09-20-2008, 04:18 PM | #1 |
Vendor Sales Rating: (2)
Member#: 66674
South East
Vehicle:9.2@ 153mph Fastest STI |
Forced Performance Red, Green, HTA, and MUCH MORE!!!
Subaru FP Red Turbocharger
Subaru FP Green HTA Turbocharger ***Anti-surge 3" compressor cover pictured above is no longer available. Standard 3" compressor covers are now used.*** The new for 2008 HTA update for the FPGreen model delivers an increase in maximum flow rate from 49lb/min to over 56lb/min without an increase in turbo lag, while also decreasing compressor outlet temperatures with better compressor efficiency than previous models. The turbo features a 8cm Subaru flanged internally wastegated turbine housing with 1 bar actuator and your choice of 3" compressor housing or the more compact 2.4" compressor housing for applications retaining the TGV setup. Subaru FP Green Turbocharger Subaru FP 20G Turbocharger In typical Forced Performance fashion, a new breed of high horsepower turbos are now available for the Subaru WRX and STI in bolt on configuration. The FP2006 or FPSUB20G features a 44lb minute compressor and fast spooling TDO6SL2 turbine wheel. The FPSUB20G typically produces 350-380WHP with astounding spool up response and efficiency. Subaru FP 18G Turbocharger This water cooled, flange compatible TD06SL2-18G-7cm2 turbocharger has a compressor flow rating of 600cfm and an unheard of compressor efficiency of 75% as high as 23psi and can easily deliver as much as 28psi! This makes it the perfect low cost easy install option for your 350+whp 2.5 or even 2.0 Subaru project. Subaru FP EVO3 16g Turbocharger The "Big 16G" as some call it is a standard in the niche, but the FP version has the superior MHI EVO3 16g6 compressor. This TD05H based Subaru turbocharger is best suited for daily driver duties while retaining 330+whp capability. This Subaru flange compatible turbo comes fitted with water lines and oil drain tube to ease installation. Subaru FP 16G Turbocharger This water cooled, flange compatible TD05H-16G-7cm2 turbocharger has a compressor flow rating of 505cfm and max compressor efficiency of 77%, the highest in this family of wheels. It can be operated as high as 23psi without dipping below 74% compressor efficiency! This makes it the perfect low cost easy install option for your 275-300whp 2.0 Subaru project. Many people overlook the "Small 16g" due to it's limited CFM rating, however nothing is better suited to a hot 2.0 than the "Small 16g" turbocharger. PM FOR PRICING OR QUESTION
__________________
[COLOR="Red"][B]Fastest USDM STI[COLOR="Black"] 9.20@153 Tuned By Gadiel[/COLOR] Fastest stock appearance Evo X in the world, [COLOR="Black"]10.79@124 Tuned by Gadiel[/COLOR][/B][/COLOR] [COLOR="Red"][B]Blue Demon STI [/B][/COLOR][COLOR="Black"][B]9.3@150mph Tuned By Gadiel[/B][/COLOR] [COLOR="Red"][B]Fonseca Impreza GT [/B][/COLOR][COLOR="Black"][B]9.6@145mph Tuned By Gadiel [/B][/COLOR] [COLOR="Red"][B]Gadiel Evo IX[/B][/COLOR] [COLOR="Black"][B]9.5@135mph Tuned By Gadiel [/B][/COLOR] [B][I][SIZE="3"][COLOR="Blue"]Winner EVO X class 16th Buschur DSM/EVO shootout 2008[/COLOR][/SIZE][/I][/B] To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. [B]AIM: tonyatbvp & bigvalleypr (online 24/7)[/B] [B]407-287-5940 & 321-578-0888[/B] |
Similar Threads | ||||
<::FS::> Forced Performance Red Turbo | subaru2k4 | Engine/Power/Exhaust | 8 | 05-09-2007 02:26 PM |
1998 Acadia Green 2.5 RS with entire STI powertrain and much more | keirnna | Private Vehicle 'For Sale' Classifieds | 24 | 07-25-2006 06:03 PM |
Forced Performance Red Fp Red Stage 4 turbo For sale | kccobra | Private 'For Sale' Classifieds | 14 | 02-03-2006 09:47 PM |
Forced Performance Red Fp Red For sale | kccobra | Private 'For Sale' Classifieds | 0 | 02-01-2006 08:37 PM |
Indiana:Totalled STi part out, Acadia Green '98 RS, 2 5MT Transmissions and much more | keirnna | Private 'For Sale' Classifieds | 96 | 10-23-2005 11:47 PM |
