12-15-2008, 09:54 PM | #1 |
Member#: 137902
Vehicle:---- living life to the least!! |
home theatre guys...bitsream or pcm?
bitsream or PCM?? need help setting up my seestum. from what i can tell bitstream is better? thanks....
also is hdmi just for video or do i get sound with that too? that doesn't really matter cuz i'm using a digital coax to my receiver. also would optical be better for sound?
12-15-2008, 09:55 PM | #2 |
Member#: 57283
Vehicle:2014 4.7L of TT Fury w/ 4Matic |
do you mean toslink or coax for digital? coax
12-15-2008, 09:56 PM | #3 |
Member#: 44170
Vehicle:2010 Forester XT 05 and 09 honda ruckus |
12-15-2008, 10:15 PM | #4 |
Member#: 137902
it;s one of those fancy digital RCA types that had to some certain ohms i think.
12-15-2008, 10:19 PM | #5 |
Member#: 17751
SCIC
Depends, if you want your reciever to do the processing then bitstream. You got no choice really.
12-15-2008, 10:19 PM | #6 |
Member#: 34154
South East
Vehicle:2005 1/2 jew crew |
depends on alot of things. if your using dvd and no hd audio codecs then your receiver can probably decode so send bitstream. if you are using bluray and trying to get hd audio, then your receiver has to accept audio over hdmi. if it does you need to know if it will decode the codecs or will it just accept pcm. also will your bluray decode or bitstream? the ps3 only decodes where as alot of the bluray players only bitstream.
12-15-2008, 10:55 PM | #7 |
Member#: 137902
well i did some reading here and there. my unit has 3 output versions. stereo, spdif raw and spdif pcm. raw basically comes out as dts or ac-3/dolby digital, which is 5.1.
aparently raw is a little better since it is usually how it was recorded, has better separation, and usually finer detail . for expample if i switch to pcm, then my unit auto decodes and will only decode to prologic and prologic2, whereas if i use raw, then my unit detects dolby digital and it sounds tons better. btw i don't have a HD player, just regular DVD and upconverting. someday i'll afford the blu rays i still need to get the hdmi cable also. i guess my player needs it for upconverting copy protected dvds, which i assume is most of them. my unit does not do HDMI, so it'll just have to be for the picture. i'd just use component, but it doesn't support the upconvert on the protected dvds. so that's kinda dumb and defeats the purpose. weird. |
12-15-2008, 11:32 PM | #8 |
Member#: 17751
SCIC
Home theatre stuff package or individual | 12vpro | AKIC Private Classifieds | 0 | 06-05-2008 09:13 PM |
Home Theatre Recommendations (Theatre in a Box or Piece by Piece) | Swivel1000 | Off-Topic | 35 | 05-13-2004 03:56 AM |
FS Cheap local and loud, Home theatre gear yamaha | elsanto | Tri-State Area Forum | 0 | 09-09-2003 04:28 PM |
Home Theatre Equipment FS Yamaha, Sony.. | elsanto | Private 'For Sale' Classifieds | 5 | 09-09-2003 04:08 PM |
OT: Home theatre subwoofer heaven | WAFlowers | South East Region Forum | 26 | 03-03-2003 11:26 AM |
