Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Old 04-27-2006, 06:26 AM   #1
gimmewar
Member#: 100792
Default need new plugs for 2.5l swap w/ wrx heads?
I thought I read somewhere that I may need new plugs for the 2.5l just wondering if there is any fact to that.
Also noticed a lot of discussion about which headgaskets to use to get the compression ratios correct, I am using standard wrx heads w/ the sti 2.5l which headgaskets should be used?
Thanks,
Mike
gimmewar is offline   Reply With Quote
Old 04-27-2006, 10:20 AM   #2
WhiteWoRX1
Member#: 92601
01 Z06
Check it out here http://forums.nasioc.com/forums/show...ght=lfr7aix-11
As far as the headgasket goes, I am running an Axis 2.5 block w/WRX heads and got the Cometic Headgasket from Ron at Axis. It is an oversized 4 layer metal gasket. Not sure on the thickness, but I believe it brings the compression down to 8.5:1. Give Ron a call for the details. 314-865-4409
WhiteWoRX1 is offline   Reply With Quote
Old 04-27-2006, 01:14 PM   #3
ShaggyGT
Member#: 19221
2005 Legacy GT (STi)
UR35R/Rotated Intake Mani
Uhh, you use the same type of plug you used before the 2.5L swap. The plugs go into the heads not the block......
ShaggyGT is offline   Reply With Quote
Old 04-27-2006, 06:49 PM   #4
gimmewar
Member#: 100792
I understand that shaggy, but because it's a 2.5l there's a possibility it may need a different one, I didn't know that's why I ASKED.
Mike
Old 04-27-2006, 07:37 PM   #5
Ronin Quickblade
Member#: 100567
02 WRX
I used the stock 2.5 STi headgasket with my 2 liter top end and my 2.5 bottom end.
I heard they are pretty much the way to go unless you want to spend extra money for no added guarantee. I'm 160 miles into my swap, things are going good. What turbo did you go with?
Ronin Quickblade is offline   Reply With Quote
Old 04-27-2006, 09:28 PM   #6
Unabomber
👏 Big Ron 👏
Member#: 18062
on car parts so PM
me b4 j00 buy
Post in the right forum next time! Your correct choices would be Service & Maintenance and the Subaru Conversions Forums for your questions. Post appropriately next time dammit!
Old 04-28-2006, 01:58 AM   #7
gimmewar
Member#: 100792
I'm very sorry about that Unabomber (sincerely) I thought this was the best one. I thought conversions were more for huge swaps n stuff..but I guess that makes sense :idea:
Ronin Quickblade, vf30 I might get a 34 instead, I got the 30 as part of a trade to where out of pocket was only $200 for block/turbo..$300 for sti tmic, $50 for fuel pump, still need the pink injectors
Mike
Old 04-28-2006, 12:55 PM   #8
V5-STi
Member#: 18058
Try the following plugs: NGK PFR7B, gap at 0.65/0.70 mm, recommended by my tuner.
V5-STi is offline   Reply With Quote
Old 05-01-2006, 03:26 PM   #9
Skully
Member#: 48990
98 Impreza RS
RBP
i recommend you run 8's on heat range. 7's are only 1 step colder, and since you are raising your compression to 8.7:1 by using a STI bottom end + WRX heads. you will need the colder plug. Call advanceauto and tell them you need a heat range 8 plug from NGK. They can look it up in their NGK book.
-Thomas
Skully is offline   Reply With Quote
need a base for 2.5L block/2.0L heads w/VF30 and TMIC db_amn UTEC 9 08-11-2009 06:18 AM
Weird noises after new clutch and 2.5L swap mucky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-13-2008 06:46 PM
Built 2.5l Motor W/wrx Heads Turbo Set Up ...... And More julezamazing212 Private 'For Sale' Classifieds 61 02-18-2006 12:45 AM
can 2.5L sb w/ wrx heads make 330-340 whp Antonios Kintos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 09-29-2005 11:56 PM
Copper Plugs for 2.5L Turbo rich728 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 12-10-2004 11:51 PM
