07-15-2011, 02:22 PM | #126 |
Member#: 220868
South East
Vehicle:2005 STi Urban Camo Orlando, FL |
The smallest blanket would work, I can help you out with that.
You could do tape on the hood but it only reflects, it doesn't absorb. So you don't want to reflect heat back on certain things.
09-29-2011, 08:07 PM | #127 |
Member#: 98955
Vehicle:2011 WRX Hatch White |
09-29-2011, 11:42 PM | #128 |
Member#: 206720
SWIC
Vehicle:2002 WRX Wagon Silver |
Yes even stock cars suffer from heat soak. Every one who is concerned about performance needs to fight the heat. Heat is energy and any heat that is not controlled is lost energy.
09-30-2011, 12:33 PM | #129 | |
Member#: 98955
09-30-2011, 12:59 PM | #130 |
Member#: 220868
South East
You could just cut the metal out between the larger holes and just make one long oblong vent, that would be ideal.
We did a few more things to help with engine bay heat, we'll get some pics and update our post shortly |
09-30-2011, 02:28 PM | #131 |
Member#: 98955
Any cons to using a turbo blanket?
So just reading through this post I am getting a feeling that everyone is using turbo blankets with great results.
The pros seem to be obvious: better heat management, less heat under the hood, faster turbine gas velocity, etc... But it leaves one big question in my mind. Are there any cons to using one? Will it shorten turbine life span? What about engine bay fires? Burn engine oil more? Anything??? Thanks for all the help! |
10-03-2011, 12:22 PM | #132 |
Member#: 220868
South East
Some people think it will shorten turbo life by keeping the turbo running hotter.
I haven't read any definitive research on it, and realistically the average person doesn't need to worry about this. I'd rather personally have the benefits of everything else in the engine bay not receiving so much radiant heat. |
10-07-2011, 02:07 AM | #133 | |
Member#: 98955
10-07-2011, 02:16 AM | #134 |
Member#: 98955
Has anyone tried lining the inside of a turbo shield with DEI aluminum or gold tape or an equivalent heat reflective material? I wonder if it would be effective at reflecting some of that radiant heat from the turbo away from the IC. It probably won't be as good as a turbo blanket but could offer an alternative for people that are not comfortable with a blanket. I personally feel like my turbo needs a little breathing room.
10-07-2011, 10:28 AM | #135 |
Member#: 207561
AKIC
Vehicle:2018 Forester Limite Pearl |
I have actually seen several pictures and threads where people have lined the underside of the heat shield with the gold tape. Go for it!
10-07-2011, 12:38 PM | #136 |
Member#: 220868
South East
Yeah the Gold Tape would help I'm sure.
10-07-2011, 02:12 PM | #137 | |
Member#: 98955
10-10-2011, 01:33 PM | #138 |
Member#: 220868
South East
It will help reflect heat down and away from the heat shield, instead of the shield reflecting what little it naturally would and then absorbing heat and radiating out.
10-10-2011, 03:47 PM | #139 |
Member#: 97043
TXIC
Vehicle:08 STI 02 Z28 - project |
How hot can the gold tape get before things start melting or burning? Is the adhesive backing on it just as tough as the material itself?
I imagine the glue starts breaking down sooner than the tape so it might separate. Perhaps increasing risk of underhood fire? If I had a turbo blanket I would leave it at that without the lining. To reduce underhood heat I'd suggest wrapping the cast iron uppipe and headers. Both retain heat in the piping to keep precious exhaust velocity higher and prevent heat leaking out. |
10-10-2011, 03:58 PM | #140 |
Member#: 97043
TXIC
As for drilling out holes from the inner fender, I've pulled out the rubber bumper thing Subaru thought was a good idea to leave BLOCKING A VENT Didn't want to swiss cheese it without additional fender bracing.
Not sure if it helped but you can feel hot air leaving the vent after driving and still for a while while the car cools down. |
10-10-2011, 04:08 PM | #141 | |
Member#: 296791
Vehicle:2011 wrx OBP |
the wrx fenders seem to be just for show. If you search for "heat vent" on the page, it shows it as standard for the sti and na for the wrx. Wondering whether that is just a typo, carried over from the 2010, though. |
10-10-2011, 05:46 PM | #142 | |
Member#: 178770
NESIC
Vehicle:06 STi 17 Fozz |
10-10-2011, 08:29 PM | #143 | |
Member#: 79222
W. Canada
Vehicle:'09 STi 297.5 WHP Blue |
10-11-2011, 02:31 AM | #144 | |
Member#: 98955
10-13-2011, 01:24 PM | #145 |
Member#: 220868
South East
They do it so people don't complain when they driver through a muddy puddle and they get dirt coming out of the vent all over their new car.
At least they leave it for the enthusiast to take off if they want |
10-26-2011, 12:54 PM | #146 | |
Member#: 10202
RMIC
Vehicle:'07 Spec B '85 EJ25 Syncro Westy |
I've also had Ti wrapped UP/DP, covered parts of the intake piping and resonance chambers with the gold foil, and used the heat reflective/insulated sleeves on my AWIC fluid lines. Everything helps! |
10-31-2011, 11:29 AM | #147 |
Member#: 220868
South East
Yeah the Gold Foil is good stuff, for sure.
11-02-2011, 01:06 PM | #148 |
Member#: 220868
South East
Mid-week SEMA Bump!
Don't forget to visit our website and use our special Coupon code this week -sema2011 www.circuitmotorsports.net |
11-03-2011, 01:10 PM | #149 |
Member#: 220868
South East
Mid-week SEMA Bump!
01-19-2012, 12:09 PM | #150 |
Member#: 116355
TXIC
Vehicle:2004 Impreza STI bassboat JBP |
I found this thread very useful! bump for you.
75% of the reason i'm sticking with a TMIC setup, is to keep the oem front bumper beam. Last thing I need to deal with is the insurance guy asking me why I removed "safety" devices from my vehicle. |
SCCA AUTO-X: Bartlett Beat in the Heat Bonanza | JordyB | Alaskan Impreza Club Forum -- AKIC | 65 | 08-13-2008 12:57 AM |
Beat the Summer Heat With the All-New Portable Seat Cooler! | NYCshopper | Non-Subaru News & Rumors | 5 | 01-06-2007 12:05 PM |
How are you beating the heat? | upnygimp | Off-Topic | 9 | 09-27-2006 05:34 PM |
Beat the Heat | iWayner | South East Region Forum | 5 | 07-25-2003 06:13 AM |
Austin: Beat the Heat | TriniTuner | Texas Impreza Club Forum -- TXIC | 7 | 02-14-2002 10:20 PM |
