Brakes & Suspension Forum sponsored by The Tire Rack |
06-11-2019, 08:03 PM | #1 |
Member#: 467898
Have to replace right front Lower Control Arm on 2016, anyone have any tips?
Slid into a curb and bent my control arm, It doesn't seem like a bad job but is there anything I need to know for first time? I am more worried about the ball joint being trouble
06-11-2019, 08:54 PM | #2 |
Member#: 165955
Vehicle:2015 WRX Base WRB |
Its easy. You won't have any issues. Just make sure you have a pry bar.
06-11-2019, 09:34 PM | #3 |
Member#: 467898
06-11-2019, 10:43 PM | #4 |
Member#: 165955
No idea but I just call the dealership and ask. I want to say they will.
06-12-2019, 07:37 AM | #5 | |
Member#: 153216
as for level of dificulty for this job, I'd say its not hard at all... just spray and let the ball joint to knuckle bolt soak.. I personally use brake fluid.. as I've found it to work wonders on stuff like that... |
06-13-2019, 08:38 PM | #6 | |
Member#: 467898
06-13-2019, 08:48 PM | #7 |
Member#: 470981
Vehicle:2008 Legacy GT spec DGM |
Make sure to tighten the bolts with the weight of the vehicle on the ground. If you tighten with no weight on the arms, you will prematurely ruin the bushings because they will be tweaked once the car is on the ground.
06-20-2019, 04:35 PM | #8 |
Member#: 502816
06-15-2019, 11:50 PM | #9 |
Member#: 467898
Can confirm. The Lower Control Arm came with the bushings and ball joint
06-20-2019, 04:35 PM | #10 |
Member#: 413457
My tip.. use a bottle jack to support the flange of the big bushing. the jack can hold it snug to the frame as you remove the bolts. withouth it, the flange will torque against the bolt and make it harder to turn the bolts. good luck. it's a great repair that makes the car handle a lot better. I've done both of mine at different times.
