Welcome to the North American Subaru Impreza Owners Club Sunday October 21, 2018
Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 08-24-2017, 12:09 PM   #1
BarmanBean
Member Sales Rating: (62)
Member#: 297778
2005 OBXT 6mt
Default (VA): Set of B25 Heads w/ cams
B25 heads, 88k miles. Here's the run down on em. Did a motor R&R and the driver's AVCS sprocket was mistakenly pressed on with the cam dowel in an oil galley hole instead of the dowel hole. The result was that the 4 valves on the driver's intake cam were about 4 teeth off from the rest of the timing and the valves *just* touched the pistons--enough to make a mark in the carbon deposits on the pistons and possibly bend the valves, although not visibly. Passenger side leak down numbers were 1% and 2 %, driver side leak down numbers were both 9%. You could have them pressure tested or just replace the 4 valves. The lash was just set, but obviously check everything before installing.
Includes buckets, cams, cam caps, cam basket. Journals and such are in good condition and these were never on a motor with any oiling / bearing issues.
$500, local pickup in Springfield.
BarmanBean is offline   Reply With Quote
Old 08-28-2017, 10:34 AM   #2
BarmanBean
Member#: 297778
2005 OBXT 6mt
Bump, price is OBO. Also have some case halves and a stock shortblock with bearing issue for sale if you want to make a package deal.
Old 09-06-2017, 10:42 AM   #3
BarmanBean
Member#: 297778
2005 OBXT 6mt
Bump.
Old 10-20-2017, 09:45 AM   #4
BarmanBean
Member#: 297778
2005 OBXT 6mt
Sold.
