01-26-2010, 04:15 PM | #51 |
Member#: 97841
Vehicle:2005 STI Race Ready OBP/Orange |
Are you going to do any wheel to wheel club races or just TT?
01-26-2010, 05:17 PM | #52 | ||
Top Scoob 009
Member#: 68273
Vehicle:2012 WRX GD Race Car |
You can only imagine how excited I am! You know I wouldn't trust it in anyone else's hands |
01-26-2010, 05:19 PM | #53 |
Top Scoob 009
Member#: 68273
Yes I'm planning to do some NASA ST2 races this season, I just have to complete comp school. I may even try to rent a spec miata or something and do comp school earlier in the season so I have my license when the car is done. I'd also like to do an enduro or 2 later in the season, we'll see how things go though.
01-26-2010, 06:01 PM | #54 | |
Member#: 149631
Vehicle:ST-3 STi 2.3L Evo |
01-26-2010, 06:44 PM | #55 |
Member#: 55727
South East
Vehicle:#533 Spec Racer Ford |
01-26-2010, 06:49 PM | #56 |
Member#: 118082
SCIC
Have you decided on the airbrushed mural for the hood yet?
Im thinking this would look pretty tough: The new aero package should be sick too, put this to shame: |
01-26-2010, 07:13 PM | #57 | |
Top Scoob 009
Member#: 68273
I think the bald eagle we discussed earlier is a definite possibility, but that tiger just screams "dont **** with me." The aero package on the van is pretty solid, he must have spent a lot of time in the wind tunnel refining it. |
01-26-2010, 07:14 PM | #58 |
Member#: 87194
Sorry to hear about the crash!
Good luck with the new build. I look forward to reading about it! |
01-26-2010, 08:28 PM | #59 |
Member#: 149631
01-26-2010, 08:48 PM | #60 |
Member#: 211057
Vehicle:2006 STI Matte Black |
cant wait to see this car when its done.
01-26-2010, 09:43 PM | #61 |
Member#: 101091
01-26-2010, 09:52 PM | #62 |
Member#: 99140
E. Canada
Vehicle:GD Racing chassis Slowly in construction |
I'm doing something similar but not on the same time scale and budget as you ....I will be happy to be done somewhere in 2011. I will follow you're build very carefully.
01-26-2010, 10:01 PM | #63 |
Member#: 98961
Vehicle:2003 WRX Black |
PM'd you.
01-27-2010, 07:46 AM | #64 |
Member#: 95419
E. Canada
Kosmic ... did you install that cage, or you purchased the car like that?
There are a few SERIOUS issues i suggest you address before continuing: 1) footings on the main hoop need to be at the lowest floor panel possible. In the case of the subaru, if you mount were you are, a rollover could deform the panel enough to actually puncture the fuel tank.... 2) Main Hoop and A-pillar support need to be installed, mandatory in ALL series as of 2008. 3) Front Upper windscreen supports, again, I believe the majority of series are mandatory now to prevent INWARD collapse towards occupants. I have attached the schematics of an international spec design to help guide you. Nothing is worse than having to re-do parts of a cage once the car is finished! Best of luck Last edited by MSI; 01-27-2010 at 07:52 AM. |
01-27-2010, 08:48 AM | #65 |
Member#: 99140
E. Canada
Let's talk about this via PMs, I don't want to hj BJ's thread.
I just want to say, there's no oem fuel tank in that chassi.....I have a fuel cell. The car ran in the Speed World Challenge not too long ago. |
01-28-2010, 12:16 AM | #66 |
Member#: 78074
Vehicle:2005 STi Aspen White |
w00t! This is going to be an awesome build! Can't wait to see what you do with it.
01-28-2010, 05:34 PM | #67 |
Member#: 158123
01-28-2010, 05:42 PM | #68 |
Member#: 139955
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
How will you be finish welding the top parts of the tubes on the upper half of the cage thats against the roof now that youve already welded in your floor plates?
01-28-2010, 05:47 PM | #69 | |
Member#: 158123
We normally double layer the floor plates in the rear. What you see is the first layer. We would drill a hole in the first layer in the rear and drop the cage down to weld it. After welding the top, you raise the cage back up and weld in the second layer of floor plate. After that, we box in the rear as well to tie it into the side frame rail. In this, case, we may be able to weld the top without dropping the cage, because we will be cutting the center of the roof out to install the carbon fiber panel. Regards, JJ |
01-28-2010, 06:03 PM | #70 |
Member#: 139955
Yeah Im used to seeing it done with the hole in the floor method, so I was confused when I saw the plates welded in.
And I forgot this car will be a convertible for at least a few days of it's life. |
01-28-2010, 06:17 PM | #71 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
Hey I was standing next to both of your cars new and old this past sunday when I was getting tuned last sunday... Sorry to hear about your old car. Good luck with the new build...
01-28-2010, 07:17 PM | #72 | |
Member#: 158123
You will notice that in this picture, that there is an additional plate welded in once the cage was raised back up.... Here is a picture after the rear boxing is complete: Hopefully that does a better job of explaining how it is normally done. Again, our plan is to try to weld the tops while the roof is off. We shall see. Last edited by IAG Performance; 10-13-2014 at 12:48 PM. Reason: update image links |
01-28-2010, 07:20 PM | #73 |
Member#: 139955
Completely understood now. Thanks
I believe I have the urge to cage my car now. |
01-28-2010, 07:37 PM | #74 |
Top Scoob 009
Member#: 68273
Thanks for posting those pics, looks like the cage is off to a great start. The front plinth boxes are a work of art
01-28-2010, 07:41 PM | #75 |
Member#: 51463
Vehicle:2013 Impreza SWP Gas Sipper |
Good luck on the build, I saw you there pulling parts out of the old car when we were up for my tune last month. It's came a long way since then.
Similar Threads | ||||
Turn in Concepts 2010 Track Car Build | Turn in Concepts | Press Releases | 374 | 12-30-2016 02:06 PM |
My GC Race car build | rrsettgast | Member's Car Gallery | 3 | 04-27-2010 12:19 PM |
Came out to my car... belt on the ground and this (pic). | Padge | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 03-11-2009 10:36 PM |
Getting my car closer to the ground | BluScopion | Vancouver Impreza Club Forum -- VIC | 12 | 02-02-2007 02:30 AM |
got car back from the shop, now lights are messed up | X2.5RS01X | New England Impreza Club Forum -- NESIC | 1 | 02-21-2005 09:41 PM |
