Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 09-19-2005, 09:31 PM   #1
Antonios Kintos
Member#: 81122
08 STi white
Default can 2.5L sb w/ wrx heads make 330-340 whp
Ok, so that is my whp goal. My plan is 2.5L sti sb with stock wrx heads. 06H 18g or 06H 20g. Now I know I have a better shot at this goal with the 20g but I'm not ruling out the 18g just yet cause it can be upgraded to a 20g.
So, in doing a ton of searching, some say the stock wrx heads can't go past 320 whp. However, others say a set up like this can make over 320 whp.
So does anyone actually have a setup like or similar to my plan.
I was considering cams while the motor is apart but, there not much info on them, they seem to be not much bang for the buck, and some specialists and gurus claim they may prevent a turbo from making its potential.
I also understand its all in the tuning. Install and tuning will be done at Rallispec. So I know I will get quality work.
Opinions anyone? Thanx
Antonios Kintos is offline   Reply With Quote
Old 09-19-2005, 10:24 PM   #2
Antonios Kintos
Member#: 81122
08 STi white
bump.
Old 09-19-2005, 10:27 PM   #3
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
Yes it can. My turbo is maxed out, but a 20g would reach your goals quite easily.
http://forums.nasioc.com/forums/showthread.php?t=843648
LiquidForce is offline   Reply With Quote
Old 09-19-2005, 10:30 PM   #4
Antonios Kintos
Member#: 81122
08 STi white
So I guess its the WI that brought up the numbers that high? For some reason I dont want to get into the complexities of WI.
Old 09-19-2005, 10:45 PM   #5
LiquidForce
Member#: 12811
2002 2.5l Wrx
With a bigger turbo you can get there without the alcohol injection . The point is the stock heads and stock cams are capable of more than 320 whp. I just needed alcohol injection to get enough out of my smaller turbo. If I had all of my money back I would have gone with a deabolt 20g. A 20g on race gas or alcohol injection would be closer to 400whp.
Old 09-19-2005, 11:32 PM   #6
Antonios Kintos
Member#: 81122
08 STi white
Ah yes straight from one with proof. I came this close to oredering stg2 crowers, glad a highly reguarded vender convinced me to save my $$$ and use it for a bigger turbo.
Old 09-20-2005, 12:49 AM   #7
Antonios Kintos
Member#: 81122
08 STi white
But wait, why did Unkdave top out at about 310 whp in his thread " now putting Axis stg 2.5 together". I think he p & p'ed all the exhaust ports.
Old 09-20-2005, 01:04 AM   #8
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
I know a guy with 18G and TXS TMIC stock wrx engine 323whp, you can get 350whp with a SR55 in a wrx!
west005 is offline   Reply With Quote
Old 09-20-2005, 10:00 PM   #9
Antonios Kintos
Member#: 81122
08 STi white
Default 20g w/ 2.5L sb
I know the 20g is becoming an increasingly popular turbo for the sti. Has any one put a 20g on a 2.5 wrx with stock heads.
Old 09-20-2005, 11:16 PM   #10
wuuusaa
Member#: 92894
2015 Wrx
why would u want stock wrx heads why not v7 or v8 heads,they flow much better than usdm wrx's.i think it will be worth while
Old 09-20-2005, 11:20 PM   #11
hockeygm
Member#: 80681
2003 Impreza WRX
Platinum Silver
not to sabotage this thread or anything but what kind of gas mileage are you guys getting with that much power? just curious
hockeygm is offline   Reply With Quote
Old 09-20-2005, 11:27 PM   #12
02WRX03060
Member#: 19897
02WRX03060 is offline   Reply With Quote
Old 09-21-2005, 12:53 AM   #13
Antonios Kintos
Member#: 81122
08 STi white
Well yes the jdm heads are far better than my stock heads but, its possible to reach my goal with stock wrx heads (330-340 whp).
Also, it would cost me about 3000 to swap in a 2.5L sb, that includes all parts and labor. A set of slightly used jdm heads from IA Performance or another highly reguarded vendor costs about 2000, just for the heads. So thats another reason to stay with stock wrx heads.
As I stated in the first post, I was considering cams but, I've concluded they're not much bang for the buck. The ones I was considering would have run me 1700- 1800 parts and labor.
Old 09-21-2005, 01:47 AM   #14
WSSBOARD18
Member#: 47964
2003 WRX
WHITE
I am getting the same set up and looking for soem results from others. I have a vf22 2.0l now and am getting a 2.5l with forged internals and want to see what kind of numbers i should expect. I will eventually get a bigger turbo, but for now i am going to use the vf22. what can i expectwith stock wrx heads?
