02-22-2020, 06:08 AM | #51 |
Member#: 148335
Vehicle:2018 STi Type RA#454 WRB |
I wanted to upgrade the exhasut on the car since I got it. I wasn't sure which route to go since I am trying to keep this as JDM/OEM as possible. My options were the STi performance exhaust, S209 Mufflers, and the rare JDM Sport exhaust. Well I didn't want the STi Performance exhaust as it is technically more restrictive than the OEM Type RA/19+ exhaust. So that left me with very limited options as the S209 mufflers are $$ and the JDM Sport Mufflers are $$$$.
Browsing the classifieds on NASIOC I came across this combo of the Namless 3" midpipe and the JDM Sport Mufflers. Made and offer, and drove to Maryland to pick everything up!
02-22-2020, 06:15 AM | #52 |
Member#: 148335
Was going to let the car fund cool for a bit after picking up the JDM Exhasut. Well, a former Type RA owner and current S209 offered me his S209/Type RA-R fog covers. These were absolutely on my short list of mods. Couldn't pass up the deal on bought them.
02-22-2020, 04:12 PM | #53 |
Member#: 145105
Vehicle:2015 Honda Accord |
All the pictures don't work for me
02-23-2020, 06:39 AM | #54 |
Member#: 148335
I have no idea what is going on with google photos. They will upload then dissapear.
02-23-2020, 11:29 AM | #55 |
Member#: 8
HIIC
Vehicle:2016 WRX STi Ice Silver Metallic |
02-23-2020, 11:50 AM | #56 |
Member#: 2272
BAIC
Vehicle:2019 Macan 4cyl 1993 Impreza FWD WRX swap |
03-16-2020, 08:58 PM | #57 |
Member#: 148335
Installed the final Suspension pieces from the JDM/STi parts catalog. Flexible Rear Subframe Support Brace, S208 Subframe Bolts and Stoppers, and Flexible Front Strut Bar
03-16-2020, 09:18 PM | #58 |
Member#: 53206
Vehicle:2018 Type RA WRB |
Looking great!
How’s the transformation from stock? |
03-16-2020, 09:52 PM | #59 |
Member#: 148335
The car feels awesome! Everything is designed to work together and once I installed the final parts the car just turns in so much better. Its not stiff like solid braces make the car feel, but these flexible braces do work when you need them to.
The last suspension piece that I am going for are the STi Pink Springs. After that I am moving onto drivetrain. Group N STi Shifter Group N Rear Shifter Bushing Group N Transmission Bushing Group N Transmission Support Bushings Group N Pitch Stop Mount Group N Motor Mounts I also have project in the works. I want to be the first RA to completely swap the S209's I/C sprayer system into the car with working paddles and everything. Still looking for the wiring diagrams to see if the I/C harness plugs into the existing RA harness |
03-17-2020, 07:35 PM | #60 |
Member#: 164302
Vehicle:11 20 STi, 11 STi 21 WRX, 02 WRX |
I like the parts selection and the way the car is coming along so far. Looks sweet!
03-17-2020, 09:27 PM | #61 |
Member#: 369934
Vehicle:2018 STI Limited Heritage Blue |
Those JDM Sport Mufflers are incredible.
03-18-2020, 10:02 AM | #62 |
Member#: 148335
Thanks! They definitely sound awesome and fit and finish is amazing. The 3" Namless piece is also beautiful.
Wish my first AutoX weekend wasn't canceled do to this Virus crap. Car needs its legs stretched. Also, found the JDM STi Rear Toe Links for sale separate from the control arms and snagged those yesterday. Last edited by archer1.8; 03-21-2020 at 06:40 AM. |
03-18-2020, 10:22 AM | #63 |
Member#: 280995
Vehicle:2019 STi Crystal Black Silica |
Love your approach to an OEM+ build. Fits the character of the car much more. Have you thought about adding a rear wiper? I'm always jealous when I see photos of our cars overseas with the feature.
03-18-2020, 03:20 PM | #64 |
Member#: 53206
The upgrades sound great. I just picked up an RA a month ago with only 900 miles on it. Super happy to be back in an STi after driving our 09 Outback for the past 3 years.
