Welcome to the North American Subaru Impreza Owners Club Saturday November 28, 2020
Old 10-19-2020, 03:26 AM   #26
silver_echo
Member#: 241296
2002 wrx
aspen white
Originally Posted by Mulder View Post
You might have to swap pullies if they are different. Also check whether the later alternator has an internal regulator as yours does, or is ECU controlled. If the latter it won't be compatible even if it fits physically.
This swap is already in my car. That alt is internally regulated, and the pulley matches just fine.
silver_echo is offline   Reply With Quote
Old 10-19-2020, 09:54 AM   #27
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Thanks for your comments, I was only looking at the physical shape of the alternator not realizing the internal systems could be a problem.
Glad to have a member confirm fit and function.
Ironically, I discovered yesterday both my battery terminals were not exactly fully tightened. After tightening the terminals my car is working 100% again.
I will install the 110 amp alternator anyway since I already ordered it.
D-Rodman is offline   Reply With Quote
Old 10-19-2020, 02:26 PM   #28
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suggest you leave the original one in since it is okay and install the new one if it is really needed at some point in the future.
Cougar4 is offline   Reply With Quote
Old 10-19-2020, 04:03 PM   #29
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Default What alternators fit 2002 WRX
I have an aftermarket head unit and subwoofer, also aftermarket xenon projector headlight retrofit. I知 thinking the 110amp alternator is a good thing to have. Although it is working just fine now, I知 thinking the amperage bump would be beneficial.
Old 10-19-2020, 05:12 PM   #30
cdska
Member#: 458809
2005 wrx wagon
You could also install a 1n4004 diode in line with the power line running to the alternator. Half a volt jump in charging regulation and my car loves it.
cdska is offline   Reply With Quote
Old 10-19-2020, 06:35 PM   #31
D-Rodman
Member#: 110078
05 Saabaru JDM STi
I don稚 know electrical, it痴 my kryptonite. I知 not sure the diode would be necessary with the 110amp alternator. Thanks for the tip, appreciate all the input as this is an old thread I revived with my inquiry and it is getting fresh input thanks to all you contributing.
Old 10-20-2020, 04:04 PM   #32
Cougar4
Member#: 53443
Winestone
If your alternator is working correctly and the wiring is in good shape for the charging system then you don't need to add anything to the wiring. A battery can only hold a certain amount of charge. Making the charge voltage go higher is not necessarily a good thing in my book.
Old 10-28-2020, 10:54 PM   #33
SubaruBastardProject
Member#: 519745
1995 Legacy
Cocaine White
If you're looking for higher output with minimal modification the PowerBastards 220 amp alternator is also an option.
SubaruBastardProject is offline   Reply With Quote
Stock alternator from 2002 wrx Bill Engine/Power/Exhaust 4 11-28-2007 01:38 PM
Stock alternator from 2002 wrx Bill Engine/Power/Exhaust 0 11-19-2007 11:27 PM
WTB: NNJ, Alternator for 2002 WRX SupaSizeFries Tri-State Area Private Classifieds 7 10-16-2007 04:21 PM
WTB: NNJ, Alternator for 2002 Wrx SupaSizeFries Private 'Wanted' Classifieds 1 10-15-2007 06:45 PM
