Welcome to the North American Subaru Impreza Owners Club Monday June 18, 2018
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 08-11-2003, 01:04 PM   #1
Camperguy
Member#: 21274
2002 Mc_Bains car
I use to have a WRX :(
Default Guys running a catless down-pipe and cel fix.Any probs with OBDII testing?
Hey I am going with a catless down pipe but am keeping my stock mid-pipe.I guess I`m going with a Pony-Express mil eliminator and was wondering if the OBDII emmisions testing will see this or will it pass?
Bill
Camperguy is offline   Reply With Quote
Old 08-11-2003, 01:46 PM   #2
Karl
Member#: 13110
From what I understand, if they put a scanner on your car, and the ecu passes all the OBD II readiness, you pass emission.
No sniffer, no rollers (even for 2wd vehicles)
At least this is the case in Rhode Island.
(Of course, you have to pass all other safety testing too.)
Karl is offline   Reply With Quote
Old 08-11-2003, 01:50 PM   #3
Snowphun
Member#: 1800
In theory you should be fine, as the ECU is reporting everything to be within specs. But what may be an issue is what the MIL fix is doing to the voltage reported back to the ECU. It may be "in spec" as far as the ECU is concerned, but it may be clearly wrong to the monitoring software (like reporting far too clean for example).
I would recommend installing any MIL fixes as discreetly as possible.
Paul
Snowphun is offline   Reply With Quote
Old 08-11-2003, 02:10 PM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
I believe this is correct and the keyword is readiness. When they hook up the scanner to your OBD-II connector they're looking for two things: Is the MIL commanded "OFF" and do all I/M monitors indicate "READY?"
It has been reported in thread http://forums.nasioc.com/forums/show...hreadid=367865 that the "MIL fix" may prevent the catalyst monitor from ever indicating "READY." If so, you'll never pass emissions - they'll tell you to come back at some future date for a retest because one of your I/M monitors came up "NOT READY."
Jon [in CT] is offline   Reply With Quote
Old 08-11-2003, 02:39 PM   #5
Sith_Lord
Member#: 40619
My understanding is that the MIL eliminator sends a signal to the ECU as voltage in an acceptable range to indicate a fully functioning catalytic convertor. Am I off base here?
Sith_Lord is offline   Reply With Quote
Old 08-11-2003, 04:34 PM   #6
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
not trying to hijack this thread, but after reading the other thread, the CEL fix for the uppipe won't effect the readiness in the EGT sensor to the computer?
coyote73176 is offline   Reply With Quote
Old 08-11-2003, 07:48 PM   #7
Jon [in CT]
Member#: 2992
02 WRX Sedan
I think you probably are off base. It looks like the MIL eliminator changes the resistance or impedance that the ECU sees when it tries to measure the O2 sensor's temperature. The ECU is fooled into believing that the O2 sensor isn't hot enough to provide accurate readings. The ECU can't run it's catalyst efficiency check until the rear O2 sensor reaches operating temperature. The MIL elimantor apparently doesn't work on 2004 WRXes. I'm guessing that the 2004 WRX ECUs now set a timer and if it pops and the rear O2 sensor still hasn't reached operating temperature, the ECU throws a "bad sensor heater" trouble code.
This, of course, is merely speculation.
Old 08-11-2003, 07:51 PM   #8
coyote73176
Member#: 36576
2k2 WRB wrx WAGON
16G'd & FMIC'd
you could be right with that. I checked the codes on my 02 after work today and theres an "NA" after the H02 (heated 02 sensor). I guess with the my02 they don't have the heated sensor.
NorCal: Perrin cat-less down-pipe w/ CEL fix kjsmith2266 Engine/Power/Exhaust 2 04-02-2009 12:17 PM
04 Stock WRX Wagon Down pipe, Headers, CEL fix wrx_gon Engine/Power/Exhaust 16 08-23-2008 08:16 PM
getting up/down pipe what cel fix TheSubyGod Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-19-2005 10:16 PM
FS: MI - Helix Down Pipe w/CEL Fix - $200 OBO (PU) toni Private 'For Sale' Classifieds 5 09-22-2004 12:40 PM
For Sale, HKS Carbin/TI cat back with Helix Down pipe and CEL fix. $800.00installed!! WRBLUEWAGON Tri-State Area Forum 8 01-28-2003 01:33 PM