Luckily for me it’s such a huge change I’ll be quite content with the stock set up for the foreseeable future. But if I change my mind I’ll check back in with your progress. Keep us posted on the IC spray setup. That’d be awesome! |
03-18-2020, 05:16 PM | #65 | |
Member#: 148335
I sourced the Type RA-R smaller windshield washer bottle and i would have to remove part of the front safety crash bar to do it. I decided not to go that far with it. Last edited by archer1.8; 03-21-2020 at 06:40 AM. |
03-19-2020, 02:37 PM | #66 |
Member#: 369934
With the JDM Sport mufflers with they attach to the OEM mid pipes or does larger piping need to be used?
03-20-2020, 02:32 AM | #67 |
Member#: 189372
03-20-2020, 12:07 PM | #68 |
Member#: 148335
The Sport mufflers are designed to fit the 2015-2018 Exhaust systems. That includes Stock and the STi Performance Exhaust. The Type RA and 2019+ Systems have larger diameter all the way to the mufflers and wont work with these mufflers
03-21-2020, 07:13 AM | #69 |
Member#: 148335
Was able to work with Japan Parts and have them source the JDM STi Type RA-R lightweight Windshield Washer Bottle. I filled both bottles and weighed them. The RA-R bottle when full weighs 5lb less. 13lbs compared to 8lbs.
It will work on the USDM cars, however some modifications are needed. The JDM Piece does not have a level sensor in it, and would requiring swapping the level sensor which is a PITA. That oem sensor wouldn't come out of the USDM bottle. The other problem is the USDM Bumper beam is different than the JDM one. The USDM Beam has this extra brace that is just bolted on to triangulate the brace and the frame rail. You need to remove the front brace to remove this brace. If I ever have the front bumper off, then I may remove this brace. But for now I did not install the bottle. |
03-21-2020, 07:23 AM | #70 |
Member#: 148335
Someone was parting out an S209 on Ebay recently. Spoke to them, and the owner is modding it for track use and was selling off some parts.
I had the JDM STi Rear Control arms, but not the Toe Links. Scored these for an awesome price. Alignment is totally out, but I scored some other S209 goodies I am waiting on for a total alignment. |
03-21-2020, 07:39 AM | #71 |
Member#: 148335
Made a deal on a set of S209 Bilsteins with the STi Pink Lowering Springs. They have 1000 miles on them, and I got them for a killer deal. Will take some comparison pictures of the Type RA Setup and the S209 Setup when the arrive. Cant decide if I want to get aftermarket camber bolts while I am at it.
04-01-2020, 08:07 AM | #72 |
Member#: 148335
My S209 Struts and Springs showed up. I found it interesting that the STi Pinks that come on the S209 dont actually have "STi" printed on them. The previous owner apparently had the one strut apart to "take a 3D image" of the top hat to make an adjustable one. He forgot to reinstall the dust boot. So I ordered a new one.
04-01-2020, 08:29 AM | #73 |
Member#: 148335
With all this Covid-19 stuff going on my work as a power plant operator has been considered "essential." We are operating on a skeleton crew at the plant, and I have had a lot more free time since all capital projects are on hold.
One of my pet projects for my Type RA-R themed build was to figure out if the S209 intercooler spray system would simply just plug and play into the existing harness of the RA. It turns out it does! Well, 95% The S209 as a different Instrument Cluster that has the warning light for the low I/C Tank Level. This plug just wont be used. No biggie. All of the parts for the swap can be bought directly through Subaru. If you shop around for the best prices it comes out to be around $700. Intercooler Spray Harness: ST84981VV030 Intercooler Spray Hose (Front): ST86688VV010 Intercooler Spray Hose (Rear): ST86688VV020 Intercooler Spray Tank Assembly: ST86669VV000 Intercooler Spray Paddles: ST34329VV000 Intercooler Spray Paddle Column Trim: 34317VA010 Intercooler Spray Nozzle Kit: ST57253VV080 |
04-01-2020, 12:31 PM | #74 | |
Member#: 447898
BAIC
Vehicle:2022 Tesla M3P 2019 STI CWP |
Beautiful build. Truly inspirational.
Is that a real JDM STi Magnesium Oil Cap that I spy? They're nearly impossible to find. Quote:
This is all that I was able to really find:
04-01-2020, 01:00 PM | #75 |
Member#: 118334
SWIC
Vehicle:2006 Red GDA-F 2005 Aspen White GDA-E |
The OEM+ of this makes me all tingly
And as a Subaru Parts Manager, I'm sure your dealers Parts Department is loving you as well Awesome thread so far. |
