12-27-2001, 01:21 PM | #1 |
Member#: 5030
Vehicle:1999 Legacy 2.5GT 19 Audi RS3, 13 Armada |
Anyone Running 300hp and Similar Torque On Stock WRX Tranny?
I am trying to figure out how much power the stock WRX tranny can reliably handle for a future project of mine.
I know a few people have the Cobb APS kit that boosts power to near 300 and I am sure many of you have done other mods to boost power levels. Did you have any problems with your tranny holding up? What alternatives have you explored (Other than a Dog Box) to handle the power? Thanks for all of your help. Brad
12-27-2001, 01:30 PM | #2 |
Member#: 8303
Vehicle:2011 SWP WRX 02WRX & 05STi (both sold) |
I have 300 (crank)hp right now and no problems w/ my tranny whatsoever. I'll have the Cobb FMIC, STi injectors, and Supra fuel pump installed soon and I'm sure the tranny will still hold up just fine....
12-27-2001, 01:33 PM | #3 |
Member#: 4980
I think i fit into that catagory...
Look to the left for my 1/4 mile time. -Nathan |
12-27-2001, 01:42 PM | #4 |
Member#: 6713
TXIC
Vehicle:2007 Prius brown |
Im at around 290, drag race and autocross fairly regularly.
everything is ok so far. 11k miles |
12-27-2001, 01:43 PM | #5 |
Member#: 6788
Vehicle:2014 991 Turbo S 2007 997 Turbo |
at about 320 hp - ebverything is ok if you dont shift that hard.
When I went over 360 HP on race gas - thats when i started smoking clutches and broke a 2nd gear off a tranny |
12-27-2001, 01:54 PM | #6 |
Member#: 3960
So far so good in my ride too. Only issue is my brakes are gone at 13k miles.
12-27-2001, 02:09 PM | #7 |
Member#: 8302
Vehicle:2002 WRX WRB Sold! 2006 Scion TC-T |
I'm at about 300 and the tranny is fine. Hard shifts do cause some slipping of clutch. Be nice to your car and your tranny should survive a long time. If you are going to drag race, drop the clutch and don't feather it in. This should add a few years in my opinion and if done right your car will still be just as fast.
12-27-2001, 02:24 PM | #8 |
Member#: 563
Vehicle:2002 Subaru WRX WR Blue Pearl |
Ok, I am confused now...I thought it hurts the tranny more if you drop the clutch instead of slipping it out.
Steve |
12-27-2001, 03:01 PM | #9 |
Member#: 5030
Sounds great guys. Thanks for all your help.
12-27-2001, 03:02 PM | #10 |
Member#: 8302
As far as I know, feathering the clutch is terrible for your clutch, and I would think your whole transmission. Maybe your right about it being easier on the rest of the transmission, I don't really know for sure, but it seems to me to be much easier on the car when I just drop it. When I feather the clutch in for a day at the dragstrip all sorts of strange smells come from my transmission. Bad smells make me think of bad things. Clarification anyone.
12-27-2001, 03:07 PM | #11 |
Member#: 4649
Vehicle:2002 WRX '88 323 GTX |
Pick what you want to break...
If you feather the Clutch you will start smoking clutches but it will be easier on the Tranny... Drop the clutch and you are puttin gmore strain on the tranny and saving the clutch.. As Alfrie says at a certain point it doesn't matter which way you go... |
12-27-2001, 03:11 PM | #12 |
Member#: 5030
Slipping the Clutch kills clutches but saves transmissions. I would much rather replace a clutch rather then a whole tranny. I would first rather have clutch and transmission setup that will handle the power whether I give it a little clutch slip or slammed upshifts.
12-27-2001, 04:25 PM | #13 |
Member#: 4980
I hear that feathering the clutch is the easiest thing on the transmission, but i actually like a quick but controlled release.
Its lasted me over 150+ launches so far... Tears up the tires though, but hey i would rather replace those than the clutch or transmission. One of the main reasons i am still on the stock tires... -Nathan |
12-27-2001, 07:13 PM | #14 | |
Member#: 13483
12-27-2001, 09:57 PM | #15 |
Member#: 4324
Vehicle:02 GDA Platinum |
Im at 300hp (crank). no issues with tranny. I did about 10 total runs dropping the clutch at 5k rpm, and went to 1 autocross event.
i havent abused the car in about 15k miles though since then, just drive it aggressive but no crazy launches or banging shifts. i also run full redline fluids in the engine, coolant, transmission, and rear diff. i should be at 340-350 crank hp shortly and we will see what will start happening as a result of the extra power. also no clutch slippage at all. im at 21,500 miles so far. EJ20WRX |
12-27-2001, 11:23 PM | #16 | |
Member#: 5970
Vehicle:2004 \/\/|2>< STi Bp]V[ 97 |_||\|1<|-|1p2.0 |
check it out, its about 3 megs http://www.ritchbrook.com/fuzzylogic/nmyeti12sec.mpeg |
12-27-2001, 11:49 PM | #17 |
Member#: 8943
TXIC
Vehicle:2006 MINI + Corvette Both Blue |
I'm running 257 WHP which I guess translates into 300-something at the crank. No "problems" with the WRX tranny beyond what people normally encounter. GoodFinder
12-28-2001, 03:44 AM | #18 |
Member#: 13675
Vehicle:202 wrx and outback white and silver |
how did you get the hps
How did you guys get all the horses under the hood? I live in Orange County California. Do you local places where I could add more grrrrrr to my wrx?
12-28-2001, 03:45 AM | #19 |
Member#: 11271
NESIC
do it yourself homey!
Anyone running a gt30r or gt35r on a wrx hybrid | 99subi | Built Motor Discussion | 12 | 10-12-2007 06:00 PM |
Who here is running a good amount of power on the stock WRX tranny? | mrtrex | Transmission (AT/MT) & Driveline | 11 | 07-09-2002 02:32 AM |
Anyone running 215/45/16 Falkens on stock rims? | veloLexus | Brakes, Steering & Suspension | 4 | 05-06-2002 01:40 AM |
Full Boost in 1st and 2nd gears on stock WRX | Castor Troy | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 8 | 03-23-2002 06:48 PM |
Will a Legacy Turbo Tranny handle 260-280hp and similar torque? | MY99 2.5GT | Legacy Forum | 8 | 11-19-2001 05:53 PM |