WSSBOARD18 is offline   Reply With Quote
Old 09-21-2005, 09:09 PM   #15
Antonios Kintos
Member#: 81122
08 STi white
My guess is you'd be right in the 300whp range. With the extra low end torque and less lag, it should even more fun to drive. Keep us posted.
Old 09-21-2005, 09:23 PM   #16
dcwrx2
Member#: 69005
'04 4EAT Wgn
Any inputs?
dcwrx2 is offline   Reply With Quote
Old 09-21-2005, 09:30 PM   #17
west005
Member#: 65684
1993 JDM Soarer TT
White on golds
Low boost mine is still good/ normal. The way I drive usually around 10mpg. Around 350whp right now
Old 09-21-2005, 09:44 PM   #18
dcwrx2
Member#: 69005
'04 4EAT Wgn
10mpg?!
Have you tried using cruise control and run a tank of gas on roughly 70mph all the time? I know it means torturing to you, but I would like to know the answer (or I'd appreciated if someone else can fill in the answer).
Old 09-21-2005, 11:39 PM   #19
perkowskiforpope
Member#: 50618
2004 Crawford S2
FPgreen PSM Wagon
Im running a crawford s2 block which is a 2.5l STI block with forged pistons and its making 280whp and 325 torque on a ktr's dyno dynamics with a vf22 turbo at 20psi. Its using stock wrx heads, however the pistons are designed to be used with wrx heads, so if your planning on upgrading to 2.5 why not go crawford?
perkowskiforpope is offline   Reply With Quote
Old 09-22-2005, 12:39 AM   #20
InfamousDX
Member#: 25413
A regular ej205 stock block stock heads will make 330-340whp... heck I made 320 with fouled plugs (less timing).
Old 09-22-2005, 01:23 PM   #21
WSSBOARD18
Member#: 47964
2003 WRX
WHITE
On what type of fuel and on what dyno. A dyno dynamics is a very low reading dyno. 270whp on a dd would be over 300whp on another dyno. Also you will not get the torque out of a 2.0l that you will on a 2.5l.
Old 09-22-2005, 02:39 PM   #22
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
With the proper setup, the EJ205 head will make a lot more then 320 WHP.
That's been proven time and time again.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 09-22-2005, 03:01 PM   #23
InfamousDX
Member#: 25413
On a dyno jet...w hich is why this post isn't that great but wahtever. It was a dyno jet where my friend's stock sti put down 232whp. This was on 93. And you definitely wouldn't get the torque of the 2.5 but I never said you would. Also... my other friend's green'd WRX with headwork (ferrea valvetrain, stock cams) did 363whp on pump 93 at turbotrix's dyno and then 405whp on c16. But nothing's relative here... just adding fuel to the misinformation fire.
Old 09-22-2005, 04:15 PM   #24
dcwrx2
Member#: 69005
'04 4EAT Wgn
Speaking of sb, which 2.5L sb you guys think it is good for WRX 2.0 -> 2.5 proj? Can you sort them out according to "Cost vs Performance"? How about quality of each too?
OEM USDM STi 2.5 sb (~$1700)
OEM JDM 2.5 sb (cost varies)
Cobb tuner-series 2.5 sb ($3050)
Crawford s2 2.5sb ($2249)
Axis Stg2 2.5sb ($2650)
Old 09-22-2005, 04:42 PM   #25
Lawrence
Member#: 82518
2005 wrx
I agree with dcwrx, i would go with either the cobb uner or axis power shortblocks. thogh they are still using the same STI forged material but these short blocks are in some cases balanced.
here is the summerized specification of the my list.
http://www.clubwrx.net/forums/showthread.php?t=112875
Also, thought he wrx head is good for 320whp but as you are adding a alchohol injection you will end up gong to the limit of the air flow on the head. you would be better off doing a port and polish.
Lawrence is offline   Reply With Quote
2.5L STi shorblock + WRX heads w/ TD04 Udonboy Proven Power Bragging 34 05-31-2007 06:35 PM
Requirements to install 2.0L head onto 2.5L SB nomorem3 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 07-25-2006 04:58 AM
need new plugs for 2.5l swap w/ wrx heads? gimmewar Subaru Conversions 8 05-01-2006 03:26 PM
Built 2.5l Motor W/wrx Heads Turbo Set Up ...... And More julezamazing212 Private 'For Sale' Classifieds 61 02-18-2006 12:45 AM
Can 2.5L DOHC heads and block be machined if warped? johndingk2 Normally Aspirated Powertrain 4 01-31-2005 08:58 PM
