid and replace it.. if you do that once a month, theoretically you'll have done a full fluid change in about four months time.. automatics will not fully drain by themselves, they need to be pumped.. if you have a transmission fluid pump at your disposal, then by all means do it yourself..
Old 04-01-2006, 12:41 PM   #22
24
Member#: 39142
Memb er#: 39142
DO NOT USE SYNTHETIC GEAR OIL IN YOUR CENTER DIFF. Your synchros need the friction so that you can shift properly. I learned this the hard way, I put all Neo Synthetic in mine, and it was grinding like crazy. I had to drain out a quart, and replace it with GM Synchromesh.
This is b/c the tranny shares oil with the front differential, IIRC. It's a catch 22, it needs lube for the bearings, but needs friction for the synchros. There's a bunch of threads about it in the tranny forum.
Old 04-01-2006, 12:43 PM   #23
alacrity024
Review Crew
Member#: 49476
*sigh*
i always like to put something "better" into my car whenever something needs to be replaced (aka brake pads, clutch, suspension components, fluids, etc) so i feel like i won't be accomplishing much by putting dino oil in the transmission..
but oh well.. it seems i must.
Old 04-01-2006, 12:44 PM   #24
alacrity024
Review Crew
Member#: 49476
and hey dcmo.. if i manage to sneak white powder into one of your clubs, you probably won't be there??? you're potentially bailing on the BBQ so i assume you'll likely not be out at the clubs if you're all snotty and oozy, right?
Old 04-01-2006, 12:44 PM   #25
24
Member#: 39142
Memb er#: 39142
*sigh*
Yes, I fall under the same mindset. That NEO **** cost me like $18/quart of some outrageous price. But I was like, hey that's what the WRC team uses. :cries:
Mobil 1 gear oil sucks...now what? ScoobySnacker Transmission (AT/MT) & Driveline 6 09-06-2006 08:19 AM
Mobil 1 gear oil for tranny? nix-hex Transmission (AT/MT) & Driveline 11 03-12-2006 09:13 AM
Successful P.M. : New gear oil in 5MT @ 50k miles 2Stroke Transmission (AT/MT) & Driveline 1 05-13-2005 01:40 PM
Cheap Mobil 1 gear oil AlboWRX Transmission (AT/MT) & Driveline 16 12-21-2003 02:23 PM
Mobil 1 gear oil wrxlvr Rocky Mountains Impreza Club Forum -- RMIC 2 12-15-2003 08:05 PM
