Welcome to the North American Subaru Impreza Owners Club Saturday October 19, 2019
Old 04-07-2014, 11:22 PM   #1
NIL8GM428
Member#: 126558
2015 WRX
ISM
Hey guys, I should be taking ownership of my 2015 WRX in early May. In the meantime I have been searching for a wheel and tire combo to replace those hideous(to me) 17's.
For those of you that have your cars already what size of wheel/tire combo do you feel would complement the car? Looking for a semi aggressive set up but not interested in rolling any lips. Car will be lowered(mild) once someone offers a spring. I was hoping to run 18's in the 265/275 range. Think this is a possiblility? Any recomendations on rim size/offset??
thanks
Rick
NIL8GM428 is offline   Reply With Quote
Old 04-08-2014, 11:30 PM   #2
willimprez
Member#: 91655
15 STI
CWP
I'm in the same boat , just picked up my 15 WRX and will be swapping to some nicer wheels and tires ASAP.
I'm aiming for 18x9.5 Et 35-48ish with 265/35-18
willimprez is offline   Reply With Quote
Old 04-08-2014, 11:38 PM   #3
RavSpec
Member#: 26854
2002 Impreza
WRX
roll fender, coil over, camber arms needed.
RavSpec is offline   Reply With Quote
Old 04-08-2014, 11:53 PM   #4
NIL8GM428
Member#: 126558
2015 WRX
ISM
So what do you think the largest wheel/tire that can be fit in without any other mods? Of the above wheels that you tried what was the best fit?
Old 04-09-2014, 12:50 AM   #5
DrDanimalSize
Member#: 254097
2010 2014 Impreza
Should fit fine with a 255 tire with no fender roll on 45 offset. Just by eye on the new STi there is still room for more tire, and they are 245s with 55 offset wheels. 255 with 45 offset will stick out 15mm farther than stock STi.
DrDanimalSize is offline   Reply With Quote
Old 04-09-2014, 07:22 AM   #6
sc00by4life
Member#: 97135
Offset means nothing without width.
Old 04-08-2014, 11:34 PM   #7
RavSpec
Member#: 26854
2002 Impreza
WRX
Already tested on our new 2015 STI launch edition
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
19x10.0 +35mm 5x114.3
Old 04-09-2014, 11:15 AM   #8
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
shortly.
Tested... What were the tires? What were the verdicts?
colin1234567 is offline   Reply With Quote
Old 07-05-2014, 08:07 PM   #9
whitefrs
Member#: 341024
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
shortly.
how was the poke on 18x9 +20
whitefrs is offline   Reply With Quote
Old 09-18-2014, 09:45 AM   #10
pbawesome
Member#: 393499
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
shortly.
Any pictures of these?
pbawesome is offline   Reply With Quote
Old 05-13-2015, 05:19 PM   #11
cyrusthevirus23
Member#: 345050
2006 Lancer Evo 9 Mr
apex sliver
[quote=RavSpec;41758434]Already tested on our new 2015 STI launch edition
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
how much are these wheels starting off at?
cyrusthevirus23 is offline   Reply With Quote
Old 05-26-2015, 04:33 PM   #12
nintendobratkat
Member#: 47104
2016 WRX Limited
What wheels are these? Where can I order them?
nintendobratkat is offline   Reply With Quote
Old 07-20-2015, 07:43 PM   #13
mellowjamesy
Member#: 425604
2015 WRX
Ice Silver Metallic
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
Which picture is for which spec? and what tires are each spec running? Is it a squared set-up? What are the fronts running and what are the rears?
mellowjamesy is offline   Reply With Quote
Old 08-05-2015, 10:40 PM   #14
mellowjamesy
Member#: 425604
2015 WRX
Ice Silver Metallic
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
How well did the 18x9.5 ET 30 and the 18x9.5 ET 25 fit? What kind of modifications did you need to run it? And with what tires?
Old 08-08-2015, 08:45 PM   #15
Boost is Best
Member#: 102858
15' WRX
ISM
18x10.0 +20
Interesting ... These fit I'm assuming, I didn't find the pics though. Does anyone know what size tires were installed?And this is assuming from the looks of it STi & WRX bodies are similar in fender width ... (This is in reference to my 18x10 e25 w/ 275's fitting) :
Boost is Best is offline   Reply With Quote
Old 05-12-2016, 04:51 PM   #16
D3monicTun3r
Member#: 443609
2016 WRX
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
What wheels are these ??? Did you need to do any fender rolling or anything to fit.
D3monicTun3r is offline   Reply With Quote
Old 08-02-2016, 12:27 AM   #17
kdique
Member#: 145790
2008 forester xt
blue
those look sick!!
kdique is offline   Reply With Quote
Old 08-02-2016, 08:30 AM   #18
jbatarseh11
Member#: 445220
2016 WRX
Originally Posted by kdique View Post
those look sick!!
What are you referring to exactly? I'd like to see what looks sick
jbatarseh11 is offline   Reply With Quote
Old 08-03-2016, 10:54 AM   #19
raven1231
Member#: 427206
2016 WRX
Those bruh!
raven1231 is offline   Reply With Quote
Old 08-03-2016, 10:55 AM   #20
jbatarseh11
Member#: 445220
2016 WRX
Originally Posted by raven1231 View Post
Those bruh!
The rpf1s?
Old 10-01-2016, 10:31 PM   #21
Webberx
Member#: 189361
2017 STi
White perl
Default What wheels are those?
In the middle two pictures? I looked on rays and couldn't find those. I want for my '17 sti stock ride height. I will not be lowering it. On the first pics if this post are the wheels I am referring to.
Webberx is offline   Reply With Quote
Old 11-07-2016, 03:00 PM   #22
mgpmadmike
Member#: 457800
Default 2014 Subaru sti wheel question
Hello everyone I had a 2014 Subaru sti. I know that the stock wheels are 18x8.5 with a +55 offset well I was looking at a set of wheels 18x8 +35 offset would these wheels fit and clear the brakes without any problems I'd hate to buy them and them not fit right or rub don't really want to roll or pull fenders either just bolt them on would there be any problems I'm new to this website so if someone could just message me on here or something I would really appreciate it thank you!!
mgpmadmike is offline   Reply With Quote
Old 11-07-2016, 08:43 PM   #23
Rowrx11
Member#: 338312
Oz ultralleggera 18x8 +35 and 235/40/18 rce yellows. No problem at all. This is my old setup.
Rowrx11 is offline   Reply With Quote
Old 04-11-2018, 08:48 PM   #24
Devynsettle
Member#: 484526
Default Wheels
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
WHAT WHEELS ARE ON THE first and second stis?
Devynsettle is offline   Reply With Quote
Old 04-18-2019, 12:24 PM   #25
thwrightstuff
Member#: 358745
2017 Subaru WRX
18x9.0 +20
18x9.5 +38
18x10.0 +20
Will be testing
18x9.5 +30
18x9.5 +25
Did any of these need fender rolls or camber adjustments or were they bolt on wheels? I want the biggest possible size without needing to adjust my camber, my suspension or roll my fenders.
thwrightstuff is offline   Reply With Quote
