11-11-2013, 04:09 PM | #1 |
Member#: 302186
Vehicle:2011 wrx pearl white |
first set of power upgrades..
not new to here by any means but i have not touched either of my wrx's powertrain at all...
so now i want to...im very experienced in the evo 4g63 engine and cars as ive had an 95 dsm and an evo9 but dont know where to start with this car as ive heard even an exhaust on these cars cause issues without a tune so i ask you.. whats the first things i should do power wise.. where do i start.. would i be correct to say intake, exhaust, tune.. or is there another way to go in subieland.. thanks in advance !
11-11-2013, 04:29 PM | #2 |
Newbie Moderator
Moderator Member#: 91347
Vehicle:2004 Tacoma Crew Cab 2012 Triumph 1050 |
do a search for the words "first mods" here in the Newbie forum. You'll find a billion threads on the subject. Intake is not the place to start. If you're looking for power bumps, exhaust and tune. But honestly, without a budget and a goal, we can't really help you. For all we know, you want a stock power lifted WRX for rock crawling.
11-11-2013, 05:04 PM | #3 | |
Member#: 302186
anyway.. heres my old setup and car.. http://www.dsmtuners.com/forums/turb...etup-pics.html for the end result of what i want.. which is obviously thousands.. but for now ill say 1000-2000 for a safe 50-80 hp bumps into the high 12's at the strip.. |
11-11-2013, 05:29 PM | #4 |
Member#: 193934
RMIC
Vehicle:2011 WRX Texas born n' raised |
Full exhaust (turbo back, up pipe.. basically all the "pipes" haha) E85 tuned w/ supporting fuel mods (injectors, pump, ect..)
It's what I would do! but that's my opinion done from my own research. People aren't very nice on here but if you do search which I'm sure you have.. You can find some very very useful information on here. Hope all the best and good luck! |
11-11-2013, 05:35 PM | #5 |
Newbie Moderator
Well, no. Here's why:
Budget - Without this, we don't know if you're dirt poor and just want cheap fun mods, or you're looking for an all out build. Based on the $1k-$2k, there's only the question of whether you're doing the work yourself. Goal - We're not here to judge your goal. But we do request you have one. That could be as simple as "I want a fun daily driver that will blow the pants off anything I see, but not be unbearable to drive." or as complex as "I want a car that will do 9 second 1/4s and still be able to clear speed bumps." You've now given us those things. Sounds like you're looking for a good Stage 2 set up, with maybe a few other mods. Honestly, a Stage 2 and a set of tires might get you into the high 12's... maybe. |
11-11-2013, 05:53 PM | #6 |
Member#: 316278
TXIC
Vehicle:2010 WRX Sedan WRB |
It looks like your just wanting to take the first steps to get a little more out of your car. I would recommend starting out with an accessport and load the stage one tune intended for a stock car. after that if your still looking for more, get yourself a downpipe, they're one of your best bang for the bucks on these cars. at that point you would be whats widely recognized as stage two. if stage two with the accessport map still isnt what your looking for, find a local tuner that can maximize the power output you can gain out of your new downpipe, the maps that come pre loaded on the ap are better than stock but still leave some on the table to be on the safe side. If you live nowhere close to a subaru tuner like me, hit up eric at torqued performance. he can send you one of his base maps which will be a little hotter than what comes stock on the ap, plus he will fine tune it to your specific vehicle via email. all you have to do is send him data logs, he'll make adjustments and email you the revised map, you load the new map he sends and send him data logs of his revised map. he will keep doing this for no charge until everythings squared away.
Defiantly the first thing to do is get yourself an ap |
11-11-2013, 06:06 PM | #7 | |
Member#: 302186
again im sorry for being so stupid when it comes to these cars.. but until now..if it wasnt mitsu im braindead.. |
11-11-2013, 06:08 PM | #8 |
Member#: 302186
im thinking a turbo back, intake, and tune via accessport would give me a decent bump in hp.. would a sti intercooler or IC upgrade do anything or is that a waste ?
11-11-2013, 06:11 PM | #9 |
Member#: 268310
SCIC
Vehicle:2011 SSM STI saloon Church! |
Assuming you're and experienced driver and know how to properly launch an AWD car, an aftermarket downpipe and a protune will get you into the low 13's or high 12's.
Cole and Loyale are spittin' truth, OP. $800-1000 can get you where you want to be. That's with a brand new downpipe too. |
11-11-2013, 06:15 PM | #10 |
Member#: 302186
yea a dp is on the list
11-11-2013, 06:16 PM | #11 | |
Member#: 302186
11-11-2013, 06:21 PM | #12 | |
Member#: 268310
SCIC
With a good protune, you should be able to lop about a second off that quarter time. Lots of YouFace vids of WRXs and STIs with "stage 2" mods running mid 12's with a good driver. |
11-11-2013, 06:41 PM | #13 | |
Medium Frank
Moderator Member#: 140114
Vehicle:2020 Subaru Outback |
Clearly you did not read ANY of the stickies that outline exactly what you want. Go do a quick search on "stage 2" and be happy. An STI intercooler cannot fit any 08+ WRX's. |
11-11-2013, 07:31 PM | #14 |
Member#: 295068
Vehicle:2015 ford escape tuxedo black metallic |
Downpipe, injectors, fuel pump, front mount boost control solenoid, protune. Let's see what that vf52 can really do.
11-11-2013, 07:34 PM | #15 |
Member#: 268310
SCIC
11-11-2013, 07:52 PM | #16 |
Member#: 302186
Still not comprehending this up pipe downpipe thing.. I must be insanely stupid becsuse I dont get it.. who wants to break it down to my level
11-11-2013, 08:12 PM | #17 |
Member#: 343118
Vehicle:06 Impreza WRX STI WR Blue Pearl |
The uppipe feeds the exhaust gasses to the turbo. Makes the turbo spool
11-11-2013, 08:26 PM | #18 | |
Member#: 316928
Vehicle:2012 STI limited |
Check the diagram on that webpage. Exhaust gasses leave the motor into header through uppipe which spools the turbo |
11-11-2013, 08:54 PM | #19 |
Member#: 295068
11-11-2013, 08:59 PM | #20 |
Member#: 295068
Upon some reading, you will find out that Subaru put a catalytic converter in the up pipe from 02-05, which is why people replaced them with catless versions. On newer 06+ Models, the up pipe is catless from the factory and is usually replaced by owners looking to squeeze a few more hp out if their set ups or if your making "big" power numbers and replace it with a more efficient unit.
11-11-2013, 09:03 PM | #21 | |
Member#: 302186
Got it.. feeds the header.. just something im not used to.. dsm headers bolt right to the turbo..makes sense now that external gates come off the up pipe.. Thanks |
11-11-2013, 09:18 PM | #22 | |
Newbie Moderator
Keep in mind, that's from an '02. But the same principle. |
11-11-2013, 10:19 PM | #23 | |
Medium Frank
Exhaust manifold>Up pipe>Turbo>Downpipe>Catback>Axle Back (if you want to get technical) The up pipe "feeds" the turbo. Connects Exhaust manifold to turbo. This research on your end is sucking, start using google. |
11-12-2013, 06:00 AM | #24 |
Member#: 302186
K.....flow is the other way.. used the wrong word.. "connects" would have worked.. got it.. move along
11-12-2013, 06:22 AM | #25 |
Medium Frank
Move along into this thread, and start reading. http://forums.nasioc.com/forums/showthread.php?t=533787
