07-13-2002, 11:51 AM | #1 |
Member#: 3467
Vehicle:1998 Dinan3 Bleck |
help, does anyone know where....
Hi, does anyone know where the fuel pump relay is located in an RS? I'm not getting fuel when I crank the car and the fuel pump does not purge like it should when I turn the car to ON. any info would be greatly appreciated. thanks,Stephen
07-13-2002, 01:25 PM | #2 |
Member#: 1257
Vehicle:2000 GC8 WRX 93 RS-W Wagon (White) RIP |
The Fuel-Pump Relay is located on the driver side, just behind the instrument cluster. So for us US base Subies, that would be the upper-LEFT. There are three relays there, I believe that it is the one closest to the front.
It is fairly hidden with all the wires there. Note: The WRX is located on the passenger side. Only the GC8 style is on the Left side. Hope this helps Cheers EddyL. |
07-13-2002, 08:29 PM | #3 |
Member#: 3467
thank you. is the plug brown with a bunch of wires?
07-13-2002, 10:07 PM | #4 |
Moderator Member#: 922
MWSOC
Vehicle:16 WRX (white) 04 FXT (red) |
If you want to stop the fuel, go under the passenger side of the rear seat and disconnect both those plugs. That is much easier then fishing under the dash, IMO.
07-14-2002, 12:37 AM | #5 |
Member#: 3467
Nick, I can't seem to get the fuel pump to ressurize. and my ECU is not getting main power
07-14-2002, 12:53 AM | #6 |
MWSOC
Start with the basics, like checking the underhood fuses and batter connection and whatnot? Check the battery to see what type of voltage it's holding?
Similar Threads | ||||
does anyone know where the vss is on a 6 speed? | efmd3 | Transmission (AT/MT) & Driveline | 0 | 03-30-2008 10:36 PM |
so does anyone know where the Air Temperature Sensor is on a 99? | Big_Hitter | Texas Impreza Club Forum -- TXIC | 3 | 10-20-2005 03:43 PM |
so does anyone know where the shock sensor adjustment knob is on a 99 forester? | Big_Hitter | Forester Forum | 3 | 09-23-2004 08:43 PM |
so does anyone know where the shock sensor adjustment knob is on a 99 forester? | Big_Hitter | Texas Impreza Club Forum -- TXIC | 1 | 09-18-2004 06:51 PM |
Does anyone know where the sun is | Templar | South East Region Forum | 9 | 03-18-2003 10:48 AM |
